PRECISION 3510 BSoD when installing windows
  • kuraimangetsu
    • Nov 2022
    • 77
    • iraq
    Hi.
    I received a dell precision 3510.
    works fine on bios
    but i always get a BSoD when installing windows 7-10-11 64-86 uefi or legacy.
    tried changing RAM and swap slots.
    changed the M.2 to new one too.
    tried like 15 different OS! same thing! still getting BSoD when installing windows.
    tried hirens BOOT, but still getting system crash after two minutes.
    even tried linux still getting crash while installing
    tried updating bios and downgrading it same thing
    is reflashing new bios straight to the IC is different from updating it?!
    or maybe it's another hardware problem?
  • jiroy
    • Jun 2016
    • 2416
    • Lebanon
    Re: PRECISION 3510 BSoD when installing windows
    Originally posted by kuraimangetsu
    Hi.
    works fine on bios
    Were you at any point able to launch the Windows Event Viewer ?
    • mon2
      • Dec 2019
      • 14342
      On the BSOD, the offending device / driver will be shown in the screen.
      Can you take a pic of this BSOD screen and post it here?
      • jiroy
        • Jun 2016
        • 2416
        • Lebanon
        That was my next question ..
        • mon2
          • Dec 2019
          • 14342
          @jiroy I see Lebanon and I think of falafels. Yum!! Getting close to my lunchtime
          • kuraimangetsu
            • Nov 2022
            • 77
            • iraq
            No. I couldn't.
            • kuraimangetsu
              • Nov 2022
              • 77
              • iraq
              It didn't! That why am asking here. And am suspecting the CPU CHIP
              Will post it when i get to the office
              • jiroy
                • Jun 2016
                • 2416
                • Lebanon
                You're the most welcome anytime ..
                • jiroy
                  • Jun 2016
                  • 2416
                  • Lebanon
                  Okay . Any specific reasons why you suspect the CPU ? ..Did you try for instance to check for a fix in Dell's site .
                  • kuraimangetsu
                    • Nov 2022
                    • 77
                    • iraq
                    Dell site? the only things they give is the make sure of the
                    -secure boot enabled
                    -and UEFI
                    -disable legacy roms
                    or to take it to Dell facility or something like that
                    i suspects the CPU because in both windows and linux
                    i get BsOD OR just stuck there doing nothing
                    like now it's stuck on installing updates
                    or before it stuck on getting files ready for installation 77%
                    tried different types of flash drives even optical drives
                    attached a photo
                    • kuraimangetsu
                      • Nov 2022
                      • 77
                      • iraq
                      after downgrading the bios to the Recommended ver which is 1.31
                      i still get the BsOD but it's now shows the
                      Wof.sys as the failed thing
                      attached img
                      • jiroy
                        • Jun 2016
                        • 2416
                        • Lebanon
                        attached img
                        I fully understand your frustration at Dell , trust me on that . All I can help you right now is to tell you that VGA driver in some of their models was the culprit ..Sometimes they put a fix , but all I find later is more frustrated people . Just so to be sure , try not to install the VGA driver , (It's difficult , I know), and see if the BSODs disappear .
                        • kuraimangetsu
                          • Nov 2022
                          • 77
                          • iraq
                          you mean removing the driver pack from the windows ISO file?
                          so that it's wont install the VGA driver with the windows installation?
                          caus, i did that with both windows 7 and 10. same BsOD
                          or you mean i don't install the driver after windows installation (caus i cant get pass the windows installation even!!)
                          I just desolderd the bios IC and will try older bios dump ver 1.19
                          will update after flashing
                          updated: same wof.sys error when installing
                          Last edited by kuraimangetsu; 01-05-2023, 02:25 AM. Reason: after flashing new bios IC
                          • kuraimangetsu
                            • Nov 2022
                            • 77
                            • iraq
                            after changing the bios dump again
                            still gives me the BsOD
                            but it's different stop code now
                            • kuraimangetsu
                              • Nov 2022
                              • 77
                              • iraq
                              did a memtest86 everything passed good
                              Tried few other versions of windows and settings
                              i get different stop codes when installing windows such as
                              -memory management
                              -bad pool caller
                              that's why i think it's more of a hardware problem!!
                              • jiroy
                                • Jun 2016
                                • 2416
                                • Lebanon
                                Something like that .. It would have been easier if you were working on a Desktop . Supply an external VGA and disable on board VGA ..Evenmore , if you have dual VGA in a laptop , you can simply (well , not that much ,it has some procedures to make) disable the culprit one .
                                Keep us updated anyway , you're doing good job .
                                • kuraimangetsu
                                  • Nov 2022
                                  • 77
                                  • iraq
                                  Hi again.
                                  just cleared the ME from the original bios bin backup. and it's works fine now
                                  i don't know what that have to do with anything, really!!
                                  but after the bios flash with the CLEARED ME bin file
                                  tried it with legacy and uefi windows 10 and installed 10\10 no problems!
                                  • jiroy
                                    • Jun 2016
                                    • 2416
                                    • Lebanon
                                    Hi again.
                                    I knew it wasn't the CPU , Those problems weren''t CPUs ones anyway . Excellent job and thanks for the update ..
                                    • s_henya
                                      • Jan 2011
                                      • 482
                                      • Israel
                                      Hi again.
                                      Hi were you able to install the AMD Display driver properly?
                                      i have the same unit and getting issues once windows auto install this driver.
                                      • swammyw
                                        • Apr 2021
                                        • 66
                                        • finland
                                        Hi again.
                                        i have same kind of fault, i tested diffrent bios dumps with no luck, what program did you use to do that,
                                          DELL Precision 3630 Precision E-2274G Specification for Upgrade or Repair
                                          This specification for the DELL Precision 3630 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision 3630 boardview and Precision 3630 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          09-12-2024, 03:44 PM
                                          DELL Precision 3431 Precision 3000 E-2224 Specification for Upgrade or Repair
                                          This specification for the DELL Precision 3431 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision 3431 boardview and Precision 3431 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          DELL Precision T3420 Precision i3-6100 Specification for Upgrade or Repair
                                          This specification for the DELL Precision T3420 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision T3420 boardview and Precision T3420 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                          DELL Precision 3620 Precision i7-6700 Specification for Upgrade or Repair
                                          This specification for the DELL Precision 3620 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision 3620 boardview and Precision 3620 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          DELL Precision T3630 Precision 3000 E-2174G Specification for Upgrade or Repair
                                          This specification for the DELL Precision T3630 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision T3630 boardview and Precision T3630 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
