Acer CB5-312T
    Acer CB5-312T
    da0zsemb6f0 rev F
    not charging USB-C stays on 5V schematic available quanta_zse_rev.1a_
    any thoughts?
    Re: Acer CB5-312T
    Can you link or post the schematic?
    Original power adapter?
    What is the history?
    Tested with a known good battery?
      Re: Acer CB5-312T
      Just stopped charging
      Battery works after external charging
      Power adaptor not orginal but likely to work
        Re: Acer CB5-312T
        The adapter is critical and if with less power, the logic board will be throttled and charging will halt.
        Test with a suitable adapter.
        Next step is to review the schematics.
          Re: Acer CB5-312T
          schematics
            Re: Acer CB5-312T
            Does your adapter support 45W or more?
            20V 2.25A
              Re: Acer CB5-312T
              it is solid on5V
                Re: Acer CB5-312T
                It is possible that the BMC communication for the power delivery are not working to negotiate the power delivery contract.
                Remove all power. Meter in diode mode. Review the usb c pinout and check the diode mode readings for CCx pins.
                  Re: Acer CB5-312T
                  20V 2.25A
                  yes 60W
                    Re: Acer CB5-312T
                    CCx pins:both 0.168 with red to ground otherwise open
                    i did get suddenly 15V after remove battery and reconnect
                      Re: Acer CB5-312T
                      CCx pins:both 0.168
                      Sounds low. Have not had a chance to review the schematics but check if there is a TVS diode on this line. If yes, carefully remove it and then check the same CCx diode reading to see if it is higher in value.
                      Note that CC1 is for one side of the USB C connector blade; CC2 is for the other side of the USB C connector blade.
                      Either can then communicate with the power adapter over this single wire communication.
                        Re: Acer CB5-312T
                        There are TVS but seems good
                          Re: Acer CB5-312T
                          Here are some known good DIODE mode readings from macbooks that make use of the USB C interface:
                          USBC0_CC1 Default d 0.588
                          USBC0_CC2 Default d 0.569
                          USBC1_CC1 Default d 0.584
                          USBC1_CC2 Default d 0.584
                          If you see a TVS diode on the line with the low diode reading, remove the TVS diode and test again to see if the measurement is higher.
                            Re: Acer CB5-312T
                            Never mind, the solution is near
                            Its totally working
                              Re: Acer CB5-312T
                              BAT_ENABLE _L was the cause, not looked byond that, simply added R699
                                Re: Acer CB5-312T
                                Nice! Strange that the battery's BMS was not supplying this pull-down status upon docking to the battery connector.
