Macbook Air M1 A2337 Battery Not Recognised
  • Instafixx
    • Jul 2022
    • 374
    • India
    Namaste .
    I have a Macbook Air M1 A2337 which shows a Battery Cross Icon sometimes or sometimes it shows Battery Not Charging and is stuck at 1%.
    Tried another known good battery but it reboots with Apple Logo coming and going.
    The board here is clean and has no history of any liquid damage.
    The machine works perfectly fine on a power adapter.
    Can anyone help me in this please ?
  • mon2
    • Dec 2019
    • 14114
    Re: Macbook Air M1 A2337 Battery Not Recognised
    Check the voltage to ground of each pin on the battery connector. Post the list of measurements.
    • Instafixx
      • Jul 2022
      • 374
      • India
      Pin 1 is PPVBAT_AON_CONN = 0.15V
      Pin 2 is PPVBAT_AON_CONN = 0.15V
      Pin 3 is I2C_SMC_PWR_3V3_SCL= 3.25V
      Pin 4 is I2C_SMC_PWR_3V3_SDA = 3.25V
      Pin 5 is SYS_DETECT_L = 0V
      • mon2
        • Dec 2019
        • 14114
        Is the battery connected ?
        See attached. Measure the voltage to ground of each of the pins with the arrows.
        • Instafixx
          • Jul 2022
          • 374
          • India
          Thanks Mon2 for your help. Was curious and went ahead with a DFU Revive, problem solved.
          • mon2
            • Dec 2019
            • 14114
            Very nice!
            • PeaceDeath
              • Jun 2023
              • 6
              • Ukraine
              Very nice!
              I have the same problem, with 0.15v on 1-2 pins, and battery doesn't displayed on system. But im doesn't have second mac for using revive in configurator.what can you advise me?
              P.s. sorry for my English, im from Ukraine
              • mon2
                • Dec 2019
                • 14114
                The laptop works ok other than this battery problem?
                The battery voltage is low. Maybe not charged?
                Connect the battery to the board. Measure, carefully the voltage to ground of each pin of the battery connector.
                The issue could be the smbus pins (SDA and SCL) on the battery connector. These pins must be ~3v each.
                Confirm it.
                • PeaceDeath
                  • Jun 2023
                  • 6
                  • Ukraine
                  Confirm it.
                  from the original charger 30 w works, but with a heavy load it reboots. sda and scl have 3v, + and - measurements on the battery show 3.7v
                  • mon2
                    • Dec 2019
                    • 14114
                    Since the battery is not detected yet the smbus lines appear to be ok, suggest to test with another known good battery. Unit must be able to detect the battery.
                    Would you have other but higher current USB type c power adapters for testing? They must support 20v.
                    Test if available to see if the unit reboots under heavier loading. That is odd to me.
                    • PeaceDeath
                      • Jun 2023
                      • 6
                      • Ukraine
                      the situation is as follows: found a battery (from a donor) from the battery does not turn on, if you turn on the power, the laptop will start, and then pull it out, it will run on battery, but the system is not displayed as before. I think that the board does not give a charge. in which direction to move? I am a beginner, and due to hostilities in the country, there is no way to contact the service.
                      • PeaceDeath
                        • Jun 2023
                        • 6
                        • Ukraine
                        By the way, I tried the apple configurator, the restoration did not help
                        • mon2
                          • Dec 2019
                          • 14114
                          When it runs on battery - does the desktop / OS show the battery to be detected?
                          Can you extract the details of the battery ? Such as number of charge cycles, battery health, battery serial #, etc. ?
                          • PeaceDeath
                            • Jun 2023
                            • 6
                            • Ukraine
                            No it doesn't detect
                            • mon2
                              • Dec 2019
                              • 14114
                              Can you post the 820-#### number of the logic board?
                              Link the schematic if it is available on the schematic forum. Will also check my paid database to see if it is included.
                              If the battery is not detected, then the SMBUS interface is not working with the logic board or this battery.
                              Is this the only battery you have at this time?
                              Unless the host logic board can detect the battery, the charger IC will not be able to charge the same battery.
                              • drlarsen
                                MacBook Air M1 A2337 battery/charging issue
                                by drlarsen
                                Hello. Sorry for the long post, but I am trying to decide if this is a simple battery replacement, or potentially something more complicated.
                                I bought an open box MacBook Air M1 2020 A2337. Seller claimed it was never used. Visually, it appears pristine.
                                On arrival, the battery was completely flat. Computer powers up and boots fine. Battery status showing 1% and charging, 1 cycle. coconutBattery showing 0 mAh and ~6 watts.
                                After some hours, the battery status did not improve. Restore via DFU did not help.
                                I connected the power adapter to a Kill-a-Watt...
                                07-17-2025, 02:35 PM
                              • Bowline
                                by Bowline
                                06-11-2025, 10:13 AM
                              • brockauly
                                Macbook M1 A2337 EMC 3598 weird battery charging problem
                                by brockauly
                                Hi guys,
                                If I unplugged the battery and the charger, then plug the battery then the charger, it charges without problem.
                                Then if I unplug the charger and plug it back, it won't charge anymore.
                                In the first case, main voltage is regulated at ~12.5V and charges the battery.
                                After unplugging the charger, main voltage drops to battery voltage at ~11.5V.
                                After replugging the charger, main voltage stays at ~11.5V and won't go up to ~12.5V again.
                                I found C520A (2.2ยต after current sensor from USB-C source) completely burnt and removed it properly. I cleaned...
                                02-05-2025, 10:51 AM
                              • reformatt
                                A2337 not working with flat battery
                                by reformatt
                                Looking for some advice on a 820-02016 board as I don't have much experience with these M1 machines. Learning the nuances of them as I go.
                                So the history of this machine was it had been in a bag where a bottle of water leaked. Presented as dead about a month ago, corrosion was mainly around the battery connector and it's sub-PCB. Some corrosion was noted on the board around UC300, CC325, CW1C7, CW1C8. That was it really.
                                Now without battery connected, USB-C will stay at 5V and cycle between 0 and 120ma. PPBUS_AON is cycling between 0 to 12.3V. If battery is connected,...
                                10-12-2023, 04:36 PM
                              • gboone
                                820-00850 2019 MacBook Pro 13" Touch Bar (A1989) mysterious battery drain
                                by gboone
                                Hi, I was given this laptop by my uncle who said:
                                • It would occasionally shutdown if not plugged in
                                • battery had been replaced
                                • touchbar would "strobe"
                                I disconnected touch bar components and strobing and sudden shutdowns were fixed. Recent updates were installed to the OS.
                                After fully charging the battery, with bluetooth disabled, no LAN cable and only wifi enabled, the laptop stayed on (screen on) for about 6-8 hours. Allowing screen to turn off while not in use, and it went for over a day.
                                BUT
                                When powered off, it would at some point have a...
                                01-27-2025, 09:12 AM
