Help Me diagnose A1706 820-00239 0.13v on PPBUS
  • zipporobotics
    • Feb 2023
    • 5
    • Italy
    Hi everybody
    trying to get data out of my MacBook Pro which I accidentally liquid damaged.
    A Small drop of tea travelled on the back of the board nearby the trackpad connector: blowing it (see picture) digging a small hole in the motherboard (probably removed the first two layers.
    https://imgur.com/a/TyHyyPm
    Cleaned everything
    Now trying to get this machine to boot again
    Reading up a few post I've done some tests
    Removed battery
    A few measurements
    - PPDCIN_G3H (19.95 V)
    - PPBUS_G3H @ F7000, pin # 2 ( 0.13 V) (resistance to ground = 14 ohm)
    - PP3V3_G3H (3.390 V)
    - PPVIN_G3H_P3V3G3H (19.59 V)
    - PPBUS_G3H @ D6902, pin # 1 (Missing, value 0.13 V)
    - PPDCIN_G3H_CHGR @ D6902, pin # 2 (19.85 V)
    - PPVBAT_G3H_CHGR_REG @ F7000, pin # 1 ( 0.13 V)
    - SMBUS_SMC_5_G3_SDA (3.25V)
    - TBA_VDDP (5 Volt)
    - PPBUS_HS_CPU (0.13 v)
    -L9400 both pin 11.05 K Resistance to ground
    -Q7030 is getting 19.85 volt on pin 1-2-3
    -Q7040 is getting 0.13 v on pin 1-2-3
    -No voltage on L3500 and L8410
    -0.13 volt measuring Q7030, L7030
    couldn't find anything misplaced
    how do I find if something is heating up without a thermocamera ?
    Plugging in the USB C tester measures 19.99 volts and draws 0.067 amps
    What should I test next ?
  • mon2
    • 14634
    Re: Help Me diagnose A1706 820-00239 0.13v on PPBUS
    Resistance is too low. Need to determine which side of the F7000 is responsible for this short condition.
    Remove fuse F7000. With NO power, measure the resistance to ground of each side of the fuse pads (no fuse is installed).
    Suspecting that the downstream (consumer side) is with the low resistance?
    Power up again. Measure the voltage to ground of the PCB pad that is towards the ISL (regulator = SOURCE) side.
    What is the voltage now of PPBUS_G3H without this load ?
    • zipporobotics
      • Feb 2023
      • 5
      • Italy
      Found the short
      I removed F4500 and now I have 12.84 volts on PPBUS
      Still
      no signs of life
      Now its drawing 0.13 amps at 20 volt
      cpu is warming up
      Further Check
      I have no voltage on PPVCCSA_S0_CPU neither on PPVCC_S0_CPU
      what should I check next ?
      • mon2
        • 14634
        Remove all power. Measure the resistance to ground of PPVCCSA_S0_CPU.
        • zipporobotics
          • Feb 2023
          • 5
          • Italy
          Hang ON
          And thank you for patience as I'm re-learning power rails and I think I've found the correct order
          So
          PPBUS_G3H is ok at 12.98
          Then I went on Measuring the PP5V_S5 rail and got 5 volt
          So I went on the 3V3 Rail PP3V3_S5 and found it appears just a few seconds after plugging in the USB C and then its quickly cut off
          Seeing its generated by U7650, nearby coil L7660, I measured the resistance to ground and got 7K. So it doesn't seem to be short neither it seems to be low
          Could it be another stage being served by PP3V3 that has gone failed thus causing PP3V3 to shut down ?
          I've noticed in the meantime U7900 and U7800 are getting really hot
          and U7800 seems to be generating PP1V2_S3 which I suppose is the voltage needed for the cpu to turn on ?
          Coil L7900 Measures 170 ohm to ground and PP1V2_S3 shows no voltage
          Thinking about it, The tea drop (with a bit of honey) that travelled along the board, travelled through both U7900 and U7800. I have cleaned them around and superficially but I haven't yet tried spraying isoprophilic alcol under them.
