Apple A1466 power on issue
  • Jacksoft
    • Feb 2011
    • 36
    • Italy
    I have a MacBook A1466 with 820-00165-A with a strange issue.
    The Mac power on and runs perfectly, AST in EFI mode passes all the tests (even the full longer test), but if you leave the Mac off, and without the power adapter connected, for about two days without powering it on and using it, it will not power on anymore (battery have enough charge).
    Already did an SMC reset but the issue still persist.
    What could I check?
    Thank you.
  • mon2
    • 14634
    Re: Apple A1466 power on issue
    Check if you have 3v42 rail with only the battery.
    • Jacksoft
      • Feb 2011
      • 36
      • Italy
      Yes, the 3.42 is present.
      But now, don't know why, the Mac does not power on at all.
      To be more precise:
      If on battery, thermal camera show heat on CPU and SSD and after 3-4 seconds cools down.
      If AC plugged in, thermal camera show a persistent heat on CPU and SSD but the Mac still not bootup.
      No fan spin-up.
      • mon2
        • 14634
        Be sure the power adapter is the original.
        Disconnect the battery and trackpad.
        Connect the power adapter and measure that 3v42 rail is stable. Do you see the magsafe led light on the connector head? What is the color?
        Check the ppbus_g3h voltage to ground.
        Post your measurements.
        • Jacksoft
          • Feb 2011
          • 36
          • Italy
          PP3V42_G3H is 3.42V
          PPBUS_G3H is 8.60V
          MagSafe LED color is orange.
          CPU and SSD are active with about 60°C and the fan is off.
          EDIT: U7870 gets hot too, but voltages seems present.
          • dellxps15
            • Feb 2014
            • 1598
            • italy
            looks like audio capacitor shorted.
            check also if 3,3 volt and 5 volt s5 state are present.
            check if cpu vcore , ram, pch voltage are present.
            • Jacksoft
              • Feb 2011
              • 36
              • Italy
              SORRY for the huuuuuuge delay!
              We tried to replace the U7870 from a working donor board (but with BGA problems) and still the same. We checked all the caps, removed the U8040 but still short, removed also the Q1920 and no luck. We thought the CPU was dead (we tested with just the MagSafe board connected).
              Fully reassebled the Mac back and after some days... It started works again.
              Now we don't understand how this is possible. We checked almost anything and seems there was no extra solder that could caouse a short.
              We don't think could be a BGA issue (that could go away when you thight the screws).
              There was a short and now there's not.
              How could be possible? Any suggestion?
              One thing: U7870 goes hot (45-50°C) when the AC plug is connected and instead of 1.5V on PIN 1 there was about 0.4V, but with voltage injection of 1.5V we read just 0.02A (that is the maximum amount, standing by the schematic, so is correct) in power off state (not normal), but nothing goes hot.
              EDIT: We suspect there's something wrong in the trackpad/keyboard connector on the motherboard (a twisted pin, maybe) that causes shorts or something. We will inspect this in the next days.
              • GLISIT
                by GLISIT
                01-16-2025, 02:29 PM
              • justice171
                Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
                by justice171
                I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
                Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
                1. Verified that all critical voltages are present:
                  • 3.3V and 5V are always present if DC is plugged.
                  • 1.8V on the BIOS chip is present.
                2. Checked the power button functionality:
                  • When pressed, the voltage drops to 0V, indicating the button is functional.
                3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
                  • Confirmed connectivity is intact, ruling out issues
                11-26-2024, 12:39 AM
              • claws77
                lenovo flex 5 14itl05 power sequence issue
                by claws77
                hi guys, my motherboard will not start no matter what
                when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
                but rest nothing happens no sign of life.
                this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
                with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
                but now nothing happens no matter how much i wait/ charge/ press and hold power button.
                i have no knowledge of motherboards ....
                10-20-2024, 02:48 PM
              • yaya3gmax
                Laptop Power Issue – Works on Battery, Fails on Adapter Load
                by yaya3gmax
                Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
                Symptoms:
                • Laptop works normally on a pre-charged battery.
                • Battery does not charge when adapter is connected.
                • Without battery:
                  • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
                  • Speakers “pop” when power cut occurs indicating harsh sutdown.
                  • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
                08-21-2025, 07:16 AM
              • Soulzink
                Samsug washing machine. Power supply DC41-00189a board issue
                by Soulzink
                I am trying to fix a samsung washinmachine power supply main board.
                I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                The power supply board reference is the following: DC41-00189a
                I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                04-19-2025, 06:26 AM
