Asus Vivobook X512FA Keyboard Backlight (Windows 11)
  • zioclive
    • Dec 2022
    • Italy
    Hi, I've changed the original keyboard of my notebook because it had horrible labels on keys (almost unreadable).
    Anyway I've chosen a new keyboard with backlight. Everything is well connected (the backlight connector too) but the backlight is not working.
    I've read various topic on the forum about using from command prompt as an administrator:WBT.exe -C CNFG/ W DD 7C
    Without any luck I've got some errors ( Ndrivrs Failed) and return code 0.
    Do you have any suggestions ?
    Many thanks for your appreciated help
  • ktmmotocross
    Asus G513QE keyboard and backlight not working
    by ktmmotocross
    Have this Asus G513QE with keyboard, keyboard backlight and Led backlight not working. other works ok.
    i measure all voltages ok on keyboard, KB backlight and Led backlight. looks like a kbc error.
    but as laptop works i think it cannot be bad. maybe its FW. have anybody some hint for this?
    08-08-2025, 06:29 AM
  • user546087
    Keyboard backlight too bright - Asus Zenbook S16 / UM5606
    by user546087
    I have a new Asus Zenbook S16, Model UM5606. Unfortunately, the keyboard backlight is too bright, even on the lowest setting. I have explored several ways now:
    - kindly ask Asus for an adjustment - they basically told me to STFU and get lost It is not possible, they say. Of course.
    - tint the keycaps from behind - I have already tried that - it is kind of a last resort
    - try to find out, how it is done, look at schematics - this is, where we are at.
    - maybe get the BIOS modified somehow? This would be the best option but I do not know a lot about...
    02-24-2025, 02:03 AM
  • hollox123
    ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
    by hollox123
    Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
    1. Laptop keyboard doesn't work
    2. The backlight on the laptop keyboard doesn't work
    3. The x2 side LEDs (red) on the laptop don't work
    The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
    I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
    But I am strongly aiming that it is somehow a BIOS-related problem,...
    05-11-2025, 08:05 AM
  • obdcart
    Asus X415ea Adding a Keyboard with Backlight
    by obdcart
    Hello my friends i hope you can help me, i have just replace a keyboard with non backlight on a Asus X415 Laptop and i already install a Keyboard with backlight, the motherboard has the conector and ic's to control the light but i doens't work, i already try with a new installation of Windows and it's the same and injecting 3v/5v to the backlight flex it turns on the light, i think must be disable on Bios or need a jumper configuration.
    I hope you can give me some help
    06-28-2024, 02:21 PM
  • Dobrowol
    Asus GA402RK keyboard and kb backlight problem
    by Dobrowol
    Hi. I have a problem with Asus ROG GA402RK. The keyboard suddenly stopped working along with the kb backlight. I replaced the keyboard and the ITE KBC chip and the problem is still the same. I don't see any passive elements that look damaged. Does anyone have an idea?
    04-28-2025, 04:30 PM
