820-3115 no post
  • Bizb9l21
    • Jan 2023
    • 26
    • Usa
    820-3115 no post
    Hey all,
    I have a 820-3115-b that was worked on, I have no history for it .
    Found a lot of flux by the keyboard ic and EFI chip was definitely removed and resoldered.
    It powers on , fan spin , green light, won't beep without ram .
    Did SMC reset, did pram ,no visible water damage.
    Removed EFI chip , made a backup and worth chip with good working bios of same exact model board.
    Got a file with clean ME from some other thread here at badcaps but still same result.
    Any ideas where I can start diagnosing this issue?
  • mon2
    • Dec 2019
    • 14101
    Re: 820-3115 no post
    What is the voltage to ground of PPBUS_G3H (F7040) ?
    • Bizb9l21
      • Jan 2023
      • 26
      • Usa
      Hey , it's 11.40v
      • mon2
        • Dec 2019
        • 14101
        What is the voltage to ground of PP3V42_G3H ?
        The PPBUS_G3H a low voltage.
        Remove fuse @ F7040 and measure again at the ISL side (producer).
        reference:
        https://www.logi.wiki/index.php/Powe..._List#820-3115
        • piernov
          • Jan 2016
          • 4435
          • France
          Machine is in S0 state, relevant power rails must be measured not random things.
          • Bizb9l21
            • Jan 2023
            • 26
            • Usa
            Thank you guys for your help, is there a weather fall flow I can follow to check voltage across rails and report back to you ?
            Can it still be a bad ME that needs cleaning that is putting this board in this state and pulling the voltage down?
            • leovalpo
              • May 2014
              • 12
              • chile
              measure the ground resistance of the rails (red probe of the multimeter grounded to ground and the common probe reads the component), in the list attached as an image is the voltage reference value.
              • acedogblast
                by acedogblast
                11-02-2024, 05:13 PM
                by SMDFlea
                Bad...
                09-02-2021, 04:40 PM
              • BMCappelletti
                Asus Chromebox CN62 - wrong chip put on BIOS reader
                by BMCappelletti
                Long story short:
                - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                - gave the computer to his son a couple years later
                - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                (seems like the story was not that short)
                He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                01-08-2025, 07:27 PM
              • Troystain
                Help EZP2023+ updated chip database for w25q256jveq?
                by Troystain
                Hello, anyone here have updated ezp2023+ chip database in .dat file format.
                I need to add w25q256jveq chip but I do not know what data should I type.
                I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
                The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....
                11-25-2024, 12:53 AM
              • inck243
                Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
                by inck243
                Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
                The BIOS...
                07-25-2024, 09:17 AM
