disable onboard ram lenovo ip3 nm-d151
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: disable unboard ram lenovo ip3 nm-d151
    Originally posted by LKB
    And 2K resistor must be placed at RC123 position.
    Become a Badcaps supporter
    Thanks to all supporters.
    • makx1998
      • May 2023
      • Ukraine
      Do you need to physically remove the memory chips? flash bios?
      • Vesko356
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        No.
        • kamalkharbanda
          • Jun 2013
          • 91
          • India
          in my case i have 8gb samsung onboard ram on my motherboard.
          R1612 , R1610 , R1608 , R1606 resistances originally placed.
          RC123 originally blank.
          I moved only R1606 to RC123 and display successfully done on ext. dimm.
          and onboard ram permanently disabled. No need pull onboard ram chip.
          May be helpful for others
          • Vesko356
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            Will work but R1606 is 10K and RC123 should be 2K, so the proper way to do it in your case is: R1606 must be removed out, and 2K resistor to be added in a RC123 position!
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3553
              • slovakia
              #26
              if somebody is strugling like me with resistors, this will show position of resistors for memory disable
              • kyawthurabgo
                • Jun 2022
                • 15
                • MM B
                #27
                One resistor must be moved only.
                RC1606 (10K) ---> move it to RC1608 position. That's it.
                Thank Bro
                • Jan Svidek
                  • May 2024
                  • 5
                  • Slovensko
                  #28
                  I have this board:
                  GV451&GV551 NM-D151
                  Rev.: 1.0
                  RAM on board its bad (Samsung)
                  I moved RC1606 to RC1608 and nothing
                  I added RC123 (2kohm - (serial 1+1k ohm)) and nothing
                  maybe I need new bios ?
                  LCD still black, without battery using 0,39A
                  I searched the internet and here on the forum, but nothing works.
                  can someone help please​
                  • mon2
                    • Dec 2019
                    • 13835
                    Double check the strapping of each resistor. With no power, measure the resistance of each position. Compare with post # 26.
                    • Jan Svidek
                      • May 2024
                      • 5
                      • Slovensko
                      #30
                      Click image for larger version  Name:	dimm_only.png Views:	18 Size:	101.9 KB ID:	3276151
                      I have everything as it is on post 26.
                      It still doesn't work​
                      maybe the BIOS is also damaged or? If somebody have BIOS pls upload, or Im try find in forum..
                      • Jan Svidek
                        • May 2024
                        • 5
                        • Slovensko
                        #31
                        Notebook still not working, im using many Bios flies, but nothing happen.
                        Now LCD still black, white light working, without battery using only 0,02A nothing is short and when Im plugin battery start charging normaly.
                        Im lost....
                          • 20318
                          Im lost....
                          Post your bios in the "Bios requests ONLY!" forum and someone will take a look at it. You can try the RAM patcher for now https://www.badcaps.net/forum/troubl...63#post3172363
                          • Deby
                            • Aug 2015
                            • 52
                            • Serbia
                            #33
                            This tutorial works 100%
                            Like all the others who give the same instruction only in a different way.
                            It doesn't take much to philosophize.
                            With the BRD scheme and the brain, it is solved without problems.
                            If the motherboard still doesn't work, then you have another problem.
                            My board had symptoms of drawing around 750mA and climbing slightly as the CPU warms up.
                            As soon as I failed with reprogramming the EC and Main bios, I went to disable the RAM memory.
                            Immediately after the first startup of the motherboard, the current began to work variably and the image appeared without problems.
                            So the instruction is checked and works.​
                            • degebe2006
                              • Sep 2017
                              • 6
                              • argentina
                              #34
                              I have 4 gb onboard , move R1606 to RC123 and works? Thanks.
                              • degebe2006
                                • Sep 2017
                                • 6
                                • argentina
                                #35
                                In RC1608, I have one resistor 10 Kohm, and RC1606 is 10 Kohm too. Thanks
                                • degebe2006
                                  • Sep 2017
                                  • 6
                                  • argentina
                                  #36
                                  Thanks, I can disable the memory!!!!
                                  • kamalkharbanda
                                    • Jun 2013
                                    • 91
                                    • India
                                    #37
                                    ON BOARD RAM DISABLE TESTED SOLUTION FOR NM-D151 MOTHER BOARD
                                    • Joandean14
                                      • Jul 2021
                                      • 20
                                      • Philiphines
                                      #38
                                      THANKS 100% WORKING TRY THIS
                                      • brotank
                                        Lenovo C861 Ryzen 5 disable 4GB samsung onboard ram
                                        by brotank
                                        I quiet struggling with board lenovo c681 to disable 4gb samsung onboard ram because they're faulty, I followed the instruction on the schematic to disable them with resistor codes but still not detecting the ram on the slot.
                                        can someone disable onboard ram from my dumped bios, please 🙏
                                        I tried the other bios on this forum with disabled onboard ram, but no success
                                        my final try is to find someone that can help disable onboard ram in my dumped bios attached in this post.
                                        after that I officially give up 😂
                                        thanks for awesome jobs 😊...
                                        03-16-2025, 12:51 PM
                                      • Visual_vt
                                        Lenovo IdeaPad 3 15ADA05 Model: 81W1, how to disable onboard MICROTEC RAM?
                                        by Visual_vt
                                        Laptop freezes, sometimes no picture. POST every time with 4GB additional memory but still freezes in the windows.
                                        SSD and BIOS seems to be OK.
                                        Thank you....
                                        12-30-2024, 09:14 AM
                                      • NoRelax
                                        Correct procedure to disable defective onboard RAM on Lenovo T14 gen 1?
                                        by NoRelax
                                        Good day,
                                        In my hands I have a Thinkpad T14 gen 1 (20UD002BIX) showing sporadic BSOD issues caused by failing onboard soldered RAM. I suspect disabling the onboard RAM via a bios mod would do the trick.
                                        The laptop has already the latest updates as well as latest bios 1.51 as of today.
                                        I informed myself in an attempt to DIY my way to victory but it left me with more questions than answers. This is not a BIOS request, what I really need is somebody to verify that the following procedure is correct.
                                        Step 1: grab a bios image:
                                        - Method 1: from the official website:...
                                        12-18-2024, 04:52 PM
                                      • maury94
                                        Lenovo V330-14IKB Onboard Ram disable via Bios
                                        by maury94
                                        Hi everyone, let me start by saying that I'm new and I don't know if this is the correct section in which to write the post. I have a lenovo V330-14IKB notebook with 4GB of built-in ram that doesn't work. Is there a way via bios to disable the integrated RAM memory and use only the external slot?
                                        09-18-2024, 02:31 AM
                                      • b-slayer
                                        Acer A317-53 need help to disable faulty onboard ram
                                        by b-slayer
                                        Hello.
                                        I have an Acer Aspire A317-53 laptop with faulty onboard ram modules, after online searches, I have only found two options to get it working :
                                        - first one is to modify le bios to disable the onboard ram.
                                        - second one is to disable the onboard ram by desoldering some components on the mainboard.
                                        so after some hours google-ing, i have to give-up the modified bios option, main reason is I couldn't find anywhere a such modified Bios, alternate reason is that if windows update makes a bios update, the problem is always here...
                                        so i found that my motherboard...
                                        10-12-2024, 03:46 AM
