820-00239 Macbook Pro SSD not detected
  • RepairhouseAB
    • Jan 2022
    • Sweden
    I have a Macbook pro 2017 (820-00239) that dosent detect the SSD.
    It's no water damage, just stopped working. Read the lines between C9402, R9350 and C9401 are weak spots so I did jumpers, just to make sure. No difference. Have checked for short on sourrounding components but not find anything.
    Any ideas how I can continue? Thanks
  • mon2
    • 14657
    Re: 820-00239 Macbook Pro SSD not detected
    https://boards.rossmanngroup.com/thr...etected.61390/
    • envym
      by envym
      Hi everyone!
      06-27-2025, 08:54 AM
    • bibinskii
      Macbook Pro M1 (A2338) - Not Charging but Detected and Post
      by bibinskii
      A client showed up with a Macbook Pro M1 stating that the battery doesn't get charged (no increase in percentage) but still charge. She left me with the battery 25% and still draining. The Macbook is fully functional. I checked with coconut battery and system report. Battery health shows 85% and stating normal condition, no abnormalities. When it is charging, the system says it takes 10 hour to finish charging. I went ahead to charge it for a longer period, the battery just drains (doesn't get charged).
      At first, I thought that this must be a battery issue. I went to replace the battery....
      07-22-2024, 12:22 AM
    • Flasman90
      Macbook Pro DFU Restore Issues
      by Flasman90
      I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
      - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
      - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
      08-30-2025, 10:27 AM
    • tobeend
      Bypass mdm macbook m2 ventura
      by tobeend
      1. RESET MACOS WITH IPSW
      a. Power off MacBook, press and hold the power button to enter Recovery
      b. Open Disk Utility, remove Macintosh HD
      c. Reboot, connect to the network to Activate Mac.
      d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
      d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
      e. Release the other keys, but keep holding the Power key for another 10 seconds
      f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
      05-26-2023, 07:18 AM
    • salim5566
      Macbook A1708 EMC3164 battery not detected laptop on when power cable in
      by salim5566
      HI everyone i have strange problem i have macbook A1708 battery not detected
      i have change new battery still same, when i plug charger in to laptop it can turn on soon as i take out cable macbook turn off. anyone knows how do i solve this problem?
      thanks
      07-15-2022, 07:37 PM
