Asus Nitro 5 N20C1 dead
  • vpower
    • Sep 2022
    • 116
    • italy
    I'm trying to fix this Acer laptop, main board is FH52M LA-J891P
    The laptop suddenly turned off during normal use and this is the situation:
    -the power supply is working correctly, 19 volts output. But when I connect it to the laptop , no voltage on the charging connector. If I disconnect the charger, no more 19 volts output until I disconnect and reconnect again the the wall plug
    -the positive and the negative of the charging connector are not shorted
    I have a power supply, a multimeter and maybe a short finder, but still no thermal camera(I'm thinking about purchasing one).
    Any suggestion?
    Thanks in advance.
  • mon2
    • Dec 2019
    • 14661
    Re: Asus Nitro 5 N20C1 dead
    Connect the power adapter. Measure the voltage to ground on gate pin #4 of pqb11 or pqb12 = ACDRV voltage.
    • vpower
      • Sep 2022
      • 116
      • italy
      0,33 volts. slowly decreasing
      • myth77
        • Feb 2017
        • 380
        • Croatia
        you power supply is going to protection mode because the main power rail on motherboard is shorted. This board has strange design but i believe on PRB3 and PRB46 is you main power rail (first picture, near the power connector...upper right corner). Put multimeter on diode mode and on those resisters see if you have short to ground. Post back. if you have a hot air station remove them and post on which side is a short.
        • vpower
          • Sep 2022
          • 116
          • italy
          both PRB3 and PRB46 are shorted to ground on both sides
          • vpower
            • Sep 2022
            • 116
            • italy
            maybe these files I found in another thread could be useful
            • vpower
              • Sep 2022
              • 116
              • italy
              after removing PRB3 and PRB46 , only the right side is shorted to ground
              now wit both removed, 19 volts are found on charger connector, no more protection mode for the power supply
              • mon2
                • Dec 2019
                • 14661
                Is the laptop now working?
                • vpower
                  • Sep 2022
                  • 116
                  • italy
                  still dead.still no light when charger is plugged in.
                  • mon2
                    • Dec 2019
                    • 14661
                    See attached.
                    Measure the voltage to ground of the DCin mosfets.
                    Source (1-2-3)
                    Gate (4)
                    Drain (5-6-7-8)
                    Only if GATE voltage is ~25 volts will these N-channel mosfets enable.
                    • vpower
                      • Sep 2022
                      • 116
                      • italy
                      See attached.
                      Source (1-2-3)
                      Gate (4)
                      Drain (5-6-7-8)
                      during the measurements, I noticed a component becoming very hot: it's the PUB1, BQ 24780S is the name on it.Google search says "SMBus 1-4 cell Buck battery charge controller to support hybrid power boost mode"
                      do you think it is possible that the problem?
                      • vpower
                        • Sep 2022
                        • 116
                        • italy
                        See attached.
                        Source (1-2-3)
                        Gate (4)
                        Drain (5-6-7-8)
                        with charger inserted:
                        PQB11 has 19v on Source, Gate and Drain. Same with PQB12
                        PQB18 and PQB19 are not present in this board (factory empty)
                        PQB1 has 0.14v on source and gate. 0v on drain
                        PQB2 has 0v on source and gate. 0.14 on drain
                        PQB13 has 0.14 on source, 0.07 on gate and 0v on drain.
                        I think I tested all mosfets in the diagram
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          @myth77 has guided you on correct path.You have multiple problems here. Follow these steps
                          01. Check resistance for PQB11/12 between
                          Pin1-Pin4
                          PIN1-Pin8
                          Pin4-Pin8
                          One of them is definitely shorted and most likely its PQB11.
                          Then again check resistance on both pads of CLR. You may need to inject some voltage(not more then 1V) on the shorted side and see what's getting hot. You need a short killer/dc supply to do the job.
                          After solving these two issues check resistance on both pads of CLR again.
                          Report your findings.
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            Hey@mon2, With CLR removed, how will the board work?? I think you missed it in a hurry
                            • vpower
                              • Sep 2022
                              • 116
                              • italy
                              Pin1-Pin4
                              PIN1-Pin8
                              Pin4-Pin8
                              PQB11 between
                              Pin1-Pin4 72 ohm
                              PIN1-Pin8 3 ohm
                              Pin4-Pin8 72 ohm
                              PQB12 between
                              Pin1-Pin4 77ohm
                              PIN1-Pin8 open circuit (no resistance value)
                              Pin4-Pin8 open circuit (no resistance value)
                              I'm about to inject 1 volt on shorted side of removed CLR
                              • myth77
                                • Feb 2017
                                • 380
                                • Croatia
                                Inject 1 volt but max 1 amp...and see if anything gets hot. Do not change voltage..if you dont see/feel anything hot increase for half amp and so on. Use alcohol and focus first on mosfets near cpu and gpu.
                                • mcplslg123
                                  • Jun 2015
                                  • 7262
                                  • india
                                  PQB11 is shorted. Replace it and then check resistance on CLR again. I think it'll still show shorted and you need to inject voltage(not more then 1V) to find out whats getting warm.
                                  • vpower
                                    • Sep 2022
                                    • 116
                                    • italy
                                    I'm looking for the replacement mosfet. I read:
                                    6406
                                    BA8512
                                    but I cannot find any reference on eBay or AliExpress. any suggestion? thanks in advance
                                    • myth77
                                      • Feb 2017
                                      • 380
                                      • Croatia
                                      so you located shorted mosfet? did you remove it? short gone?
                                      You can find what model it is by opening board view, locate it...and then search in schematic what is exact mosfet info.
                                      • vpower
                                        • Sep 2022
                                        • 116
                                        • italy
                                        I've just removed PQB11 as mcplslg123 suggested yesterday. But after removing, the right side of PRB3 and PRB46 are still shorted to ground. Maybe PQB11 mosfet is not shorted? I'm going to inject 1 volt on right side of shorted PRBs to see if something gets hot. I still don't have a thermal cam.
                                        Ps sorry I'm a noob
                                          ACER NITRO Nitro GX50-600 NITRO 50 i5-8400 Specification for Upgrade or Repair
                                          This specification for the ACER NITRO Nitro GX50-600 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the NITRO Nitro GX50-600 boardview and NITRO Nitro GX50-600 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-12-2024, 03:28 PM
                                          ACER NITRO Nitro N50-600 NITRO 50 i7-9700 Specification for Upgrade or Repair
                                          This specification for the ACER NITRO Nitro N50-600 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the NITRO Nitro N50-600 boardview and NITRO Nitro N50-600 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          Acer Nitro Nitro 5 AN515-57-775V Notebook 5 Specification for Upgrade or Repair
                                          This specification for the Acer Nitro Nitro 5 AN515-57-775V Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-57-775V boardview and Nitro 5 AN515-57-775V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 04:10 AM
                                          Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                          This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          Acer Nitro Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i7-11800H, 16GB, 512GB SSD, NVIDIA RTX 3060, Full HD 144Hz, Windows 10, Black) Notebook 5 Specification for Upgrade or Repair
                                          This specification for the Acer Nitro Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i7-11800H, 16GB, 512GB SSD, NVIDIA RTX 3060, Full HD 144Hz, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i7-11800H, 16GB, 512GB SSD, NVIDIA RTX 3060, Full HD 144Hz, Windows 10, Black) boardview and Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i7-11800H, 16GB, 512GB SSD, NVIDIA RTX 3060,...
                                          09-07-2024, 03:10 AM
