Lenovo T570 not turn on
  • arber1232
    • Dec 2019
    • 372
    • Albania
    hello I have a lenovo t570 laptop that has water on board. I cleaned the board well with solutions for the board, dried it well and tried to turn it on, but it didn't turn on. I made some measurements 20v is the voltage in dc in and in the first mosfet I miss VSYS 3.3v and 5v
    Laptop have 2 dcin i use type c charger i try and lenovo charger with with a yellow head
    THIS IS SHCEMATIC
    [Mod. Edit-Vesko356] Schematic: https://www.badcaps.net/forum/showthread.php?t=118676
    Last edited by Vesko356; 05-02-2023, 09:50 AM. Reason: Attached schematic removed and replaced with link.
  • mon2
    • Dec 2019
    • 14246
    Re: Lenovo T570 not turn on
    Check the voltage to ground of PU7301:
    pin #1 (VBUS)
    pin #2 (ACN)
    pin #3 (ACP)
    pin #4 (CHRG_OK)
    pin #28 (REGN)
    • arber1232
      • Dec 2019
      • 372
      • Albania
      pin #1 (VBUS)=20.23v
      pin #2 (ACN)=20.23v
      pin #3 (ACP)=0v
      pin #4 (CHRG_OK)=0v
      pin #28 (REGN)=6v
      • mon2
        • Dec 2019
        • 14246
        pin #3 (ACP)=0v
        Confirm this voltage to ground measurement. It should not be 0v unless there is a trace break or a resistor is missing between pin #3 of the charger IC and the current sense resistor @ PR7320 (pin #1).
        To check the resistance, remove all power -> meter in resistance mode (lowest scale).
        Measure the resistance with one probe @ pin #3 of the charger IC; other meter probe @ pin #1 of PR7320. If you do not see a low resistance (~10 ohms), there is a fault in this trace.
        • arber1232
          • Dec 2019
          • 372
          • Albania
          yes is 10 ohms
          • mon2
            • Dec 2019
            • 14246
            Then the voltage on pin #3 should not be 0 volts -> confirm it. Should be the same voltage as the ACN pin.
            • arber1232
              • Dec 2019
              • 372
              • Albania
              I measured it now with a device with thinner pins and the voltage is 20v
              • mon2
                • Dec 2019
                • 14246
                Measure the voltage to ground of VSYS (pin #22) on the charger IC.
                Measure the voltage to ground of RTCVCC.
                • arber1232
                  • Dec 2019
                  • 372
                  • Albania
                  i see in this place is not normaly can you confirm it ?
                  • arber1232
                    • Dec 2019
                    • 372
                    • Albania
                    VSYS 12.36v
                    RTCVCC 3v is battery bios ?
                    • mon2
                      • Dec 2019
                      • 14246
                      The mosfet is a P-channel so this means that the gate voltage must be lower than the voltage being passed between the source / drain pins to ENABLE.
                      Since gate voltage is the same, this mosfet is OFF.
                      Take a piece of wire and connect one side to pin # 4 (only) = GATE. Other side of the wire to ground on the logic board.
                      This act will force this P-channel mosfet to turn ON.
                      Test it.
                      • arber1232
                        • Dec 2019
                        • 372
                        • Albania
                        yes it true mosfet enable
                        • arber1232
                          • Dec 2019
                          • 372
                          • Albania
                          in Pu7501 VIN vsys is missing
                          • mon2
                            • Dec 2019
                            • 14246
                            Have you tried the ground wire on gate pin #4 of PQ7308?
                            • arber1232
                              • Dec 2019
                              • 372
                              • Albania
                              yes i try and mosfet enable now in Pu7501 i have
                              Vin=12,3v
                              Vreg3=3,3v
                              vreg6=5v
                              In power button i not have 3,3v
                              • mon2
                                • Dec 2019
                                • 14246
                                Check the voltage to ground on both sides of the fuse F2607 which is used to power the power switch board.
                                • arber1232
                                  • Dec 2019
                                  • 372
                                  • Albania
                                  is ov in both side
                                  • mon2
                                    • Dec 2019
                                    • 14246
                                    VCC3M is created by PU7501.
                                    Remove all power. Meter in resistance mode.
                                    Check the resistance to ground of VCC3M at PL7502.
                                    What is the resistance?
                                    Next, meter in voltage mode. Check the voltage to ground of the EN1 and then EN2 pin of pu7501. Each pin is used to enable the local power rails. We are checking to see if the power rail is being instructed to turn on or not.
                                    • arber1232
                                      • Dec 2019
                                      • 372
                                      • Albania
                                      Risistance in Pl502 is 5,4 kohms
                                      EN1=0.025 v
                                      En2=0,025 v
                                      • mon2
                                        • Dec 2019
                                        • 14246
                                        Confirm the power rails of the KBC component that is used to enable the above power rails.
                                          Lenovo ThinkPad T570 Notebook T Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad T570 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T570 boardview and T570 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                                          09-06-2024, 06:08 AM
                                          09-06-2024, 09:12 AM
                                          09-06-2024, 08:40 AM
                                          09-06-2024, 08:35 AM
