HP Sprectre x360 15-DF DAX38CMBAG0 (Quanta X38) not charging
  • Rainbow
    • Aug 2005
    • 1375
    Laptop works either on AC adapter or on battery but does not charge. The LED turns amber after connecting AC adapter, OS says "charging" but there's no current flow to the battery.
    Tested 3 adapters (original 135W, older 90W and 60W), two batteries (both do charge on bench supply and provide correct data through SMBUS).
    Charger is ISL9241, MOSFETs are OK. There's SMBUS communication between EC (IT8987VG) and charger. Examined SMBUS using analyzer - seems that EC does not enable charging
    Upgraded BIOS to latest (47), EC was flashed too during the process.
    Any ideas?
  • mon2
    • 14662
    Re: HP Sprectre x360 15-DF DAX38CMBAG0 (Quanta X38) not charging
    SMBUS voltage and resistance to ground are ok ?
    Confirm the resistance path from the ISL9241 to the current sense resistor for the battery charge path. Check the P and N sides of the CSR (low ohm resistor) to be sure there is no break or a cause to have a large voltage drop. Then the charger will shutdown if it senses the rail is under 'excessive load'.
    • Rainbow
      • Aug 2005
      • 1375
      SMBUS is OK, laptop can read battery status including individual cell voltages.
      There's a 5 mohm current sense resistor and traces are OK.
      EC writes zero to register 0x14 (ChargeCurrentLimit) so no charge can happen...
      I've seen once a non-zero value write to register 0x14. But it wrote wrong values to 0x15 (MaxSystemVoltage) and 0x3E (MinSystemVoltage) - around 9V (the battery has 3 cells in series). After a moment, it wrote back zero to 0x14 (and also to 0x15 and 0x3E). Seems that EC is confused by something.
      • mon2
        • 14662
        Do you see the same SMBUS traffic if the battery is removed?
        Check the battery connector pins. Perhaps the charger is not detecting the battery?
        Does the battery respond to each smbus packet?
        Could the batteries be fake? Charger wants to see some id from the battery?
        • Rainbow
          • Aug 2005
          • 1375
          One battery is original from the laptop. The other one is non-HP (BIOS displays a warning) but it should charge.
          Although the charger and battery are connected to a common SMBUS with EC, the charger does not communicate directly with the battery. Everything goes through the EC.
          Decoded and commented SMBUS capture when AC adapter is plugged in with no battery:
          Code:
          //charger IC dedetcion
          write(12, FE) read(13, 49, 00) //mfg. ID read == 0x0049
          write(12, FF) read(13, 0E, 00) //device ID read == 0x000E
          //set up charger and enable auto charging (to wake up undercharged battery?)
          write(12, 3C, 03, 00) //Control1 = defaults
          write(12, 3D, 00, 66) //Control2
          write(12, 3E, 40, 23) //MinSystemVoltage = 9,024V
          write(12, 15, 90, 33) //MaxSystemVoltage = 13,200V
          write(12, 47, 00, 19) //ACProchot# = 6,400A
          write(12, 48, 00, 14) //DCProchot# = 5,120A
          write(12, 4C, 80, C0) //Control3 = autonomous charging, disable ACLIM reload
          write(16) //attempt to communicate with battery - failed
          // disable charging and run directly from AC adapter (bypass)
          write(12, 47, 33, 07) //ACProchot# = 1,843A
          write(12, 14, 00, 00) //ChargeCurrentLimit = 0
          write(12, 3E, 00, 00) //MinSystemVoltage = 0
          write(12, 3F, C0, 17) //AdapterCurrentLimit1 = 6,080A
          write(12, 39, 40, 00) //Control0
          write(12, 4C, 01, 03) //Control3
          write(12, 3C, 43, 01) //Control1 = BGATE off, freq=1020kHz
          write(12, 15, 80, 47) //MaxSystemVoltage = 18,304V
          write(12, 39, 40, 08) //Control0 = BYPASS on
          //status read
          write(12, 3A) read(13, 28, 80) //Information1 == 0x8028
          write(12, 3A) read(13, 28, 80)...repeats forever
          All numbers are in hex.
          The bytes are in wire order - lowest byte first.
          "write(12, FE) read(13, 49, 00)" means that register 0xFE of device 0x12 is selected by a write and the read returned 0x0049.
