Acer Nitro 5 AN515-55-55M1 [GH51G mb] powers on, no vcc_core
  • malogro
    • Mar 2023
    • 31
    Hello all,
    I'm stumped on this guy, so wanted to see if anyone has any further ideas:
    Intro:
    This is an Acer Nitro 5 AN515-55-55M1 with unknown prior history (bought "as-is" on eBay). It charges the battery and powers on from both AC adapter and battery, so I think this rules out main power issues.
    Upon attempt to boot, it will "reboot" (meaning powers down and then powers on again) only once, and then stays stuck in a status of lights on / no post / no monitor. Powering on with fn+esc maxes out the fans on first boot attempt, but once it powers down and on again (on its own), fans go back to normal despite holding fn+esc.
    All peripherals were tested in another laptop and are known good (keyboard / LCD / RAM / battery / AC adapter).
    Edit because I forgot: Visual inspection shows nothing, board appears brand new.
    Testing:
    I began by testing the main power rails:
    19_IN: There and good (19V with adapter)
    5VALW: There and good (5V)
    3VALW: There and good (3.3V)
    1.8VS: There and good (1.8V)
    1.2V_VDDQ: There and good (1.2V)
    EC_RSMRST#: There and good (3.3V) <- I'm assuming that's correct
    PCH_PWROK: There and good (3.3V)
    SYS_PWROK: There and good (3.3V) <- That one puzzles me.
    The main suspect:
    Upon testing VCC_CORE and VCC_GT (cooler off), VCC_GT is there (0.8V or thereabouts), but VCC_CORE is not. I recall measuring around 1.8V on good laptops (measured on PUH2-5), or at least something. Does not appear to be a short either, as resistance to ground measures ~20ohms. CPU does get hot, so that's weird to me as well.
    I have no idea what to use to debug further. Schematic shows PUH2-5 are responsible for that VCC_CORE (I think?).
    My next step was to replace PUZ1 from a donor board (I think that's the CPU VCC_CORE controller), but I stopped myself since I do not like to just throw parts at a problem. Is there anything else I can do to debug why that voltage isn't coming on? My only other idea is BIOS issue...
    Thank you!
    Last edited by malogro; 04-14-2023, 04:45 PM. Reason: Forgot to add visual inspection.
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Re: Acer Nitro 5 AN515-55-55M1 [GH51G mb] powers on, no vcc_core
    Originally posted by malogro
    Hello all,
    Intro:
    Testing:
    The main suspect:
    Thank you!
    Wait for other comments but , try to request a new clean me bios of your board on the BIOS request section maybe that will help.just a suggestion
    • malogro
      • Mar 2023
      • 31
      Thanks! Yeah may want to try that as well, but need to get a flasher first...
      • kalilinux25
        • Mar 2018
        • 2089
        • ZAMBOANGA SIBUGAY
        also please always have a complete details of your board and drop the schematic here.
        • malogro
          • Mar 2023
          • 31
          Ah, yes. It's a GH51G LA-L181P Rev 1A.
          https://www.badcaps.net/forum/showthread.php?t=110980
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            +VCC_SA present?
            • malogro
              • Mar 2023
              • 31
              I'm assuming it's the one measured at PLG101. If so, yes, present at 1.8V.
              EDIT: Sorry, never mind, schematic actually says PLA1. Trying to locate it now...
              • malogro
                • Mar 2023
                • 31
                Couldn't quite find VCC_SA. Closest I could find was VCC_AUX, which is the one on PLG101, which is present at 1.8V. If that's not the one, would you point me towards where I can find that signal?
                • Stevedb
                  Stevedb
                  • Feb 2018
                  • 624
                  • Belgium
                  Does the capslock toggle on external keyboard. That is sign that the board is posting if not i would go for cleaning first your original bios.
                  • malogro
                    • Mar 2023
                    • 31
                    It does not light up on external or embedded keyboard. I will get ahold of a flasher and try reflashing the BIOS.
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      Yes, strange.Schematic does mention VCCIO/VCC_SA but doesnt lead anywhere.
                      • malogro
                        • Mar 2023
                        • 31
                        Update: BIOS was reflashed to ME clean. Same exact symptoms.
                        It DOES write to BIOS (I read back from it to see if it had changed), which I think is a good sign. But still no POST (CAPS LOCK test still negative).
                        My next idea would be to go for broke and replace PUZ1 or inject ~1.8V directly to VCC_CORE to see if any signs of life, but suggestions are appreciated.
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          Dont play with voltage injection without finding the fault. AFAIK,VCC core should be approx 1V on this platform.
                          • piernov
                            • Jan 2016
                            • 4435
                            • France
                            I'm a bit confused here since VCC_GT should not exist on this platform. Ice Lake/Tiger Lake has FIVR so single rail (VCCIN) from motherboard to CPU for all the core logic including CPU VCore and iGPU VCore, and another rail (VCCIN_AUX) for the auxiliary logic. Some other rails also feed the CPU for memory, I/O and standby operation.
                            According to Intel's datasheet, VCCIN_AUX should be 1.8V.
                            VCCIN is not specified since it's controlled by SVID but I'd guess it's a bit higher that the usual VCore, maybe similar to Haswell/Broadwell.
                            As usual though, VCCIN will be absent if CPU auxiliary circuits do not initialize and there is no SVID communication.
                            • malogro
                              • Mar 2023
                              • 31
                              Ah, ok, let me clarify. What I mentioned as VCC_GT is actually the graphics card core (NVVDD), so my bad there.
                              So VCCIN is missing, because something is not initializing correctly then. Is there any sort of checklist I can go through to see what is failing?
                              • eenee
                                • Aug 2022
                                • 48
                                • Mongolia
                                Have you found a solution for this motherboard? I seem to have the same symptoms as yours.
                                • malogro
                                  • Mar 2023
                                  • 31
                                  Following up as I just saw I never did. The issue on that motherboard was the PCH. Once I lifted the PCH, there were several traces that were ripped. As said, some aux circuits have to properly initialize and they weren't.
                                  Replacing the PCH / traces should do the trick.
                                    ACER NITRO Nitro N50-600 NITRO 50 i7-9700 Specification for Upgrade or Repair
                                    This specification for the ACER NITRO Nitro N50-600 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the NITRO Nitro N50-600 boardview and NITRO Nitro N50-600 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                    09-12-2024, 03:28 PM
                                    ACER NITRO Nitro GX50-600 NITRO 50 i5-8400 Specification for Upgrade or Repair
                                    This specification for the ACER NITRO Nitro GX50-600 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the NITRO Nitro GX50-600 boardview and NITRO Nitro GX50-600 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                    Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                    This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                    09-07-2024, 04:10 AM
                                    Acer Nitro Nitro 5 AN515-57-775V Notebook 5 Specification for Upgrade or Repair
                                    This specification for the Acer Nitro Nitro 5 AN515-57-775V Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-57-775V boardview and Nitro 5 AN515-57-775V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                    Acer Nitro Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i5-11400H, 8GB, 512GB SSD, NVIDIA RTX 3050Ti, Full HD 144Hz, Windows 10, Black) Notebook 5 Specification for Upgrade or Repair
                                    This specification for the Acer Nitro Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i5-11400H, 8GB, 512GB SSD, NVIDIA RTX 3050Ti, Full HD 144Hz, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i5-11400H, 8GB, 512GB SSD, NVIDIA RTX 3050Ti, Full HD 144Hz, Windows 10, Black) boardview and Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i5-11400H, 8GB, 512GB SSD, NVIDIA RTX 3050Ti,...
                                    09-07-2024, 03:10 AM
