HP Sprectre x360 15-DF DAX38CMBAG0 (Quanta X38) not charging
  • mon2
    • Dec 2019
    • 14662
    Re: HP Sprectre x360 15-DF DAX38CMBAG0 (Quanta X38) not charging
    replacement board
    You ordered the complete logic board and it does not charge???
    I am with @reformatt, the adapter is not being sensed to be powerful enough. Test others. HP uses a resistor to define the power rating of the adapter.
    • Rainbow
      • Aug 2005
      • 1375
      I've already checked continuity from the adapter's center pin to the board and it's OK. Also the center pin voltage on the board changes - it's 820mV with the original 135W adapter and 682mV with 60W or 90W adapter. It does not charge with any of them...
      Maybe the fault is so common that the "new" board has the same problem?
      • mon2
        • Dec 2019
        • 14662
        This adapter ID voltage is too low. So low that it will take a precision analog to digital converter to detect the adapter power.
        Review this website:
        https://wiki.robotz.com/index.php/HP_Smart_Pin
        Use external resistors to dial up ~5-6 volts onto the target dc adapter center pin on the logic board.
        Then test again.
        • mon2
          • Dec 2019
          • 14662
          A more detailed article on the same topic:
          http://nerdipedia.com/wiki/tiki-inde...laptop+charger
          Do update this thread after testing these ideas.
          • Rainbow
            • Aug 2005
            • 1375
            According to some other posts, the center pin voltage is probably correct.
            When the center pin is not connected (removed from the connector that plugs to the board), the power jack LED does not come on at all.
            • piernov
              • Jan 2016
              • 4439
              • France
              #26
              The voltage can vary between boards model since it depends on the bottom resistor of the voltage divider on the board.
              Doing so could damage the board.
              • mon2
                • Dec 2019
                • 14662
                Can you link or post the schematic for your logic board?
                Does this model also offer a usb C port for charging?
                Thanks @Piernov. Thought the same but others are reporting success with this adapter pin voltage. Best for us to review the exact resistors / protection of this pin on the EC on this model.
                I think the fault is due to the EC unable to detect a valid pin voltage to define the proper adapter for charging.
                For safety, keep this pin under 3v3 which will likely be the max raw voltage of the EC's gpio pins.
                Still of concern is why the logic analyzer spews different smbus traffic between the batteries.
                Also a good read:
                https://www.badcaps.net/forum/showthread.php?p=1099382
                • reformatt
                  • Feb 2020
                  • 1497
                  At this stage, I would normally try to find another working unit for a sanity check to find out what does and does not work, be it batteries, adaptors and logic boards. You've done well to perservere so far!
                  I remember seeing a case with a MAC not charging after trying 4 batteries. The assumption was that it was a logic board fault only to find out that all 4 were indeed faulty.
                  • Rainbow
                    • Aug 2005
                    • 1375
                    #29
                    Discovered some more FETs on the back side of the board (completely covered by black plastic sheet)!
                    There are two AC switching FETs and three that look like bypass FETs from ISL9241 datasheet. As they were nowhere to be found (and there's no schematic), I thought that there was no bypass.
                    There are two 0203GMT (AP0203GMT) (in parallel) on VADP side and one M3092M (QM3092M6) on VSYS side. There's G-S short! Used bench supply to force current through the short and looks like the short is in QM3092M6.
                    • Rainbow
                      • Aug 2005
                      • 1375
                      #30
                      Removed QM3092M6 and it's really shorted G-S. S-D looks good, however. No more short on the board.
                      Replaced by FDMS0310AS (from a dead board). It's charging now!
                      • reformatt
                        • Feb 2020
                        • 1497
                        So both boards had the same fault then?
                        • Rainbow
                          • Aug 2005
                          • 1375
                          #32
                          Yes, the "new" one has the same short. Haven't fixed it, will try to return it instead. Seems to be a common failure.
                          • mon2
                            • Dec 2019
                            • 14662
                            Charges both batteries?
                            Before this discovery, the smbus traffic was different for each battery pack.
                            • Rainbow
                              • Aug 2005
                              • 1375
                              #34
                              Yes, it charges both batteries.
                              • reformatt
                                • Feb 2020
                                • 1497
                                Excellent. Both boards being faulty is why I do the sanity check with another system. You assume the replacement board was 100% working, but turns out it wasn't.
                                Biggest lesson I was taught in electronics as a trainee was that when you assume something it makes an ASS out of U and ME.
                                Full marks for persistence though. A lot would have given up.
                                • mon2
                                  • Dec 2019
                                  • 14662
                                  It is from a old Benny Hill skit (UK):
                                  https://www.youtube.com/watch?v=bPsg42EKJic
                                  He used to push the censors back then.
                                  • Rainbow
                                    • Aug 2005
                                    • 1375
                                    #37
                                    Attaching photo of the shorted FET.
                                    • reformatt
                                      • Feb 2020
                                      • 1497
                                      So I've had a 15-df that I've been struggling with since December. Original battery was swollen. Replacement from supplier seemed to work initially however customer states that it only last 5 minutes and switches off. Another replacement charges, sort of.
                                      Battery is SU06XL and doesn't seem to be stocked by many suppliers. So I've had to resort to getting a battery directly from HP reseller (EMPR) for twice the price.
                                      Will wait to see how this battery goes first, but may very well be a board issue.
                                      • Rainbow
                                        • Aug 2005
                                        • 1375
                                        #39
                                        I've been unable to find a new HP SU06XL battery. Luckily, the original one was OK (88% capacity, not swollen).
                                        Are there any replacement batteries that don't trigger the stupid BIOS warning?
                                        • reformatt
                                          • Feb 2020
                                          • 1497
                                          The first battery seemed to be ok, however he reported that it'd last 5 minutes. The 2nd battery when I tried to charge by USB-C, rather than the barrel adaptor, current went haywire on my ammeter. He said it wasn't charging with the barrel adaptor.
                                          This is the reason I got out of the phone repair industry. So over parts that just don't work out of the box. We are now starting to see it in the computer industry now too.
                                          So I bought the latest one directly from HP/EMPR. Nearly AUD $200 with shipping, whereas everyone else is AUD $100. That's the price you pay to get something that actually works.
                                          • coasterghost
                                            Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                            by coasterghost
                                            For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                            Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                            Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                            System Hardware:
                                            Processor: AMD Ryzen 7 PRO 5850U
                                            Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                            09-08-2025, 10:46 PM
                                            HP ProBook x360 Pro x360 Fortis 11 inch G9 Notebook PC Hybrid (2-in-1) Specification for Upgrade or Repair
                                            This specification for the HP ProBook x360 Pro x360 Fortis 11 inch G9 Notebook PC Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pro x360 Fortis 11 inch G9 Notebook PC boardview and Pro x360 Fortis 11 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
                                            09-07-2024, 05:50 AM
                                            HP Pavilion x360 Pavilion x360 - 14-dh1000na Hybrid (2-in-1) 14 Specification for Upgrade or Repair
                                            This specification for the HP Pavilion x360 Pavilion x360 - 14-dh1000na Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion x360 - 14-dh1000na boardview and Pavilion x360 - 14-dh1000na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                            09-06-2024, 03:30 PM
