A1932 no image or backlight
  • Jenzo
    • Jul 2019
    • 135
    • Belgium
    Hey everyone, had a A1932 come in that has no visible damage or liquid spill. Board number: 820-01521-02
    It powers on, charges 20v 1.6a. CPU gets hot, trackpad reacts, but I never get an image or backlight. One strange thing is that the light of the caps lock doesn't light up although it seems to be on.
    I tried:
    Working display and flex
    External display
    DFU (doesn't recognize the device)
    PPVCC_S0_CPU comes on so assuming power on sequence is good
    When inspecting the board I did find solder balls popping out from under both D8410 and U4802, the diode still measures normal and no shorts on or around the ic, so no clue if it means something.
    Where do I go from here? Any advice welcome!
  • Salem Aboshala
    820-00138-A got image but no backlight
    by Salem Aboshala
    Dears, this is my first post here and first try to fix my own laptop Apple MacBook Pro Retina 15-inch Mid 2015.
    I have some general electronics troubleshooting experience and still as my hoppy but this is my first laptop trying to fix.
    History: my laptop backlight stopped working without any reason.
    Symptoms:
    I have image on screen using my flashlight.
    I have fully working laptop with the help of my external SAMSUNG LED tv via HDMI cable.
    Keyboard backlight still working and can be adjusted normally.
    Since two days I tried to follow all similar...
    06-11-2024, 03:02 PM
  • zaurus81
    Yashi All in one model AY62409 (Quantum S 24'') no image (backlight works)
    by zaurus81
    This chinese all in one computer gives an image when connected to an external vga monitor but only the backlight with integrated monitor (no image). Initially I thought it was an edid problem on the eeprom of the screen but then I saw that the monitor works correctly with another identical motherboard (model th410-d4, read by bios). Unfortunately the motherboard is chinese and has no brand or codes on the pcb. The format seems ITX. Nothing can be found online. The official yashi site provides drivers but not the bios. The electrical diagram is obviously unobtainable
    The board is equipped...
    01-16-2025, 03:54 AM
  • defdjamel
    macbook a1932 no screen , no backlight
    by defdjamel
    hi there , in this A1932 - Air 13 Retina 2018 820-01521, there no screen , no backlight.
    no liquid damage.
    i have change the lcd flex ,
    tested with a working lcd screen but no display , no backlight.
    hdmi over usbc is ok .laptop is working .
    the same.
    here measurement
    • PP3V3_LCD = 3,3 V
    • PP5V_LCD = 5 V
    • I2C_SDA_TCON / I2C_SCL_TCON = 3,3 V (no oscilation)
    • LCD_PWR_EN = 5 V
    • LCDBKLT_EN_L = 12 V
    • EDP_BKLT_EN = 0 V
    • IPD_LID_OPEN = 1.8 V
    i am stuck, if you have an idea....
    09-16-2025, 06:52 AM
  • Constantinos
    Macbook Pro A2442 820-02098 No image but has backlight
    by Constantinos
    Hi all
    I have a Macbook Pro A2442 with the 820-02098 from a friend which has no picture on the display, however, the backlight works.
    He was streaming a football match on a questionable site, then the site crashed, and the problem emerged.
    Initially, he sent it to apple, who quoted him £1323.95 to replace the display, lid angle sensor and top case.
    Obviously, he decided against this and gave it to me so that I could have a crack at it.
    From initial diagnostics, I connected to an external monitor, I first tried with a HP 22W monitor, and I booted into the boot menu...
    08-24-2024, 09:48 AM
  • ajgae
    HP Pavillon x360 14-ba174nz no image no backlight, LCD_VCC low (2.25V)
    by ajgae
    Hi everyone!
    First post on here so do tell me if i'm doing anything wrong. I have a laptop that came in with a broken hinge, but a healthy LCD. We replaced the LCD rear cover and now we do not get an image on the LCD anymore, though we get one via HDMI. There is sadly no schematic or boardview available for this motherboard (Bucks U42 DIS 17817-1) as far as i can tell, but I was able to identify which of the important pins on the LCD eDP connector (30 pin 2 lane) correspond to which pins on the motherboard display connector (which is 40pin, 30 for LCD and 10 for camera/face rec etc)...
    03-06-2025, 09:53 AM
