A2159 821-00583A Macbook Pro short
  • Fredfree
    • Mar 2023
    Hello everyone. This is my first post and I am hoping to learn from the experts that help out. My daughter had a HDMI dongle connected to the laptop and when she went to disconnect a static shock went through her and to the Usb port. The computer shut down and would not start. She took it to the authorized repair at London Drugs and they charged her $70 and told her the logic board would need to be replaced for $1000 +.
    I removed the logic board and connected to Usb digital tester and it reads
    5.17 volts
    .48 amps
    Stuck there and not going any further.
    Checked power pbus 4.54v
    Checked power pp3v3_g3h_rtc 0 volts
    Checked pp3v3_g3h_rtc to ground and it is shorted.
    Noticed U3200 (CD3217) very hot
    U3100 not hot
    Can someone please advise me the next step?
    Thankyou
  • mon2
    • 14003
    Re: A2159 821-00583A Macbook Pro short
    London drugs??? Seriously?
    If the cd3217 is hot then likely it is defective. From the logiwiki / repair wiki / Scriptures by @Piernov, check the voltage to ground of the LDO rails on the cd3217 that is getting hot. It may need to be replaced.
    The cd3217 devices are available from AliExpress in Shenzhen, China. Try Exinra or similar. Post the link of the vendor before buying.
    Next ppbus is too low.
    This rail is a buck boost regulator. It should boost the voltage when 5 volts on the external power adapter is present.
    It should lower (buck) mode the voltage when the cd3217 finally negotiates a 20v contract from the adapter.
    Each cd3217 (aka ACE controller) must be functional before 20v can be selected. The hot ace controller is probably causing the logic board to fail.
    Remove all power. Meter in resistance mode.
    Measure the resistance to ground of the ppbus_g3h rail or whatever it is called in this logic board.
    Likely driven by the isl9240 regulator. I can check after wolfing a late dinner and some law and order.
    Would you have air tools? Tweezers? Or access to someone with such equipment?
    • Fredfree
      • Mar 2023
      Thanks for the quick reply.
      LDO rail 1.01 vdc to ground
      ppbus_g3h open no short
      I will order a couple cd3217 and a hot air station, flux and paste. Looks like a tricky one for a first timer. I have soldered with an iron alot but not with hot air. I will practice and post when I have the cd3217 removed and check for short.
      • mon2
        • 14003
        Very good.
        When shopping for the ACE controllers, CD3217 part, do inform the vendor on the logic board you will use.
        For the hot air tool, get one that can support the higher heat as the pcb is a multilayer one with ground plane. We use the Best 863 but likely there are more advanced models by now.
        Also consider to pick up the paste stencil for the cd3217 and a fixture so that you can reball the bga device, if required. Do watch YouTube videos on reballing bga devices.
        Do practice on other pcbs. Some techs prefer to pull the cd3217 from a donor board of the same model.
        Keep note of the bga chip orientation.
        The cd3217 has multiple LDO rails, check each to confirm that each is working.
        • reformatt
          • Feb 2020
          • 1400
          Two potential issues. One is getting a couple of CD3217 that aren't fake, and second, these may be underfilled. The latter isn't something to do for a first timer doing BGA rework. Suggest you take it to someone with a bit more experience if you're not comfortable with it.
          • Fredfree
            • Mar 2023
            https://www.aliexpress.com/item/1005...677054512%21sh
            https://www.aliexpress.com/item/1005...d=nw2yoEO9RbTM
            https://m.aliexpress.com/item/100500...2-e19d62594b8d
            • Adogabriel100
              where to get trusted CD3217. Problem with A2337 Macbook Air
              by Adogabriel100
              Hey! As the title says. i don't know if this is the right place to ask but i need to get trusted USB C Controllers (CD3217-CD3215) For macs and dont know where to get them. i dont know if you guys know where is a good place to get it.
              The thing is that i have a Macbook air A2337 M1 and i dont have a donnor board to get the CD3217. So i try the CD3217 from a A2141 Board and at first, whitout his eprom it does not convert 5v to 20v. then i put the original CD3217 eprom from the A2141 and then the macbook A2337 conver the 5v to 20v but still not turning on. i guess that the CD3217 is...
              09-06-2024, 12:06 PM
            • Stephen
              MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
              by Stephen
              I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
              02-06-2025, 12:03 PM
            • sdogs
              macbook pro M1 a2338 no video on internal display PP3V3_S2 short
              by sdogs
              Greetings to the entire forum, I ask you for help because I'm going crazy. A dear friend of mine gave me a macbook pro M1 A2338 that only works with an external screen. With the internal one, no backlight or image. Only the external display is detected from the system settings.
              First I changed the display flat, then I made a backup with time machine and tried a reset in dfu but nothing to do, always the same problem.
              I analyzed the logic board, it shows no sign of liquid or visible damage. I then moved on to examine the logic with the thermal camera and found that the UP701 chip was...
              06-27-2025, 01:58 PM
            • sdogs
              by sdogs
              06-27-2025, 11:26 AM
            • TechSplendid
              MacBook A2442 not powering on – suspecting CD3217, but replacement didn’t help
              by TechSplendid
              Hi All,
              I'm working on a MacBook Pro A2442 (14", 2021) that's not powering on. On two out of three USB-C ports, I get 5V and the current briefly ramps up to around 0.210A before dropping to 0.036A. On the third port (JF600), I only get 0.0045A and it stays there.
              Initially, I suspected a faulty CD3217 on that port, especially since I noticed signs of previous liquid damage near the JF600 USB connector. I replaced the CD3217 with an UF400 (from an A2442 donor board from the same location). According to the supplier, this should be a compatible version, but the behavior...
              04-09-2025, 02:13 AM
