Hi everyone, how are you, I need your help, I have a repair acer model Z8v x16, power issue, if I press the power button the power LED comes, fan turning but then stop, but power LED still on, 19v, 5v, 3v, 1.2., 1.0v, 1.8v are present. thank you in advance
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
Assuming...7 Photos -
by pilgrimageHello, my laptop was working smoothly, I was getting images via hdmi via the monitor. I ordered a new lcd panel because the LCD screen was broken. After replacing the LCD screen, when I wanted to turn on my laptop, my laptop was dead. Currently, there is no power, no light, no reaction on the laptop, do you think that in this case, could the GPU or CPU of my laptop be burnt? I read in some forums that this kind of error can occur if the LCD screen is replaced while the battery is installed. Unfortunately, when I replaced the LCD panel, my laptop was completely turned off but the battery was installed....
by claws77my laptop has a weird power-on issue.
Once the laptop has been powered on, it can restart/ wake just fine on battery power or Adapter, ONLY If i have not closed the LCD.
If i am running on battery and have closed the LCD (even momentarily). it will not power-on/ wake-up on battery power no matter the battery percentage.
but once i open the LCD and connect it to the adapter (even momentarily) it will wake up gain and I wont experience any issues till i close the LCD.
i do not know where to look for repair.
thank you all for any advice. -
by claws77hi guys, my motherboard will not start no matter what
when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
but rest nothing happens no sign of life.
this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
but now nothing happens no matter how much i wait/ charge/ press and hold power button.
i have no knowledge of motherboards ....10-20-2024, 02:48 PM - Loading...