          0x12/0x13 is the ISL9241, 0x16/0x17 is the battery
          • mon2
            • 14662
            Do you have a similar log for the case when the battery is connected?
            Do you see more smbus traffic for the battery slave node address of 0x16 when the battery is connected?
            Do compare with the original and replacement battery.
            Perhaps the BMS module inside the replacement battery is defective. The BMS module replies to the 0x16 node address.
            • Rainbow
              • Aug 2005
              • 1375
              Plugged original battery with charger already plugged:
              Code:
              //...status read
              //EC detected battery presence, tries communication
              write(16)
              write(16)
              write(16)
              write(16)
              write(16)
              write(16)
              write(16)
              write(16)
              //battery communication works now
              write(16, 08) read(17, 8C, 0B) //bat. temperature == 22.45C
              write(16, 0D) read(17, 08, 00) //bat. RelativeStateOfCharge == 8%
              write(16, 19) read(17, 1E, 2D) //bat. DesignVoltage == 11,550V
              write(16, 18) read(17, 70, 1C) //bat. DesignCapacity == 7280mAh
              write(16, 0F) read(17, ED, 01) //bat. RemainingCapacity == 492mAh
              write(16, 10) read(17, 2C, 19) //bat. FullChargeCapacity == 6444mAh
              write(16, 16) read(17, C0, 02) //bat. status == 0x02C0 (discharging, initialized, remaining capacity alarm)
              write(16, 1C) read(17, 76, 04) //bat. SerialNumber == 1142
              write(16, 14) read(17, 00, 00) //bat. ChargingCurrent == 0 (battery not ready yet?)
              write(16, 15) read(17, 00, 00) //bat. ChargingVoltage == 0 (battery not ready yet?)
              write(16, 0C) read(17, 01, 00) //bat. MaxError == 1%
              write(16, 17) read(17, BA, 00) //bat. CycleCount == 186
              write(16, 1B) read(17, 82, 4D) //bat. ManufactureDate == 2018-12-02
              write(16, 1A) read(17, 31, 00) //bat. SpecificationInfo
              write(16, 22) read(17, 04, 4C, 49, 4F, 4E) //bat. DeviceChemistry == LION
              write(16, 21) read(17, 09, 53, 55, 30, 36, 30, 38, 34, 58, 4C) // bat. DeviceName == SU06084XL
              write(16, 70) read(17, 10, 36, 48, 4B, 42, 52, 30, 35, 54, 5A, 42, 4D, 34, 4D, 34, 00, 01) //bat. ??? == 6HKBR05TZBM4M4
              write(16, 20) read(17, 0B, 33, 33, 33, 2D, 32, 37, 2D, 30, 39, 2D, 41) //bat. ManufacturerName == 333-27-09-A
              write(16, 00, 53, 00) //bat. mfg. access
              write(16, 23) read(17, 04, 00, 00, 00, 00) //bat. mfg. data
              write(16, 3F) read(17, 75, 0E) //bat. cell 1 voltage == 3,701V
              write(16, 3E) read(17, 73, 0E) //bat. cell 2 voltage == 3,699V
              write(16, 3D) read(17, 73, 0E) //bat. cell 3 voltagee == 3,699V
              write(16, 0A) read(17, 00, 00) //bat. current == 0A
              write(16, 09) read(17, 59, 2B) //bat. voltage == 11,097V
              write(16, 08) read(17, 83, 0B) //bat. temperature == 21,55C
              write(16, 14) read(17, 38, 0E) //bat. ChargingCurrent == 3,640A
              write(16, 15) read(17, 90, 33) //bat. ChargingVoltage == 13,200V
              ...this cycle repeats forever, looks like regular status check
              Communication and data look good.
              No signs of charger setup, however. Maybe the EC does not support battery hot-plug (battery is not user-removable).
              • mon2
                • 14662
                I see writes to smbus node address 0x12 in the last log. Is that not the charger IC address?
                But same looping of packets??
                Do you see an esd tvs diode near the battery connector?
                If yes, remove it and test again.
                • mon2
                  • 14662
                  Q: how are you parsing the smbus captured logs?
                  Logs look very nice.
                  What is the EC trying to read from the charger IC?
