Dell inspiron 17r 7720 don't work on battery
  • rbvndonh
    • Mar 2021
    • 162
    • B
    I have Dell inspiron 17r 7720 with work on battery problem.
    Motherboard:
    DA0R09MB6H1
    In bios there is:
    AC adapter 180W visible.
    Battery work normal condition information.
    In windows it shows 100% charged battery and 41% health (it is greencell replacement battery).
    It had replaced by someone power supply cable.
    I've cheched PQ1, PQ2, PQ31, PQ32. I believed PQ34 will be bad, but there also isn' short.
    Basing on that i replaced BQ24707A for new one, but nothing changed.
    PR3, PR4, PR5, PR6 have OK values as in schematics.
    I found that PR132 have 150ohm instead of 240ohm which shall be still OK for PQ1, but maybe for PQ3 generates problem?
    Have you any hints what to check?
  • mon2
    • 14156
    Re: Dell inspiron 17r 7720 don't work on battery
    Measure the voltage to ground of pq34 (battery mosfet).
    Source (1-2-3)
    Gate (4)
    Drain (5-6-7-8)
    Measure with adapter and battery connected.
    Then measure again with battery only.
    The soldering of the charger IC is ok?
    • rbvndonh
      • Mar 2021
      • 162
      • B
      D 1,065V
      G19,5V
      S19,5V
      D 2V quite quick going down to 0V
      G0V
      S 2V goin slower down to 0,5V
      IC is soldered properly.
      • mon2
        • 14156
        Update - revising this post.
        D 1,065V
        G19,5V
        S19,5V
        These are good readings for the P-channel mosfet (PQ34).
        When gate is 19v5, the mosfet is OFF so the drain pin = battery voltage.
        When the GATE voltage is lower, then the mosfet is ON.
        Are you able to charge the battery pack with perhaps another machine?
        • rbvndonh
          • Mar 2021
          • 162
          • B
          SD - 4,6Kohm
          SG - 21Kohm and rising
          GD - 600Kohm and rising
          NPN require i.e. 25V gate to switch on tranzistor, but here PNP require lower gate voltage to switch on. However there is 19,5V and it switch, but shouldn't. I am right?
          On monday i shall have access to Dell E6540. It looks like the same battery.
          • mon2
            • 14156
            No, please see my revised post. From your measurements, the mosfet appears to be working correctly.
            With the high gate voltage, the mosfet is OFF. The drain pin = battery voltage = 1,065v. Battery is depleted.
            When the battery only is used, the mosfet gate voltage = 0v to enable this mosfet but the battery is depleted.
            When the battery & adapter are connected, you should have a charge voltage to charge this target battery @ PL6 coil.
            Confirm the voltage on each pin of high side charging mosfet @ PQ33.
            • rbvndonh
              • Mar 2021
              • 162
              • B
              Adapter only
              D 19,5V,
              G 1,06V
              S 1,06V
              With battery same readings.
              • mon2
                • 14156
                PQ31 and PQ33 are N-channel mosfets so for these to turn ON, the gate voltage must be higher than the voltage being passed through source / drain pins.
                So the gate voltage must be higher than 19 volts to enable (often ~25 volts).
                At this time, the high side mosfet is DISABLED and the voltage readings are correct.
                Now attach the battery AND the adapter to see if these voltage readings change or not.
                • rbvndonh
                  • Mar 2021
                  • 162
                  • B
                  Yes, with battery and adapter still on PQ33:
                  D 19,5V,
                  G 1,06V
                  S 1,06V
                  Strange, that battery communicates fully charged, in bios show normal operation and in batteryinfoview shows 41% health (same in Dell diagnostics). It seems as it talk with battery.
                  • mon2
                    • 14156
                    Carefully, measure the voltage to ground of the REGN pin # 16 on the charger IC (PU8).
                    This is the LDO voltage that should be ~6 volts on this pin.
                    Next, remove all power -> measure the resistance (like before) but on PQ33.
                    Post each resistance measurement of this high side mosfet.
                    • rbvndonh
                      • Mar 2021
                      • 162
                      • B
                      PQ33:
                      SD 21Mohm and rising
                      SG 204Kohm
                      GD 24Mohm and rising
                      I didn't found for now any shorted tranzistor
                      With adapter only and adapter and battery
                      PU8
                      pin16 6.1V
                      Only battery pin16 is 0V.
                      I checked on ESD2
                      1. 3,3V so PS_ID shall be OK
                      3. 3V adapter only, -0,03V adapter and battery, 0V with battery only
                      4,5,6. adapter and battery 3.3V. Battery only 0V.
