RT6576DGQW looking for equivalent ic
  • MarkosG
    • Nov 2018
    • 5
    • Argentina
    Rt6576dgqw compatible ic pls. ty.
  • NotEnough
    Dell G15 5515 RGB Keyboard Not Detected (Compatible Keyboard, Possible BIOS/EC Issue?)
    by NotEnough
    I'm working on a Dell G15 5515 (Ryzen 7 5800H, RTX 3050 Ti) and recently installed a compatible 4-zone RGB keyboard and controller (for Dell G15 5510/5511/5515 models). While the keyboard functions for typing, the RGB lighting is not detected by Alienware Command Center (AWCC), which displays “No AlienFX devices found.”
    What I've Tried So Far:
    • Reseated the cables.
    • Reinstalled AWCC and AlienFX services.
    • Attempted BIOS downgrade but no improvement.
    • Inspected ribbon cables for damage.
    • Explored the possibility of BIOS or
    10-19-2024, 01:34 AM
  • Deby
    List of compatible laptop motherboards
    by Deby
    This is a list of compatible laptop motherboard information that I have been collecting for some time.
    And it's still ongoing.
    Every time I come across information that a board is compatible with another, I write it down.
    Anyone who wants to, can continue to expand the list.
    Packed in the rar, is an excel table that has additional information.
    Motherboards.rar...
    05-31-2024, 04:34 AM
  • m4a2t0t
    BD35231 compatible replacement
    by m4a2t0t
    Anyone know of a compatible replacement that has an adjustable output? The BD35230 has a fixed output of 1.0V and would be acceptable but I cannot find it anywhere. There is also the BD3523 which has an adjustable output but its also nowhere to be found. I could probably source them from alibaba but I dont have that much time and I dont want to make a huge order.
    Or perhaps you know how the BD35231 can be modified to output 0.95-1.0V? The board does have empty pads for an adjustable IC but Ive only been able to make the output go up.
    Thanks for any help...
    08-28-2025, 08:32 PM
  • peter_wheat
    Looking for SMPS flyback tranformer TAM TO-5622 or equivalent?
    by peter_wheat
    Hi All,
    I'm looking for a SMPS flyback transformer TAM TO-5622, or equivalent, or any information on it? Company is Tamura Corp (https://www.tamuracorp.com). It has Primary, Secondary, and Auxiliary windings. Have emailed the company, but no info back yet. It is out of a Makita DC24SC battery charger.. This transformer has a burnt out the primary (caused by a failed MOSFET). Secondary, gave me a reading of 0.49 Ohms, and Auxiliary a reading of 0.93 Ohms. I took it to bits, thinking I might try and re-wind it, but it was more complex than I realized, and had difficulty removing...
    08-28-2025, 02:03 PM
  • taurtnt
    Help identifying AMCH073 regulator or finding a compatible replacement
    by taurtnt
    I’m trying to identify a step-down regulator marked AMCH073. It’s used on the PEX power rail of a graphics card. I can’t find any datasheet or info online.
    Here’s what I’ve observed:
    • It has a QFN-16 footprint, similar to NB670.
    • Pins 1, 2, 15, 16 are connected together and go to the inductor, so likely SW (switch node).
    • Pin 9 is connected to GND, which doesn’t match NB670 (where pin 9 is SW).
    • Pin 8 also seems to be tied to the same GND plane.
    • The chip only says AMCH073, no manufacturer logo or other markings....
    08-24-2025, 03:06 PM
