MSI P65 Creator 9SE not booting after repair attempt
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    #41
    Re: MSI P65 Creator 9SE not booting after repair attempt
    Originally posted by reformatt
    You can't fix everything. Shorted PCH/CPU are the most common issues for most boards these days, despite what you see on YouTube.
    Very true.If its gaming board, then perhaps thats the norm rather then exception.
    • G33RT
      • Oct 2016
      • 66
      • Belgium
      #42
      You bet it is an exeption, it's an very expensive laptop and in mind condition.
      I have search around and a used mainboard is about $500 to $600 and even then you don't know what you get, a new mainboard is $1200 !
      Regards, Geert
      • reformatt
        • Feb 2020
        • 1398
        If you want to game, get a tower. The biggest issue with gaming laptops is heat dissipation. They use the same CPU/GPU's that a tower would use, but with substantially less thermals.
        There's a reason heatsinks have fins. It's to maximise the surface area for convection, and this requires airflow to remove the hot air out of the chassis. So when you get dust blocking the fan/fins, this reduces the thermal efficiency and the chips get way hotter. They pull more amps at the higher temps, and the MOSFET's then fail. Resulting in dead silicon, and a new motherboard, since lets face it, where are you getting CPU/GPU replacements from. Towers get away with dust, because the thermals are way bigger.
        Just a waste of money all ways round.
        • G33RT
          • Oct 2016
          • 66
          • Belgium
          #44
          I have a question about the GPU VRM controller uP9512Q
          If the IC got 5v on Pin-10 (5VCC) and 19v on pin-21 (VINMON) does it produce 2v out at Pin-17 (REFOUT) or does it first have to have the Enable on Pin-30 to have the 2v reference output working ?
          I include a typical application circuit of the uP9512Q
          https://www.badcaps.net/forum/attach...1&d=1680141951
          Regards, Geert
          • G33RT
            • Oct 2016
            • 66
            • Belgium
            #45
            The VINMON pin-21 is 1.9v not 19v
            Regards, Geert
            • G33RT
              • Oct 2016
              • 66
              • Belgium
              #46
              Update:
              I ended up ordering another mainboard.
              Ps. still I don't believe this is a total loss case.
              Regards, Geert
              • Manuel0970
                • Jan 2022
                • 4
                • Chile
                #47
                Hello, I know that in time but you were able to solve the problem, the same thing happens to me with the same driver that does not activate the vccore sources. The vr_svid_alert# pin 44 of the isl95855c driver is at 0, I changed the drmos but there was no change, you were able to solve
                • G33RT
                  • Oct 2016
                  • 66
                  • Belgium
                  #48
                  Did you change the isl95855c chip ?
                  I was not able to solve, however I still have te board here and when I have the time I will look into it again as I don't believe the CPU is really dead.
                  The reason I say this is that I was having the board running with all voltages available for about 20 to 30 seconds.
                  I have replaced the board with the same mainboard number but it was a GS65 Stealth version not the P65 Creator SE.
                  I also have made some notes of voltages of the replacement board and could be interesting for future investigations ;-)
                  I have had to move over a transistor and keyboard backlight connector and update the EC firmware to get the keyboard light working.
                  Regards, Geert
                  • Manuel0970
                    • Jan 2022
                    • 4
                    • Chile
                    #49
                    on't think the CPU on my board is shorted either, it was the same sic631 fault and I injected voltage into that 1v coil and there is no short, the voltage does not go down in theory if it had caused a short the drmos would have damaged the part of the cpu that powers that source I mean that when it detects voltage it should drop if it were shorted the vr_svid_alert# signal is sent by the isl95855 I have not found a block diagram of this ic to see what signals it needs to give the svid_alert at a high level if you find something new Please let me know and thank you for responding despite the time of your publication.
                    • Sephir0th
                      • Oct 2020
                      • 1256
                      The thing is, that most of the people either don't want to or simply can't realize, in how many ways a complicated semiconductor can fail. A clear short to GND is the easiest diagnostic that can happen. But often enough you can get a dead BGA with just a almost unnoticeable partial short or even no obvious signs at all.
                      For SVID communication you need at least all previous basic requirements met. For the VRM Controller they are the input voltages (VIN, VCC, etc) and enables at least. And of course, SVID Clock and SVID Data.
                      For the CPU, the same. All required signals and prower rails regarding the power up sequence have to be present.
                      However, even if you replace all parts in question (except the CPU) you can't do anything if the CPU simply doesn't request voltage via the SVID anymore. And this is most often the case.
                      FairRepair on YouTube
                      • G33RT
                        • Oct 2016
                        • 66
                        • Belgium
                        #51
                        You want a diagram of ISL95855, here you go:
                        Regards, Geert
                        • Manuel0970
                          • Jan 2022
                          • 4
                          • Chile
                          #52
                          Does anyone have bios for this notebook since it arrived manipulated and I could not find the model, it is msi p65 creator 9se
                          • G33RT
                            • Oct 2016
                            • 66
                            • Belgium
                            #53
                            Best way is to open an bios request in the appropriate forum section.
                            Regards, Geert
                              • 20318
                              Reminder: rules and organization of this section - https://www.badcaps.net/forum/showthread.php?t=117483
                                MSI Creator Creator P100X 10SE-203EU Creator i9-10900K Specification for Upgrade or Repair
                                This specification for the MSI Creator Creator P100X 10SE-203EU can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Creator Creator P100X 10SE-203EU boardview and Creator Creator P100X 10SE-203EU schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                09-12-2024, 03:28 PM
                                MSI Creator Creator P100X 10SF-201EU Creator i9-10900K Specification for Upgrade or Repair
                                This specification for the MSI Creator Creator P100X 10SF-201EU can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Creator Creator P100X 10SF-201EU boardview and Creator Creator P100X 10SF-201EU schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                MSI Creator Creator P100X 10SF-212MYS Creator i9-10900K Specification for Upgrade or Repair
                                This specification for the MSI Creator Creator P100X 10SF-212MYS can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Creator Creator P100X 10SF-212MYS boardview and Creator Creator P100X 10SF-212MYS schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                MSI Creator Creator P100X 10SE-211MYS Creator i9-10900K Specification for Upgrade or Repair
                                This specification for the MSI Creator Creator P100X 10SE-211MYS can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Creator Creator P100X 10SE-211MYS boardview and Creator Creator P100X 10SE-211MYS schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                MSI Creator Creator 15M A9SE-066RU Notebook 15M Specification for Upgrade or Repair
                                This specification for the MSI Creator Creator 15M A9SE-066RU Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Creator 15M A9SE-066RU boardview and Creator 15M A9SE-066RU schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                09-06-2024, 02:34 PM
