HP ProBook 440 G3 not charging
  • vpower
    • Sep 2022
    • 116
    • italy
    I have this ProBook that suddenly stopped charging.
    This is what happens:
    The laptop will only power on when both battery and charger are plugged. But no battery charging icon. As soon as I unplug charging cable, it will power off.
    If battery is removed, the laptop will not power on, even with the charger connected.
    This is the voltage reading on battery connector pins with both battery and charger connected, from left to right:
    pin 1&2 gnd
    pin 3 0v
    pin 4 0v (seems not connected,no wire)
    pin 5 3.3v
    pin 6 3.3v
    pin 7&8 0.2v
    any suggestion?
    thanks in advance
  • mon2
    • Dec 2019
    • 14660
    Re: HP ProBook 440 G3 not charging
    Locate the charger IC. Meter in dc volts 30v or higher scale is ok.
    Carefully measure the voltage to ground of each pin on the charger IC.
    Post the measurements with the pin # of the IC.
    • vpower
      • Sep 2022
      • 116
      • italy
      Thank you.
      Do you mean this 52-pin PU2 ic?
      • vpower
        • Sep 2022
        • 116
        • italy
        I think you refer to PU1 ic BQ24780RUYR..right?
        I will measure all the 28 pins voltage. Do I need to have both charger and battery connected? Or only charger is enough?
        • mon2
          • Dec 2019
          • 14660
          Yes, PU1. Remove the battery and start with measuring voltage to ground with only the power adapter.
          Meter in 30v or higher DC volts scale. Measure the voltage to ground for each pin.
          Post your measurements with pin #.
          • harp
            • Jun 2022
            • 642
            • Planet Earth
            Originally posted by vpower
            pin 1&2 gnd
            pin 3 0v
            pin 5 3.3v
            pin 6 3.3v
            pin 7&8 0.2v
            If is your battery connector fully and corectly plugged in, I think that you have locked battery controler inside battery, maybe overdischarged few cells or burn fuse.
            That the laptop wont start without battey is modern bs, maybe is only dumb suspend with sense pin pulled to gnd...? Unplug battery and power up laptop and measure voltage on each pin again -> compare with previous data. If you measure say 3v on pin#3, you can try to pull it down with some small value resistor to 0v and see if it power up.
            • flat-earther
              how to prevent a connected charger from draining battery when not charging?
              by flat-earther
              I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
              So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
              but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
              So the battery is backfeeding the charger and being drained.
              How can I prevent...
              08-07-2025, 01:04 PM
            • Bowline
              by Bowline
              06-11-2025, 10:13 AM
              NVDC charger configuration...
              11-05-2024, 03:28 PM
              Bauer tool battery pack charging with a HERCULES charger modification
              by sam_sam_sam
              The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
              Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
              05-06-2023, 12:17 PM
            • serious_electron
              Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
              by serious_electron
              Hello Everyone!
              I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
              06-28-2025, 02:57 PM