          Do you think I can try cleaning under them or should I just replace them ?
          • zipporobotics
            • Feb 2023
            • 5
            • Italy
            DID IT!
            So I reflowed U7800
            and the machine then booted again
            Only issue
            Fans are spinning at 6000 rpm
            And Kernel Task is taking 254 % cpu
            Could it be because trackpad isn't plugged in ?
            Given I won't ever be able to plug in trackpad.
            Is there a way to disable or tell SMC not to care about it ?
            Already tried resetting Nvram Pram and SMC
            No difference
            • mon2
              • 14634
              Attach the trackpad and test again. Be sure to also inspect the quality of the trackpad cable and that it is clean and well seated.
              • BillyJ
                2017 Apple MacBook Pro 13 inch touchbar A1706 - Not turning on - PPBUS Short?
                by BillyJ
                Is there a boot-up sequence for the A1706 (Kaby lake) to see where the computer is getting stuck? Equiv to the below for older MBP's?
                https://logi.wiki/index.php/G3_to_S3..._and_Broadwell
                currently I measure:
                PP20V_USBC_XB_VBUS = 20
                PPDCIN_G3H_CHGR = 20.4
                PPDCIN_G3H = 20.4
                SMC_RST_L = 3.4
                PM_EN_P3V3_G3H = 5.2
                PP3V3_G3H = 3.4
                PPBUS_G3H = 0V (2.1 Ohm to GND - ISL9239 failure?)
                S5:
                PP3V3_S5 = 0
                PP5V_S5 = 0.346
                PPBUS_HS_OTH3V3 = 0.0186
                PPBUS_HS_OTH5V = 0.0186...
                01-02-2022, 03:54 PM
              • ugamazing
                820-02918 PPBUS Cycling, Minor Liquid.
                by ugamazing
                Working on an 820-02918 board that had a minor liquid spill, but it was directly to the ISL/U5200. Essentially the entire area had to be replaced due to corrosion. Got it all cleaned up and everything looks good and checks out, but we're hitting a cycling PPBUS issue now. PPBUS_AON cycles quickly from ~9v-12v, indefinitely.
                Knowing this is typically a sign of a possible short on a lower rail, we checked all around and found no obvious damage or shorts. We have VERY LIMITED parts for this model (exactly 1 single U5200 chip), but I suspect it will end up being a continuity issue or...
                02-18-2025, 11:21 AM
              • Danielreinaa
                HELP need password bios Macbook A1706
                by Danielreinaa
                Hola chicos, espero estén bien, he estado buscando información para aprender a hacer eliminación de password EFI en macbooks.
                Actualmente tengo un problema con una macbook pro A1706 820-00923 SN:C02VD3GJHV2Q
                Si podrian ayudarme les agradeceria mucho o algun link para aprender a hacerlo y no volver a molestarles.
                gracias de antemano y que tengan una linda tarde, disculpen si estoy rompiendo alguna norma.
                Hi guys, I hope you are doing well, I have been looking for information to learn how to remove the EFI password on macbooks.
                09-07-2024, 03:47 PM
              • moderator
                A1706 - emc 3107 bios
                by moderator
                a1706 Bios file i am uploading , need cleaned, its not password locked..macbook is booting ..getthing chime also.but stuck on apple logo..in target mode disk is recognised and i was able to copy data...it happened while changing the touchbar
                Serial number is C02STA7EHF1P
                its A1706 - emc 3107...
                05-17-2024, 07:00 AM
              • corrize
                How to diagnose little step down and power management BGA chips never shorted
                by corrize
                I have different sort of those little BGA chips (step down DC-DC, power management battery, …) I replaced 10 on differents mobile devices (no schematics) but I noticed often they can be dead but never shorted. I see some signs : burn marks, resistance drop by comparison with good board (40 KOhms to 1 KOhms for example)… but not easy to be sure of the diagnose. Because I can't access on all tracks (balls) with the meter.
                Sometime, I know only after replacing chips.
                Do you have tips for diagnose please ?
                05-02-2024, 08:30 AM
