[help] A1466 820-3437 NO AUDIO!!
  • phantomEVO
    • Mar 2013
    • 487
    P1V5S0SW_AUDIO_EN present
    PP1V5_S0SW_AUDIO present
    all diodes readings on j9500 present and perfect
    HDA_SDOUT R1313 33ohm
    HDA_SDOUT_R R1921 1kohm
    HDA_SYNC R1311 33ohm
    HDA_BIT_CLK R1310 33ohm
    HDA_RST_L present
    changed I/O Board and flat...no luck
    no audio peripheral avaible in the system
    maybe smc rework before by someone else
    any help?
  • Kuroneox
    • Feb 2017
    • 24
    • México
    Re: [help] A1466 820-3437 NO AUDIO!!
    I don't know much English, but the audio failure of that model, for me, has been related to the flex, io board and board connector. really try changing io board
    • reformatt
      • Feb 2020
      • 1399
      Audio codec is on the DC IN board. Try a PRAM reset first, then make sure you are using a known good DC IN board and flex cable.
      Often see corrosion at the base of J9500 too. Check signals at each pin like AUD_PWR_EN etc.
      • phantomEVO
        • Mar 2013
        • 487
        I have Already changed dc board And flex like i said before…
        There is no corrosion on j9500
        Signal are present like i said
        • piernov
          • Jan 2016
          • 4435
          • France
          I think wrong SMC (from 3209) may cause no audio on these. Can try to reflash SMC firmware at least, or replace from another 3437.
          • phantomEVO
            • Mar 2013
            • 487
            How to re flash?
            • reformatt
              • Feb 2020
              • 1399
              Good point Piernov. I know that using a SMC from a 820-3437 donor for a 820-00165 board causes that.
              Reflash the SMC firmware from https://github.com/MuertoGB/SMCTool/releases
              • phantomEVO
                • Mar 2013
                • 487
                Awesome? What type of Programmer should i use? Where can i find some tutorial?
                • reformatt
                  • Feb 2020
                  • 1399
                  It's a DMG file, just create a bootable USB with it and boot off it. Menu is pretty self explanatory. Further info here:
                  https://www.youtube.com/watch?v=q8LEh8C4iYo
                  • valente222
                    HP 14 LA-A993P REV 1.0, identify ic? and not susp# present
                    by valente222
                    I have a Mb LA-A993P REV 1.0 computer, I am guiding myself with these two shared boards. ;
                    there are some ICs that are not the same, in this case those of the PU1501 (JD4TB) and PUH1 (NF4SA) images.
                    n, please identify.
                    330mA of consumption after 8 seconds turns off. +3VALW AND +5VALW present, EC_RSMRST# , LID_SW# , EC_ON# , ACIN# present.
                    SUSP# NOT PRESENT, which would be this the problem does not turn on sub-sources Any leakage?
                    I also notice that in the PLH2 coil that belongs to +1.05VS according to the drawings I am not sure,
                    06-27-2024, 06:11 PM
                  • willumpie82
                    A1466 820-00165 fan spin, no chime vcore present
                    by willumpie82
                    I'm working on a rabbit-hole again, I have a 820-00165 board that has not been damaged (no liquid or other nasty stains).
                    It came with the story that it runs but freezes randomly, when we looked at it at first it came to the disk selection and then frozen now it won't display or chime at all. I removed the SSD and wifi and inserted a USB drive, no changes.
                    So opened it up removed the battery and when powering it on it gets fan spin but no chime and no image, looks brain dead to me...
                    on visual inspection the board looks mint
                    I...
                    05-26-2020, 02:41 AM
                  • air_chair256
                    Lenovo Yoga 9I 15IMH5, MB LC40CM Won't Turn On, 1V_VCCGT is not present
                    by air_chair256
                    I have a Lenovo MB LC40CM 19863-1 when press button is pushed the keyboard backlight turns on and off twice and the power button light keeps blinking and the fans spins for a few seconds and stops then again spins and stops (Three times) then laptop turns off. no image on screen. sometime when you leave it for few days it will turn on and work but once you restart it won't turn on.
                    Tried to reball RAM 1,2,3,4
                    Checked all voltages on big coils all present except 1V_VCCGT is not present I get 0V on this rail. is this voltage should be present once power button...
                    02-13-2024, 06:00 AM
                  • javieromex
                    Dell G15 5511 LA-K452P won't turn on
                    by javieromex
                    Hello, any help will be apprecited!
                    • Model: Dell G15 5511
                    • MB: LA-K452P
                    • Issue: Won't turn on at all, no leds, no keyboard light, no fan spin, nothing happens when pressing power button. NOTHING.
                    • Customer reported it was turned off and left plugged in during the night and thats it...
                    • No signs of liquid damage or burned components.
                    Link to Schematics -> https://www.badcaps.net/forum/troubl...la-k452p-gdp50
                    I have checked so far:
                    04-17-2025, 12:44 PM
                  • Prott
                    Surface Pro 7 - SLP_S4 present, then gone
                    by Prott
                    Hello fellow Badcappers,
                    I have a problem with stubborn Surface Pro 7. I narowed it down to disappearing SLP_S4# (gone after around 200 ms).
                    Everything else works as it should (the whole power on sequence succesfully finishes, all the voltages are present) until this signal goes missing - with it missing the AND gate causes ALL_SYS_PWRGD to go back low and this makes VCCIN drop to 0 V as well. Interestingly the SLP_S4_DRV# signal from SAM is still present for a second, even after SLP_S4 is no longer there. I wonder what could either cause PCH to stop sending the signal or what...
                    12-03-2023, 06:11 PM
