Lenovo Yoga 530-14ikb, no charging, NM-B601
  • mon2
    • Dec 2019
    • 14340
    Re: Lenovo Yoga 530-14ikb, no charging, NM-B601
    Is pq316 on or off the board?
    Is the battery connected or removed?
    • hopkok
      • Oct 2014
      • 178
      • Slovakia
      pq316 is on board, all power removed
      • mon2
        • Dec 2019
        • 14340
        Post #17
        • hopkok
          • Oct 2014
          • 178
          • Slovakia
          I should remove mosfet and do measuring on motherboard pins? All power removed?
          • mon2
            • Dec 2019
            • 14340
            yes, remove this mosfet.
            Connect your battery.
            Connect the power adapter. The adapter will not be able to charge the battery since this high side mosfet will be removed.
            This is only a test to see if the battery is still in a conflict with the power adapter when BOTH power sources are applied to the logic board.
            When you do this, who is powering the board? Is it the power adapter or the battery?
            • hopkok
              • Oct 2014
              • 178
              • Slovakia
              #26
              but need to put back second mosfet and resistor PR310 too, right?
              • mon2
                • Dec 2019
                • 14340
                Which other mosfet is removed ?
                From post #20, how is the board powering up with the adapter connected but mosfet is missing?
                • hopkok
                  • Oct 2014
                  • 178
                  • Slovakia
                  #28
                  it was just sugesting to my question about ITE.
                  OK mosfet and resistors are back.
                  I connected battery (motherboard did not start), when I plug charger in, motherboard has started, there is no power consuption from power source, so running from battery and N1-0V and N2-battery voltage
                  • mon2
                    • Dec 2019
                    • 14340
                    So it has to be the battery mosfet that is left.
                    Measure the voltage to ground on each pin of the battery mosfet (PQ314) with the power adapter & battery connected.
                    • hopkok
                      • Oct 2014
                      • 178
                      • Slovakia
                      #30
                      place PQ316 back before?
                      • mon2
                        • Dec 2019
                        • 14340
                        No.
                        • hopkok
                          • Oct 2014
                          • 178
                          • Slovakia
                          #32
                          1,2,3 pins ->7,5V
                          4 ->13,5V
                          5,6,7,8 ->7,5V
                          • hopkok
                            • Oct 2014
                            • 178
                            • Slovakia
                            #33
                            No.
                            Hi, any sugestion from last measuring?
                            • mon2
                              • Dec 2019
                              • 14340
                              Meter in resistance mode.
                              Measure the resistance across the removed mosfet on your work table (PQ316).
                              Source (1-2-3) & drain (5-6-7-8)
                              Source (1-2-3) & gate (4)
                              Gate (4) & drain (5-6-7-8)
                              Post each measurement. Checking for a low resistance that means the mosfet is defective.
                              • hopkok
                                • Oct 2014
                                • 178
                                • Slovakia
                                #35
                                Source (1-2-3) & drain (5-6-7-8) -> 2Mohms
                                Source (1-2-3) & gate (4) -> 66 Kohms, if I change probes get 214 KOhms
                                Gate (4) & drain (5-6-7-8) -> 1,8 Mhoms
                                • mon2
                                  • Dec 2019
                                  • 14340
                                  To me, the source & gate readings are too low.
                                  Would you have a replacement mosfet?
                                  • hopkok
                                    • Oct 2014
                                    • 178
                                    • Slovakia
                                    #37
                                    Yes I have, lets try?
                                    • hopkok
                                      • Oct 2014
                                      • 178
                                      • Slovakia
                                      #38
                                      Mosfet replaced, the same. Orange light by charger is steady, but still no charging. Gonna to try flash ITE firmware...
                                      • mon2
                                        • Dec 2019
                                        • 14340
                                        Yes, good idea. The charger IC is configured over the smbus / I2C SDA and SCL lines. This configuration defines the battery charging profile, voltage, current, etc. So the smbus master must exist and must configure this IC.
                                        • hopkok
                                          • Oct 2014
                                          • 178
                                          • Slovakia
                                          #40
                                          Hi, finally it was failing CPU/PCH
                                            Lenovo Yoga Yoga 6 13ALC7 Notebook 700 Specification for Upgrade or Repair
                                            This specification for the Lenovo Yoga Yoga 6 13ALC7 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Yoga 6 13ALC7 boardview and Yoga 6 13ALC7 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-07-2024, 05:00 AM
                                            Lenovo Yoga Yoga 7i (16? Intel) 2 in 1 Laptop Notebook 700 Specification for Upgrade or Repair
                                            This specification for the Lenovo Yoga Yoga 7i (16? Intel) 2 in 1 Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Yoga 7i (16? Intel) 2 in 1 Laptop boardview and Yoga 7i (16? Intel) 2 in 1 Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                            Lenovo Yoga Yoga 6 13ALC7 Notebook Specification for Upgrade or Repair
                                            Lenovo Yoga YOGA Book Hybrid (2-in-1) Book Specification for Upgrade or Repair
                                            This specification for the Lenovo Yoga YOGA Book Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the YOGA Book boardview and YOGA Book schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                            09-06-2024, 08:10 AM
