Asus A555LF (X555LD Rev.3.6 Board) Not Turning On With Power Button
  • kodox
    • Jul 2017
    • 329
    • Indonesia
    the board (yes, just the motherboard & daughter board) came to my desk with shorted ITE8585E, after ordered a programmed ITE and placing it on motherboard it turned on immediately, using HDMI i confirm that the boot entering the bios since there is no bootable drive attached. then i turned off by unplugging the DC adapter, while preparing keyboard, mouse & some flashdrive to boot into.
    after all plugged (including adapter) the board doesn't "auto turn on" like before, pressing power button with no change. without unplugging anything i'm checking voltages needed for turned on and it's all there.
    before flashing the bios, i then reflow the ITE8585E then check all 128 pin one by one to confirm it soldered properly to the board and all pass, try pluged in dc adapter still doesn't turn on, no excesive heat generated after replacing the ITE before and after reflowing with hot air.
    after searching for bios, i can't found for X555LF version, all have X555LA or X555LAB version, so i decided to try edit it from asus website and the board back to life and able to boot to flashdrive i've plugged without error
    but the main problem still exist, it can't turn on after turned off, no matter from window or linux or from power button i turn it off, it won't turned on again by pressing power button, EXCEPT if i unplug then plugged the adapter it will turn on, already tried the solution from https://www.badcaps.net/forum/showpo...16&postcount=3 and still the same
    did i miss something here?
    it's been almost a week with no progress, please help...
    let me know when you need the bios
  • mon2
    • Dec 2019
    • 14725
    Re: Asus A555LF (X555LD Rev.3.6 Board) Not Turning On With Power Button
    1) post or link the schematic if available.
    2) review the usual 2*DCin mosfets to check if they are leaking. Which charger IC is onboard?
    • kodox
      • Jul 2017
      • 329
      • Indonesia
      1) sorry my bad, i used schematic from https://www.badcaps.net/forum/showth...ghlight=x555ld
      2) 2*DCin mosfet is at Mega Ohm range on my meter (Gate-Source, Gate-Drain, Source-Drain). it use BQ735 for charger IC
      • mon2
        • Dec 2019
        • 14725
        See attached.
        Confirm that PWR_SW# indeed goes to logic LOW when pressed; logic high otherwise. This is an active LOW signal to toggle the ON / OFF status of the logic board.
        If the default pull-up resistor is missing or defective, this could be a fault.
        • kodox
          • Jul 2017
          • 329
          • Indonesia
          power sequence, yes, that's i've been looking for
          PWR_SW# is working as it should, on power button pin and pin 110 of ITE8585E. it has 3.2V when not pressing power button and 0V when pressing power button
          • kodox
            • Jul 2017
            • 329
            • Indonesia
            anyone?
            please....
            • mon2
              • Dec 2019
              • 14725
              When it turns on, the operation is normal with video?
              • Sephir0th
                • Oct 2020
                • 1289
                I would also consider a bad SPI flash in a weird case like that.
                FairRepair on YouTube
                • reformatt
                  • Feb 2020
                  • 1535
                  Are you confident your vendor put the right EC code on your ITE?
                  • Pasglop
                    • Mar 2021
                    • 32
                    • France
                    Hello
                    I have boot problem on Asus zenbook pro duo UX581gv, the on/off button works (3v2 / 0) but it's don't boot, I will need the diagram if possible, thank you in advance.
                    • kodox
                      • Jul 2017
                      • 329
                      • Indonesia
                      yes, it's operate normally. even a windows 10 installation have no issue
                      Hmmm....
                      didn't think about that, i'll try it though
                      yes, because before flashing he ask about the exact model number on the sticker (X555LF)
                      • kodox
                        • Jul 2017
                        • 329
                        • Indonesia
                        tried changing SPI chip with fresh one (same model numberof SPI chip) but nothing change, but when i try accessing Easy Flash menu from bios the laptop restart, and i try download Bios-Utility from asus website (https://www.asus.com/id/supportonly/...desk_download/) the installer detected that it's not an asus laptop!
                        any ideas...?
                        • reformatt
                          • Feb 2020
                          • 1535
                          IIRC, you have to have one of the other Asus utlities installed for the Windows BIOS update tool to recognise it as an Asus system. ATK package or something like that.
                          Failing that, dump out your BIOS and upload it to the BIOS group for someone to repair it.
                          • kodox
                            • Jul 2017
                            • 329
                            • Indonesia
                            finally after long duration of brain storming, the problem solved guys!!!!
                            so, this is what i've done. in case someone had a same or similiar issue
                            flashing the original SPI chip with the lowest version of bios from asus website for the model, after installed the chip & restoring default on bios menu then i fresh install win 10 pro. without installing any driver needed then i try installing the Bios-Utility with result on post #12
                            after failed install the Bios-Utility then i re-download latest bios version from asus website and saved it on the hard drive, then i access Easy Flash from bios menu and it didn't restart like before. with finger crossed i waited until flashing process completed and it did. after restart, i forget to enter the bios to access the restore default menu.
                            so i let the windows boot to desktop and wait until no hard drive led activity, still with finger crossed then i shutdown the system. then i press power button and it TURNED ON!!! immediatelly pressing F2 to enter bios and confirmed that the version is the same with latest version on asus website, after restoring default then i let the windows to boot and repeat the shutdown - turn on without issue.
                            thank's for all your help guys, i think admin can change the title as "solved" or something like that
                            just wandering, what was happened actually?
                            • Sephir0th
                              • Oct 2020
                              • 1289
                              Good job, man. I like it when someone is persistent like that. *thumbs up*
