[help] A1466 820-3437 NO AUDIO!!
  • phantomEVO
    • Mar 2013
    • 509
    P1V5S0SW_AUDIO_EN present
    PP1V5_S0SW_AUDIO present
    all diodes readings on j9500 present and perfect
    HDA_SDOUT R1313 33ohm
    HDA_SDOUT_R R1921 1kohm
    HDA_SYNC R1311 33ohm
    HDA_BIT_CLK R1310 33ohm
    HDA_RST_L present
    changed I/O Board and flat...no luck
    no audio peripheral avaible in the system
    maybe smc rework before by someone else
    any help?
  • Kuroneox
    • Feb 2017
    • 24
    • México
    Re: [help] A1466 820-3437 NO AUDIO!!
    I don't know much English, but the audio failure of that model, for me, has been related to the flex, io board and board connector. really try changing io board
    • reformatt
      • Feb 2020
      • 1495
      Audio codec is on the DC IN board. Try a PRAM reset first, then make sure you are using a known good DC IN board and flex cable.
      Often see corrosion at the base of J9500 too. Check signals at each pin like AUD_PWR_EN etc.
      • phantomEVO
        • Mar 2013
        • 509
        I have Already changed dc board And flex like i said before…
        There is no corrosion on j9500
        Signal are present like i said
        • piernov
          • Jan 2016
          • 4439
          • France
          I think wrong SMC (from 3209) may cause no audio on these. Can try to reflash SMC firmware at least, or replace from another 3437.
          • phantomEVO
            • Mar 2013
            • 509
            How to re flash?
            • reformatt
              • Feb 2020
              • 1495
              Good point Piernov. I know that using a SMC from a 820-3437 donor for a 820-00165 board causes that.
              Reflash the SMC firmware from https://github.com/MuertoGB/SMCTool/releases
              • phantomEVO
                • Mar 2013
                • 509
                Awesome? What type of Programmer should i use? Where can i find some tutorial?
                • reformatt
                  • Feb 2020
                  • 1495
                  It's a DMG file, just create a bootable USB with it and boot off it. Menu is pretty self explanatory. Further info here:
                  https://www.youtube.com/watch?v=q8LEh8C4iYo