                      If there is smbdat and ambdclk is 3.3V then it is ok and ITE shall be OK?
                      I checked plenty of different topics, and EC capacitors close to battery are not shorted, however didn't checked capacity.
                      Maybe at real battery is damaged..
                      • mon2
                        • 14156
                        Based on the voltage measurements of PQ33 in post #7, the high side mosfet is not enabled. This may be due to the PQ33 being defective or the charger IC is unable to boost the required voltage for the gate pin.
                        Remove all power. Meter in DIODE mode.
                        Red meter probe, yes red to ground.
                        Black meter probe to PQ33 pin # 4 (gate).
                        What is the diode mode reading of this pin ?
                        Being an N-channel mosfet, the gate voltage is expected to be > 19 volts (adapter voltage) to enable this mosfet.
                        • rbvndonh
                          • Mar 2021
                          • 162
                          • B
                          Thank you for support. On battery from E6540 it is working without problem, so the main reason was battery itself.
                          Old power supply socket with cable was damaged and also old power adapter id pin was damaged. Maybe there was some shortage, which didn't caus any other damage.
                          That could be a main reaseon, that battery controller locked it.
                          It was very strange, as battery was visible, fully charged and 41% life, but was anyway locked.
                          • mon2
                            • 14156
                            That is what was asked in post #4. Sounds like that the battery is incompatible with this model of the laptop if the same battery is working inside another unit.
                            • rbvndonh
                              • Mar 2021
                              • 162
                              • B
                              With smaller, dedicated battery all works fine.
                              Thank you for help.
                              I shall somehow lock the topic? I dont see such option
                              • danielsak
                                Dell Inspiron 3542 (Cedar_Intel-MB 13269-1) - RTC battery self-discharging and Realtek LAN issue
                                by danielsak
                                Hello, I have issue with Dell Inspiron 3542.
                                Motherboard marking:
                                Code:
                                PWB FX3MC REV: A00
                                The laptop works just fine (on battery and power supply) and doesn't cause any problems, except those described below:
                                1. The first problem is that the RTC/CMOS battery self-discharges after about 2-3 weeks after installing a new battery. I have been installing different batteries (GP, Duracell, Energizer) and the problem still exist.
                                1. The second problem is the LAN network card (Realtek RTL8106E), which is not detected at all in Windows. The BIOS is
                                10-11-2024, 04:36 PM
                              • ipatch
                                dell inspiron 5567 laptop battery lipo WDX0R
                                by ipatch
                                recently i was gifted a dell inspiron 5567 for wiping the data on the hard drive. (yay me). however i already have a computer that i use, so i have no need for this computer. this computer wasn't without its problems though.
                                1. i had to purchase an adapter to retrofit my older style dell laptop battery cable. (not too expensive) ~= 10 bucks for a 2 pack via amz.
                                2. after that i had to find a spare cr2032 (easily found in my parts bin) and assemble a makeshift cmos battery thanks to some copper foil tape and some heat shrink tubing.
                                got the computer...
                                04-02-2023, 04:45 PM
                              • lawrenceptrini
                                Battery not charging - Dell Inspiron 3593 FD155 LA-JO81P (REV 1.0) (A00)
                                by lawrenceptrini
                                Hi Guys,
                                I am seeking some assistance with a Dell Inspiron 3593 FD155 LA-J081P (REV 1.0) (A00) laptop
                                The laptop is working fine with the adapter plugged in and also with a charged battery.
                                Problem is that the laptop is not charging the battery. The battery is recognized in the bios but the
                                ac adapter is listed as 'Not Installed'. So for instance, when a charged battery from another source
                                loses its charge, it stays on 0%.
                                Measurements taken
                                Charging IC (ISL95522HRZ) 32 pins
                                Voltage to ground with ac adapter only plugged in:
                                1)...
                                08-26-2024, 06:45 PM
                              • mohamed mm
                                DELL Inspiron 15 3567 not powering with battery
                                by mohamed mm
                                Hello Everyone, I hope you are all doing well,
                                I have a Dell laptop, Inspiron 15 3567, it's only powring up with the adapter not with the battery, but after it's on I can remove the adapter It works fine with the battery, so only the problem is it does not start with the battery even if its attache with the laptop.
                                battery condition is excellent and the adapter is original, both are detected in the bios. ( sometimes a laptop doesn't start until I disconnect the battery and reconnect it again), I have updated the bios but nothing has changed.
                                Here's my reading with...
                                08-05-2023, 07:08 AM
                              • Bowline
                                by Bowline
                                06-11-2025, 10:13 AM