                  • Rainbow
                    • Aug 2005
                    • 1375
                    No diodes near battery connector.
                    I'm using sigrok-cli with fx2lafw, decoding using sigrok's i2c decoder and parsing the output using my script.
                    EC is reading the charger status register (Information1). It's probably normal - run repeatedly by some kind of timer inside EC as it's inserted even between battery register reads.
                    • mon2
                      • 14662
                      Very nice setup.
                      Are you able to detect if the charger IC is timing out AFTER the battery is attached?
                      That is, why does the charger IC not proceed to charge the battery after these handshakes?
                      Are the logs the same using the other battery?
                      I would not expect the battery support to be hot swap capable.
                      With no power -> can you confirm that the battery linked mosfets are not leaking?
                      Check across the source / drain / gate pins to see if there is a low resistance.
                      Perhaps you have a leaky battery mosfet? Each mosfet should be inspected.
                      This bus analyzer is gold for this review.
                      • mon2
                        • 14662
                        Should have asked earlier - can you link or post the schematic?
                        • Rainbow
                          • Aug 2005
                          • 1375
                          All 6 MOSFETs around the charger are good.
                          Haven't found the schematic anywhere. At least ILS9241 datasheet is available.
                          • Rainbow
                            • Aug 2005
                            • 1375
                            Noticed somethg weird:
                            When I plug the battery in, the battery MOSFET (controlled by BGATE) turns on. That's OK. Then I plug the adapter in and the battery MOSFET turns off. Still OK. But after unplugging adpater, the MOSFET never turns on again. Laptop then runs on-battery only through the MOSFET's diode.
                            • mon2
                              • 14662
                              Replace the battery mosfet and test again.
                              • Rainbow
                                • Aug 2005
                                • 1375
                                Also when I plug the AC adapter for the first time (since battery plugged in), I get a voltage around 11V on the charger coil for a fraction of second. The battery MOSFET also turns on for a fraction second. That's probably the moment when EC enables charging. And disables it 22ms later for unknown reason. Since it's not obvious from SMBUS communication, the signal probably goes through some other way, probably some other pin.
                                But as the schematic is not available, I could only check ISL9241 outputs and then give this up.
                                • mon2
                                  • 14662
                                  Or the charger IC enters shutdown mode autonomously due to excessive current draw on this leg of the circuit.
                                  What if..you remove the battery mosfet. Do you still see the ON and suddenly OFF even for the battery charge voltage?
                                  What are the details of the battery mosfet GATE voltage under the same conditions (with the battery mosfet removed) ?
                                  Would you have spare ISL9241 devices? They appear to be available from Digikey / Mouser and also Aliexpress.
                                  https://www.aliexpress.com/item/1005...d=YJ3ehHJalZaC
                                  What would be gold to have right now is a good log of the same SMBUS traffic from a working model of the same laptop.
                                  • Rainbow
                                    • Aug 2005
                                    • 1375
                                    I have neither replacement MOSFETs nor ISL9241.
                                    Not spending any more time on this crap.
                                    • Rainbow
                                      • Aug 2005
                                      • 1375
                                      The story continues. I've got a replacement board ("used, tested") and guess what?
                                      IT FUCKING DOES NOT CHARGE.
                                      • reformatt
                                        • Feb 2020
                                        • 1495
                                        Might sound a bit silly, but have you tried a different charging jack?
                                        • coasterghost
                                          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                          by coasterghost
                                          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                          System Hardware:
                                          Processor: AMD Ryzen 7 PRO 5850U
                                          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                          09-08-2025, 10:46 PM
                                          HP ProBook x360 Pro x360 Fortis 11 inch G9 Notebook PC Hybrid (2-in-1) Specification for Upgrade or Repair
                                          This specification for the HP ProBook x360 Pro x360 Fortis 11 inch G9 Notebook PC Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pro x360 Fortis 11 inch G9 Notebook PC boardview and Pro x360 Fortis 11 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
                                          09-07-2024, 05:50 AM
                                          HP Pavilion x360 Pavilion x360 - 14-dh1000na Hybrid (2-in-1) 14 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion x360 Pavilion x360 - 14-dh1000na Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion x360 - 14-dh1000na boardview and Pavilion x360 - 14-dh1000na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          09-06-2024, 03:30 PM
