HP 15bs only external display working help!!!
  • chamalsb
    • Sep 2020
    • 25
    • Sri Lanka
    HP 15bs ( LA-E811P ) rev 2.0
    only external display working but no internal display working. can't find the schematic only similer schematics but those are different help me to fix it.
  • gs84
    • Dec 2022
    • 36
    • Ukraine
    Re: HP 15bs only external display working help!!!
    before asking schematics better to tell what did you try to do. Another screen for example... or reconnect original one
    • chamalsb
      • Sep 2020
      • 25
      • Sri Lanka
      tried another screen also not working
      • gs84
        • Dec 2022
        • 36
        • Ukraine
        what about voltages on 9-10 and 19-20 pins of JEDP connector?
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          You can use any similar schematic with same pincount of edp connector. I think E791 will match perfectly.
          • ArchangelGabriel
            Aorus 17G YD laptop, broken display, could not switch to external monitor
            by ArchangelGabriel
            Hello guys! I need a little help, I have one laptop for repair, it is an Aorus 17G YD, gaming laptop. Broken display, some cable ripped form daughter board connector, case broken, battery discharged and probably locked, etc. After I did the most tedious job I ever did on soldering back the broken cables (shielded cable) , I measured resistance on CPU and GPU core, 3 and 5 v ps and any coils I find on the board, everything seems to be fine. After I plugged the charger I don't get the power led light on from the charger connection maybe because the battery is locked , but on power button I have
            11-23-2023, 03:55 AM
          • eurowill
            a2141 820-01700 internal display not working / external works
            by eurowill
            Hey ya'll this is my first post on here. I recently aquired a used/broken 2019 mbp 16 a2141 with the 820-01700 board. Seller told me that the laptop needed a new lcd. However upon doing some troubleshooting i found out the lcd is fine.
            Laptop boots like a normal, plays chime, touchbar lights up however there is no image on the internal lcd. If i connect and external monitor while its already on, nothing happens and no image is displayed on external. However if i restart or boot the machine while its plugged in, the external then works and a backlight is now visible on the laptop....
            07-23-2024, 10:06 AM
          • plyanthony
            Razer Blade 15 no external display with attached screen disconnected from motherboard
            by plyanthony
            Computer in question : Razer Blade 15 2020 Base Model
            Model# RZ09-03286E22
            BIOS CHIP: WINBOND W25Q128BV
            What I'm trying to accomplish:
            I want the computer to properly boot with an external display with the attached display disconnected from the motherboard. I have a CH341A programmer and full capability of modifying the BIOS easily. I Have tried various setting changes to no Avail.
            What I've tried thus far: Too much to note and I really dont remember everything I changed but here it goes.
            W/Stock BIOS - 1.06:
            Disconnect the...
            02-01-2023, 09:35 PM
          • lawrenceptrini
            Lenovo Ideapad Flex 5 14ITL05 Only working on external display
            by lawrenceptrini
            Hi Guys,
            LENOVO IDEAPAD FLEX 5 - 14ITL05
            BIOS VERSION - FXCN24WW
            EC VERSION - FXEC18WW
            MTM - 82HT0004US
            SERIAL NUMBER - R9130MDP
            CPU - i7-1165G7
            This laptop powers on but shows nothing on the internal display.
            However, if I attach an external display it works fine.
            Observations: When I shut down the laptop from windows,
            the fan remains spinning until I close the lid. If I leave the lid open
            the laptop will restart on it's own although I select shut down from windows.
            Also, when I check the voltage on the...
            10-15-2024, 12:47 PM
          • baglaivlad
            A1534 2015 820-00045 internal display not detected, but external works
            by baglaivlad
            Hi everyone!
            Trying to repair A1534 2015 macbook. The keyboard and touchpad was liquid damaged by coke, but the MLB has no signs of corrosion. The laptop successfully turned on, but missed a display flex. Replaced keyboard, touchpad and display flex, but still no image on the internal display (no backlight as well). When connecting to the external display the laptop works just fine (I have an image).
            It seems like internal display is not recognized. I tried multiple known-good displays and display flexes, the outcome is the same: no life on the display.
            It lead me to believe...
            06-08-2024, 02:30 PM
