Asus Nitro 5 N20C1 dead
  • BalkanBoy
    • Feb 2017
    • 69
    • Croatia
    Re: Asus Nitro 5 N20C1 dead
    Check CPU and GPU capacitors, I marked them on your photo. In most cases they go bad, usually CPU ones but I bet that on your motherboard could be GPU as well. That poor laptop was tortured.
    I also do gaming on laptops but I always watch the temperatures and I lower the details or undervolt if possible, but you are obviously always above 90 degrees, at least your board looks like it.
    • vpower
      • Sep 2022
      • 111
      • italy
      Just checked, all the caps you marked are shorted to ground on both sides. Every single one.
      • mon2
        • Dec 2019
        • 14118
        Use the lowest resistance scale on your meter. Remove all power.
        Check the resistance again using this setting. It is possible that the resistance is low as it is a low voltage rail. Post your readings.
        • vpower
          • Sep 2022
          • 111
          • italy
          you mean the capacitors? in ohm mode I measure 1,9 - 2,0 ohm in every cap. The lowest scale on my meter is set in 200 ohm
          • BalkanBoy
            • Feb 2017
            • 69
            • Croatia
            Not all, just one is shorted but they are all parallel.
            Remove 2 biggest one under gpu and check them off the board, the 2 ones that looks most brownish. That part looks dodgy to me. If those are not shorted continue removing others till you find wich one is shorted.
            That's wrong way but maybe the only way since you got no proper equipment.
            • Sephir0th
              • Oct 2020
              • 1282
              It's a Gaming Laptop, so you're very likely dealing with a shorted high side. First put the current sense resistors back if not already done and then Check resistance between PRB3 and each coil on your board. Share the two lowest readings you get here, with coil designation. Good luck.
              FairRepair on YouTube
              • vpower
                • Sep 2022
                • 111
                • italy
                #27
                A little update about this repair.
                First of all, thanks everybody for the help provided.
                I finally bought a thermal camera and I found a shorted capacitor. You can see it, highlighted in the attached image. I removed it (without replacing), no more shorts, very nice
                I reassembled the laptop and tested. It is turning on but there is another problem: the laptop will not charge above 4%.It turns on,it stays on, even without battery, but with the battery I see the charging icon but no more than 4% after hours f charging.
                With the charger plugged in,on pin 7 and 8 of battery connector PJP201 I have:
                0.23v without the battery
                14.5v with the battery
                Maybe this problem is easier...any hint?
                Thanks in advance.
                • mon2
                  • Dec 2019
                  • 14118
                  Remove all power. Remove the battery.
                  Meter in DIODE mode.
                  Red meter probe, yes red to ground.
                  Black meter probe to the point to test.
                  Test each point on the battery connector.
                  Specifically interested in the SMBUS interface lines on the battery connector. It is possible the smbus lines are defective due to an ESD event which nukes the ESD tvs diode(s).
                  Post each measurement.
                  • vpower
                    • Sep 2022
                    • 111
                    • italy
                    #29
                    from the left to the right:
                    pin 1 and pin 2 shorted to ground
                    pin 3 .543
                    pin 4 .592
                    pin 5 1.064
                    pin 6 .492
                    pin 7 and pin 8 .520
                    • mon2
                      • Dec 2019
                      • 14118
                      These are good readings.
                      Is the battery partially charged? Is the battery pack able to power the laptop without the use of the external power adapter?
                      The next suggestion is to attach the battery and power adapter.
                      Then with extreme care, measure the voltage to ground of each pin on the charger IC @ PUB1.
                      Curious on the key pin voltages such as:
                      ACDET
                      ACDRV
                      REGN
                      ACOK
                      (with the battery & external power adapter connected)
                      Update:
                      Do also measure the voltage to ground of the battery connector pins with the battery & external power adapter mated to the logic board.
                      Post these readings.
