ASUS/ROG GL553V replacement mosfet
  • Jenzo
    • Jul 2019
    • 135
    • Belgium
    Hi, the circled mosfet on the added picture gets really hot and measures short, but I'm having issues finding a replacement.
    The mosfet reads:
    4843NS
    RSBD2
    Thanx in advance!
  • mon2
    • Dec 2019
    • 14801
    Re: ASUS/ROG GL553V replacement mosfet
    Remove the mosfet off the logic board. Test again the resistance across this mosfet's leads to see if it is shorted or not.
    The mosfet is a common N-channel 5*6 mm style that can be found on most motherboards. Review the 2*DCin mosfets on other motherboards. Often from AON and the charger IC will be the 'BQ' style from Texas Instruments. They will be a drop in replacement.
    Post the part numbers of other mosfets you have available to you. Otherwise you can order from Digikey or Mouser or AliExpress.
    • Jenzo
      • Jul 2019
      • 135
      • Belgium
      0 resistance between source/drain, it's completely shorted. Could you link me one from mouser for example? I'm not that familiar with these, normally I only work on macbooks :'). Thanx in advance!
      • mon2
        • Dec 2019
        • 14801
        Sure. After dropping off junior to the mall, will locate a valid sub. Any chance you have any donor boards of any brand?
        • Jenzo
          • Jul 2019
          • 135
          • Belgium
          Cool, thanx in advance! The only ones I have available are Apple (mainly from A1278 and A1466 devices), no other brands.
          • mon2
            • Dec 2019
            • 14801
            See attached:
            https://www.mouser.ca/ProductDetail/...F2SxSPZw%3D%3D
            • Jenzo
              • Jul 2019
              • 135
              • Belgium
              Thank you!
              The original was SOP-8 format, this doesn't matter as long as it fits I'm guessing?
              • mon2
                • Dec 2019
                • 14801
                Sop-8 = 8 pin package. It is the same size and the same pinout as the original.
                • Jenzo
                  • Jul 2019
                  • 135
                  • Belgium
                  Thank you very much!
                  • AppleLover123
                    Asus X712EA 3 volts after the first mosfet
                    by AppleLover123
                    Hey guys,
                    i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
                    I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
                    Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
                    I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
                    Now i thought something...
                    12-15-2024, 07:49 AM
                  • Scotchmist
                    Asus GA502D keeps blowing mosfet
                    by Scotchmist
                    I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
                    I have removed the mosfet and can run the laptop no problem
                    The MOSFET is FDPC5018SG
                    Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
                    08-24-2024, 02:23 PM
                  • someonenotyou
                    ASUS G513R - cannot remove MOSFET
                    by someonenotyou
                    Hi.
                    I have a ASUS G513R laptop with shorted MOSFET (MP86959GMW-Z 45A).
                    I tried to preheat the board to 200C brom the bottom and with rework station set to 400C I flowed it for about 2min. The MOSFET does not come off.
                    Of course, I did not force it, but tried to lift it up with tweezers.
                    Is it possible, that these MOSFETs are glues to the board? Or it got welded to the board from the short? It looks intact, no signs of blowing up.
                    10-10-2025, 11:05 AM
                  • dhenion
                    Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
                    by dhenion
                    I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
                    The original board was:
                    ASUS X510UNR REV 3.0 A
                    The replacement board is:
                    ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
                    It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
                    01-30-2024, 01:45 PM
                  • Timp74
                    Odd MOSFET only on some ASUS x99/x299/z370 motherboards..
                    by Timp74
                    Hi All,
                    Could anyone comment on the purpose of the MOSFET circled in red in the attached photo of an ASUS ROG X299 Extreme VRM?
                    I'm trying to fix an ASUS motherboard(WS x299 SAGE) with a similar VRM where this MOSFET has burnt out along with one of the IR3555m driver chips. From looking at photos of motherboard VRMs on the internet, it seems only some ASUS motherboards have a MOSFET like this. Although I've seen some photos of ASUS z370 boards where it's not populated. The MOSFET is usually a NTMFS4C06N. It has its drain connected to the output of the Vcore VRM, and on...
                    08-13-2021, 01:11 PM
