Macbook Air A1466 820-00165 green light no fan spin
  • kingskie
    • Oct 2014
    • 249
    • indonesia
    Hi All,
    I got macbook air 820-00165 with green light but no fan spin.
    Measurements:
    PPBUS_G3H = 8.14V
    PP3V3_S5 = 0V
    PP5V_S5 = 0V
    SMC_WAKE_L = 3.12V
    SMC_ONOFF_L = 3.4V
    SMC_RESET_L = 3.38V
    should i change the U7501 first?
  • mon2
    • Dec 2019
    • 14267
    Re: Macbook Air A1466 820-00165 green light no fan spin
    No, measure the voltage to ground of:
    SMBUS_SMC_5_G3_SCL
    SMBUS_SMC_5_G3_SDA
    Post the measurements.
    • kingskie
      • Oct 2014
      • 249
      • indonesia
      Originally posted by mon2
      no, measure the voltage to ground of:
      smbus_smc_5_g3_scl
      smbus_smc_5_g3_sda
      post the measurements.
      smbus_smc_5_g3_scl = 0.492
      smbus_smc_5_g3_sda = 0.491
      • mon2
        • Dec 2019
        • 14267
        I think you are in DIODE mode?
        Meter in DC volts (10 volts or higher).
        Red meter probe to point to test.
        Black meter probe to ground (shield is ok).
        Post each voltage measurement.
        • kingskie
          • Oct 2014
          • 249
          • indonesia
          sorry @mon2 it is 3.4V for both
          • mon2
            • Dec 2019
            • 14267
            Voltage is correct and confirms the required pull-up resistors are present.
            The SMC has to communicate with the ISL chip to boost the ppbus_g3h voltage. Your voltage is lower so this event did not take place. Communication is over these SMBUS lines.
            Remove all power. Meter in resistance mode.
            Place one probe on a point closest to the ISL chip to measure the smbus_smc_5_g3_scl line. Other meter probe to a point closest to the SMC chip, same line to test. Sometimes, with liquid damage / corrosion, the trace is broken for these interface lines. So you can see the 3v4 but the smc is unable to communicate with the ppbus_g3h ISL chip. Confirm that the traces are not broken with a resistance check. If your meter beeps a tone in diode mode, you can use it for the same purpose.
            • kingskie
              • Oct 2014
              • 249
              • indonesia
              i measure both path and all beeps. should i change the ISL chip?
              the SMC_BC_ACOK is 3.38V. normally should be 3.42V right?
              N.B
              there is no sign of liquid damage or corrosion
              • kingskie
                • Oct 2014
                • 249
                • indonesia
                anyone can help?
                • reformatt
                  • Feb 2020
                  • 1416
                  If PPBUS_G3H is 8.1V, then your ISL is working fine. It should be 8.6V (with no battery attached) when the SMC is properly running. So 8.1V means your issue is the SMC.
                  Check J6100 first for corrosion/crap or any bug shit that is bridging pins. If ok, then check around U5110 (provides SMC_RESET_L and PP3V3_S5_AVREF_SMC), presence of the latter at L5001. Check C5002 for presence of PP3V42_G3H, C5010 for PP1V2_S5_SMC_VDDC. These are the basic areas to check before anything else.
                  • reformatt
                    • Feb 2020
                    • 1416
                    Well thinking about it, PPBUS_G3H should be 8.3V without the SMC. So just double check that (make sure battery is not connected).
                    • astrotek
                      • Oct 2022
                      • 3
                      • Philippines
                      Originally posted by kingskie
                      Hi All,
                      Measurements:
                      PPBUS_G3H = 8.14V
                      PP3V3_S5 = 0V
                      PP5V_S5 = 0V
                      SMC_WAKE_L = 3.12V
                      SMC_ONOFF_L = 3.4V
                      SMC_RESET_L = 3.38V
                      Thats probably a SMC IC ISSUE = PPBUS_G3H it should be 8.6V
                      • joeoffice12
                        MacBook Air (2017, A1466, No power/orange-green light on)
                        by joeoffice12
                        I have a 13 inch MacBook Air 2017 that does not show any life, however, there is activity from the MagSafe light going from green to orange and staying. Normally, this battery works perfectly fine and it can actually charge the battery as if I were to leave it alone it would change to just green, however, this thing does not boot up at all, I was told the computer was at 30% and then it randomly shut off.
                        Some voltages:
                        PPBUS_G3H - 8.5V
                        SMC_PM_G2_EN - 3.42V
                        PP3V3_S5 - 3.32V
                        PP3V42_G3H - 3.42V
                        PPDCIN_G3H - 15.18V
                        PP5V_S5 - 5.04V
                        PP3V3_S5_REG_R...
                        12-15-2023, 04:00 PM
                      • xalapamac
                        Macbook air 820 - 00165 fan spin, PPVCC_S0_CPU present, No green Light, No Chime
                        by xalapamac
                        Hello, greetings everyone. I NEED YOUR HELP
                        I got this macbook that doesn't turn on, I don´t have a green light, but it's got a fan spin for a few minutes and after it's off.
                        This macbook comes in without damage from liquid spill.
                        The story of the Mac is that the screen closes and left without use for two days. Then they try to turn on and it won't turn on. Then they connect the charger and it doesn't give light.
                        It´s a Macbook Air 2017
                        Please help me understand how this works... Correct me if I'm wrong in my way of...
                        01-09-2021, 12:31 AM
                      • psdavid65
                        Macbook Air A1466 820-3437-B Booting Problem
                        by psdavid65
                        I received a 2013 Macbook Air A1466 820-3437-B motherboard with serial number C02L6GQ9FSV8 that came in WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?...
                        06-20-2024, 12:27 AM
                      • echothegamer
                        Macbook A1466 dies when charger disconnected
                        by echothegamer
                        Hello all,
                        Working on my wife's 13' Macbook air. It's been in a box since she upgraded but I figured it could be good practice.
                        Details:
                        Macbook 13' A1466
                        Board (820-3209-A)
                        Battery OEM 7.3v 50Wh 6700 mAh (020-7379-A)
                        Pictures below of Boardview and schematic...
                        I don't know how to test the voltage on a MacBook battery. I just assumed it had an enable pin but the best I could read was 300 something mV poking around the battery connector.
                        It's an older model and it is very likely that battery has become...
                        10-28-2023, 12:00 PM
                        Acer Spin Spin 511 R753TN Chromebook Specification for Upgrade or Repair
                        This specification for the Acer Spin Spin 511 R753TN Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spin 511 R753TN boardview and Spin 511 R753TN schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                        09-07-2024, 02:20 AM
