A1466 820-000165-A with low PP3v42
  • bridges_4u
    • Feb 2014
    • 105
    • india
    I have got an 820-000165-A motherboard which has got a strange problem. I have 14.32 V at R7005. But when i check pin2 of D7005, it says 0.9V. The diode is OK. Tried changing U7090 too. Any clues?
  • mon2
    • Dec 2019
    • 13962
    Re: A1466 820-000165-A with low PP3v42
    Remove all power. Meter in resistance mode.
    Check the resistance across R7005. Is it ~10 ohms and stable?
    Sounds like R7005 is defective or power path is broken.
    • bridges_4u
      • Feb 2014
      • 105
      • india
      Hi mon2,
      I am happy that I got to talk to you again. I have continuity between pin 2 of D7005 and R7005. Yep. The value of R7005 is 10 Ohms.
      • mon2
        • Dec 2019
        • 13962
        Remove d7005. Measure the voltage again at pcb pad #2 of the removed d7005 diode.
        • bridges_4u
          • Feb 2014
          • 105
          • india
          It is 0.9V.
          • mon2
            • Dec 2019
            • 13962
            R7005 is defective. Replace it and then check the voltage to ground again at pin #2 of the D7005 PCB pad.
            Do not solder back D7005 till this voltage returns to be the same as the voltage into R7005.
            • bridges_4u
              • Feb 2014
              • 105
              • india
              Hi mon2,
              I replaced R7005. Now I get 14.2v at D7005. But when I check L7095 it shows only 0.160v instead of 3.425v. There is no short on ground at either side of L7095. On pin2 of U7090 i get 0.160v. I replaced u7090 twice, same results.
              • mon2
                • Dec 2019
                • 13962
                The fault is (common) and at the input side of U7090. Very likely you have a shorted capacitor which killed the diode / R7005 network.
                1) Check the voltage at the input of this regulator (Pin # 6) of U7090.
                2) Remove all power -> meter in resistance mode -> check the resistance to ground of pin #6 on U7090.
                Likely the input bulk cap is defective and causing a short circuit. Review the input caps.
                Remove each till the short is gone.
                • bridges_4u
                  • Feb 2014
                  • 105
                  • india
                  Hi mon2,
                  Sure. Will do. Moreover, I had voltage fluctuating at L7095 before this occurred. Can u suggest as to why that could have happened.
                  • bridges_4u
                    • Feb 2014
                    • 105
                    • india
                    Hi mon2,
                    When i try to check the resistance to gnd on pin6 of U7090, it is jumping all over the place. It initially shows Mohms, moves down to KOhms, and then Ohms. Then cycles all the way back. Would that be due to the shorted caps?
                    • mon2
                      • Dec 2019
                      • 13962
                      Yes.
                      Remove each of the 3 caps and confirm that the resistance is stable. Someone is shorted inside this group of parts.
                      • bridges_4u
                        • Feb 2014
                        • 105
                        • india
                        Hi mon2,
                        After all the caps, when checking the resistance to gnd, it is fluctuating between kOhms and Mohms steadily. Once i put in only C7090, it fluctuates between all the way like before.
                        • mon2
                          • Dec 2019
                          • 13962
                          Ok so C7090 is the bad boy in the picture. It is defective. Locate a replacement.
                          Then proceed to measure the voltage to ground of this input side WITHOUT the defective C7090. Once this rail returns to a normal value which should be ~adapter voltage, the output of this regulator should be the expected value.
                          Confirm it and update this thread.
                          • bridges_4u
                            • Feb 2014
                            • 105
                            • india
                            Hi mon2,
                            Just to add to this pile, if I insert only C7092, then the same scenario when C7090 was inserted happens. Does it mean that C7092 is also kaput.? What can you advise about the KOhm - Mohm fluctuations without the 3 caps?
                            • mon2
                              • Dec 2019
                              • 13962
                              Kohms and higher is ok. The input side should not be hundreds of ohms or lower. If a cap brings down the line, skip using it.
                              The capacitance value of the cap is not critical but is required. The voltage rating is very important. Should be 20v or higher to be safe.
                              • bridges_4u
                                • Feb 2014
                                • 105
                                • india
                                Hi mon2,
                                Just a quickie. If C7090 is defective, shouldn't it show continuity when checked with a multimeter. In this case, it does not.
                                • mon2
                                  • Dec 2019
                                  • 13962
                                  a defective cap can also be of a low resistance but not fully shorted. If the resistance is low enough, the diode will be unable to support the load and the Vin voltage will sink. If the voltage sinks, the output will as well.
                                  • bridges_4u
                                    • Feb 2014
                                    • 105
                                    • india
                                    Hi mon2,
                                    I removed C7090 and inserted C7092. Now if i check resistance to gnd on that line, I could see resistance slowly building up in the KOhms and growing higher which leads me to believe that C7090 & C7091 are the culprits. What do you say?
                                    • mon2
                                      • Dec 2019
                                      • 13962
                                      Yes, it is possible. Power it up to see if the Vin remains high.
                                      • bridges_4u
                                        • Feb 2014
                                        • 105
                                        • india
                                        Hi mon2,
                                        Just to be on the same page. Would you like to power it up without C7090 & C7091.
                                        • psdavid65
                                          A1466 820-3437-B Bios Problem
                                          by psdavid65
                                          I received a 2013 Macbook Air A1466 A1466 820-3437-B motherboard WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?
                                          06-18-2024, 05:26 AM
                                        • Sergio Kub
                                          MAcbook Air A1466 EMC 3178 - 2017 Boot
                                          by Sergio Kub
                                          Could someone help me?
                                          I have a Macbook Air A1466 EMC 3178 - 2017, board 820-00165 and sometimes the boot interrupts with an image of a folder and a question mark.
                                          Could it be the BIOS?
                                          07-08-2025, 04:41 PM
                                        • Sergio Kub
                                          Macbook Air A1466 EMC 3178 - 2017 Boot
                                          by Sergio Kub
                                          07-08-2025, 04:12 PM
                                        • myth77
                                          A1369 and A1466 top case housing the same?
                                          by myth77
                                          I didnt know where to ask (on what topic) but does anyone know can i use macbook air A1369 TOP CASE (with or without palmrest and keyboard) on A1466? they look the same but i am not sure. On aliexpress they sell them as same but on some places they sell only a1466 for a1466. anybody knows? Maybe the case/housing is the same but keyboard and touchpad different? but if thats the case i would change them..
                                          08-06-2022, 10:06 AM
                                        • dbuergi
                                          Need assistance for reballing / replacing i5 CPU on a Macbook A1466
                                          by dbuergi
                                          i have some A1466 logicboards for gaining soldering and electronic experience. One board has a dead CPU and since i have several spares i want to change it. Unsoldering it was no problem but heat from the top showed that the CPU bent. I think too much heat was the problem.
                                          So for unsoldering my spare parts and soldering back i would ask for some advises.
                                          On most youtube videos you don't get any temperatures. Only helpfull video was one where the heat came from the bottom.
                                          I have a small USB heating plate and a Atten ST-862D with several nozles.
                                          06-27-2025, 02:59 AM
