Hi, I'm scratching my head on this Macbook.
Last time I worked on it (October), it had a speck of corrosion on the back of the board that ate R2281 & R8131 (maybe some condensation on dust ?). I replaced these two by the same values and the board worked correctly for 4 months.
Done all tests from here with the board out of the case without any battery plugged in, only the power board, fan & the L cable that connects to J9500, to rule out anything plugged in.
Today, Charger LED is usually Orange but no signs of life at all.
PPDCIN_G3H_ISOL & PPDCIN_G3H_INRUSH is 14.97 V
CHGR_DCIN is 14.7 V
PP3V42_G3H is 3.420 V
PPBUS_G3H & CHGR_PHASE is 1.88 V
PPDCIN_G3H to ground is 43.3 kOhm
R7105 is 20 Ohm
I don't see any corrosion on the board.
Sometimes charger led is off or switching green and off and all the voltages are pulsing & PPDCIN_G3H stays at 1.7 V.
(I looked at repair wiki and "No PPDCIN_G3H when using genuine Magsafe" says it may be Q7180 but Q7180 is not leaking back to the input it seems)
As R8131 has something to do with charging (CHGR_VFRQ), maybe it has something to do with it ? It worked fine for 4 months and is under solder mask.
Do anyone know where to look to narrow down the issue ?
CHGR_DCIN is 14.7 V
R7105 is 20 Ohm
