macbook A2141 error 9 stuck after ssd replace
  • itya
    • Jan 2023
    • 3
    • slovakia
    hello mates i got one A2141 it had restart issue after somemins and panic log shows ANS@2 RECOVERABLE that is means ssd bad it was 512gb but i got 1tb board with 6ssd so i remove all 5 and install new 6 got dfu mode but when restoring got error 9 re programm T2 rom still error 9 maybe i think new ssd which i got was from dead board maybe bad also so i remove then again and put back old 5 again dfu and error 9 with old chips i think it should work but didnt one thing i face strange is with battery this directly goes in DFU without any buttons but only motherboard is stuck at 5v no dfu even with jumper nothing not getting 1.8 on force dfu resistance R8010 but got 1.8v on pp1v8slp is this normal i think only board also will be on 20v
  • vla9imir
    • Apr 2022
    • 3
    If you have board with 512gb ssd, you can't install any configuration over 512gb (only 128,256 or 512gb), before install new ssd kit, you need check which T2 chip installed on your're board(check part number), A2141 have 2 type of T2 - 1 type have only 1GB RAM (D9VLN), 2 type T2 have 2GB RAM (H9...), T2 with 2Gb RAM compatible ssd configuration 1tb up to 8tb