                      • vpower
                        • Sep 2022
                        • 111
                        • italy
                        #31
                        the battery, when disconnected, has 0v measuring black and red.the laptop will not boot without the charger. with the charger it will boot and battery will be stuck at 4%
                        with both battery and charger connected,these are the readings on battery connector:
                        pin 3 to gnd 3.23v
                        pin 4 to gnd 3.23v
                        pin 5 to gnd 0.16v
                        pin 6 to gnd 0v
                        pin 7 & 8 to gnd 14.49v
                        tested without microscope but I thinc readings are correct:
                        ACDET 2.62v
                        ACDRV 0.10v
                        REGN 5.97v
                        ACOK 3.26v
                        • mon2
                          • Dec 2019
                          • 14118
                          ACDRV is not working. Often is the fault of the 2nd dcin mosfet. Please review the sticky article above by @Piernov.
                          Remove the 4k resistor on the ACDRV pin. Power up again. Then measure the ACDRV pin directly on the charger IC. Suspect is that the 2nd DCin mosfet is leaky.
                          You can check the mosfet by removing all power and checking the resistance across the mosfet pins. Search this forum for the details. This website should be renamed to badchargers.net. A low mosfet reading means the mosfet is defective.
                          • vpower
                            • Sep 2022
                            • 111
                            • italy
                            #33
                            you mean remove PRB7 and check PQB12, right? sorry I'm a noob
                            • vpower
                              • Sep 2022
                              • 111
                              • italy
                              #34
                              pin 3 to gnd 3.23v
                              pin 4 to gnd 3.23v
                              pin 5 to gnd 0.16v
                              pin 6 to gnd 0v
                              ACDET 2.62v
                              ACDRV 0.10v
                              REGN 5.97v
                              ACOK 3.26v
                              please ignore the reading about ACDRV. sorry. the correct reading is 19.81.
                              so I'm stuck...what do you think?
                              I also have a noob question about PRB3 and PRB46: since I desoldered and soldered back, I see on the diagram that those resistor have 4 pins each but I only see two, as a normal resistor. did I make something wrong?
                              • Sephir0th
                                • Oct 2020
                                • 1282
                                When ACDRV is reading 19V, one of your DC-IN Mosfets is internal shorted. Usually the second one. For N-Channel Mosfets Correct voltage would be around 25V at ACDRV.
                                • vpower
                                  • Sep 2022
                                  • 111
                                  • italy
                                  #36
                                  thank you. you mean the little mosfet named PQB12 right?
                                  • Sephir0th
                                    • Oct 2020
                                    • 1282
                                    First, remove power and confirm short between Source and Gate (or Drain and Gate). Then remove PQB12 and check at the other Mosfets (or empty pads where second mosfet belongs) whether the short persists or whether it is gone. If it is gone, replace it with a suitable one.
                                    • vpower
                                      • Sep 2022
                                      • 111
                                      • italy
                                      #38
                                      PQB12 has no shorts . instead, PQB11 (the first and bigger one) is shorted between pins 123 and 5678. I'm removing it and check if short is gone
                                        ACER NITRO Nitro N50-600 NITRO 50 i7-9700 Specification for Upgrade or Repair
                                        This specification for the ACER NITRO Nitro N50-600 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the NITRO Nitro N50-600 boardview and NITRO Nitro N50-600 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                        09-12-2024, 03:28 PM
                                        ACER NITRO Nitro GX50-600 NITRO 50 i5-8400 Specification for Upgrade or Repair
                                        This specification for the ACER NITRO Nitro GX50-600 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the NITRO Nitro GX50-600 boardview and NITRO Nitro GX50-600 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                        This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        09-07-2024, 04:10 AM
                                        Acer Nitro Nitro 5 AN515-57-775V Notebook 5 Specification for Upgrade or Repair
                                        This specification for the Acer Nitro Nitro 5 AN515-57-775V Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-57-775V boardview and Nitro 5 AN515-57-775V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                        Acer Nitro Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i5-11400H, 8GB, 512GB SSD, NVIDIA RTX 3050Ti, Full HD 144Hz, Windows 10, Black) Notebook 5 Specification for Upgrade or Repair
                                        This specification for the Acer Nitro Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i5-11400H, 8GB, 512GB SSD, NVIDIA RTX 3050Ti, Full HD 144Hz, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i5-11400H, 8GB, 512GB SSD, NVIDIA RTX 3050Ti, Full HD 144Hz, Windows 10, Black) boardview and Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i5-11400H, 8GB, 512GB SSD, NVIDIA RTX 3050Ti,...
                                        09-07-2024, 03:10 AM
