820-3115 no post
  • Bizb9l21
    • Jan 2023
    • 26
    • Usa
    820-3115 no post
    Hey all,
    I have a 820-3115-b that was worked on, I have no history for it .
    Found a lot of flux by the keyboard ic and EFI chip was definitely removed and resoldered.
    It powers on , fan spin , green light, won't beep without ram .
    Did SMC reset, did pram ,no visible water damage.
    Removed EFI chip , made a backup and worth chip with good working bios of same exact model board.
    Got a file with clean ME from some other thread here at badcaps but still same result.
    Any ideas where I can start diagnosing this issue?
  • mon2
    • Dec 2019
    • 14659
    Re: 820-3115 no post
    What is the voltage to ground of PPBUS_G3H (F7040) ?
    • Bizb9l21
      • Jan 2023
      • 26
      • Usa
      Hey , it's 11.40v
      • mon2
        • Dec 2019
        • 14659
        What is the voltage to ground of PP3V42_G3H ?
        The PPBUS_G3H a low voltage.
        Remove fuse @ F7040 and measure again at the ISL side (producer).
        reference:
        https://www.logi.wiki/index.php/Powe..._List#820-3115
        • piernov
          • Jan 2016
          • 4439
          • France
          Machine is in S0 state, relevant power rails must be measured not random things.
          • Bizb9l21
            • Jan 2023
            • 26
            • Usa
            Thank you guys for your help, is there a weather fall flow I can follow to check voltage across rails and report back to you ?
            Can it still be a bad ME that needs cleaning that is putting this board in this state and pulling the voltage down?
            • leovalpo
              • May 2014
              • 18
              • chile
              measure the ground resistance of the rails (red probe of the multimeter grounded to ground and the common probe reads the component), in the list attached as an image is the voltage reference value.
