Asus Model G501j , Board N501jw short at AC_BAT_SYS
  • Sephir0th
    • Oct 2020
    • 1283
    Re: Asus Model G501j , Board N501jw short at AC_BAT_SYS
    Originally posted by TheWizard
    Going to probe around and check the 1.05v rail like Reformatt suggested. Got side tracked yesterday. Will post results. But the rail i was checking below that i found the short on is posted below. There is a controller chip on that rail. I will be checking that today for restistance to ground.
    P_VCORE_VSP_10 - *Shorted*
    1. PC8012
    2. PC8055
    3. PR8051
    4. PSL8006
    5. PU8000
    Picture of the area in question please where you measured the "short". I don't like to drive in circles...
    FairRepair on YouTube
    • TheWizard
      • Feb 2015
      • 190
      Yeah sure thing. Totally understandable. Otherwise we are just at a Nascar race. Drive fast turn left! Haha Here is a pic of the shorted area. Thanks again.
      • TheWizard
        • Feb 2015
        • 190
        1.05VS rail:
        R2706, R2539 R0614,R0313,Q7702,PJP8201,PJP8202 all continious to ground. But resistance to ground is higher from components on the front side of board rather than the back side. Can i inject voltage with the ITE off or that too dangerous for the CPU?
        • Sephir0th
          • Oct 2020
          • 1283
          i finally realized you refer to the boardview without mentioning it. So now i want to understand why you randomly measured Pin 34 of the VRM controller without any reason? And when you do so, always share EXACT resistance to GND. Except you like, when the people here have to ask again, again and again.
          So what value did you find at VCCSENSE Pin...?
          Edit: Same for the +1.05VS rail ofc.
          • TheWizard
            • Feb 2015
            • 190
            My appologies. I am new to this. Not trying to cause headaches. Yes, i use the boardview. Because you cant rely much on the schematic for this board. The VRM controller measurement was probably because i didnt know the name of the rail i needed so i just searched boardview for P_VCORE.
            VCCSENSE on PSL8006 shows 32.9 reisistance to ground.
            1.05VS Rail:
            JP2603 = 0.7
            PJP8201 = 0.6
            PJP8202 = 0.6
            PT8201 = 0.6
            PT8202 = 0.6
            PT8203 = 0.8
            Q7702 = 0.5
            R0313 = 1.0
            R0350 = 1.0
            R0612 = 0.8
            R0614 = 0.5
            R2539 = 0.6
            R2601 = 0.7
            R2602 = 0.7
            R2603 = 0.7
            R2702 = 0.6
            R2704 = 0.6
            R2706 = 0.7
            R2707 = 0.6
            R2712 = 0.6
            R2713 = 0.6
            R2714 = 0.7
            R2720 = 0.5
            R2727 = 0.6
            R2728 = 0.9
            R5707 = 0.7
            U2001 = GPU
            • Sephir0th
              • Oct 2020
              • 1283
              So still, CPU Core rail and VCCSENSE measures absolutely fine and not(!) Shorted. This low values there are absolutely normal.
              Meanwhile the +1.05V is shorted to GND. Lift the related coil from at least one pad and share on which side the short persists.
              • TheWizard
                • Feb 2015
                • 190
                I don't see a coil with 1.05v attached on either one of its pins. Can you point me in the right direction?
                • Sephir0th
                  • Oct 2020
                  • 1283
                  PL8200
                  Check resistance to GND there (any pad) again before lifting, to confirm
                  • TheWizard
                    • Feb 2015
                    • 190
                    PL8200
                    Okay PL8200
                    Pin 1 = Constant pulsing
                    Pin 2 = 0.8
                    Removed coil.
                    Pin 1 = 2.761
                    Pin 2 = 2.7
                    • Sephir0th
                      • Oct 2020
                      • 1283
                      And now we want to inject 1V into pin2 to confirm a shorted PCH.
                      • TheWizard
                        • Feb 2015
                        • 190
                        I have the wire connections ready. Just waiting on phone battery to charge. I need to get a straight up thermal camera and sell this ios Flir One pro. I will report back asap.
                        • TheWizard
                          • Feb 2015
                          • 190
                          Okay injected 1v @ 1a on pad 2 of PL8200. The board pulled a 1 amp draw. But nothing got hot on the board. At least not visible to the thermal cam. I tested front and back of board for heat.
                          • Sephir0th
                            • Oct 2020
                            • 1283
                            1Amp might be not enough then. Concentrate on the platform controller hub (PCH). I'm pretty convinced it is the culprit.
                            • TheWizard
                              • Feb 2015
                              • 190
                              Try 1v @ 1.5 amps? Is this the PCH?
                              • TheWizard
                                • Feb 2015
                                • 190
                                1.05VS Rail:
                                JP2603 = 0.7
                                PJP8201 = 0.6
                                PJP8202 = 0.6
                                PT8201 = 0.6
                                PT8202 = 0.6
                                PT8203 = 0.8
                                Q7702 = 0.5
                                R0313 = 1.0
                                R0350 = 1.0
                                R0612 = 0.8
                                R0614 = 0.5
                                R2539 = 0.6
                                R2601 = 0.7
                                R2602 = 0.7
                                R2603 = 0.7
                                R2702 = 0.6
                                R2704 = 0.6
                                R2706 = 0.7
                                R2707 = 0.6
                                R2712 = 0.6
                                R2713 = 0.6
                                R2714 = 0.7
                                R2720 = 0.5
                                R2727 = 0.6
                                R2728 = 0.9
                                R5707 = 0.7
                                U2001 = GPU
                                U2001 = PCH not GPU haha
                                • TheWizard
                                  • Feb 2015
                                  • 190
                                  1v injection @ 1.5 amps. Nothing noticable on thermal cam.
                                  • Sephir0th
                                    • Oct 2020
                                    • 1283
                                    It is. It seems you need more current or a better thermal camera.
                                    • reformatt
                                      • Feb 2020
                                      • 1419
                                      Just saying, @myth77 called it in post #2. Shorted EC and PCH. Game over man.
                                      • Sephir0th
                                        • Oct 2020
                                        • 1283
                                        Agree. This board has multiple issues and it was pretty clear from the beginning that there is even a fatal fault which marks it as no-fix. However, thread starter wanted to continue, so...
                                        • TheWizard
                                          • Feb 2015
                                          • 190
                                          Yeah it sure sounds like it. What is the max current i can send and still be safe? Maybe try 1.8 amps?
