Maybe a bit off topic but im in search for schematics for a inverte used in a renault kangoo ez 2013. I hope someone can help me
In search for schematics for a inverter for a renault kangoo EZ 2013
by chbenHi,
i search the schematics and boardvew (.pdf ans .brd) for DA0NJHMBAH0 REV H ASUS TUF706HM F17-TUF706HM-HX162W
Thanks-
Channel: Schematic Requests ONLY!
by inflex
Looking for Boardview & schematic for this Microsoft Surface Go 2. Only thing I have on the bottom is "Model: 2013" beyond what is already written on the board itself ( DA0Z93MBAE0 )...2 Photos-
by eccerr0rMy cheap crappy 1KW grid tie inverter (GTI) seems to keep blowing IGBTs. When I first got it, it had two failed IGBTs. It used four 60N100's (TO264). I bought 5 from a dubious source (fleabay) and replaced just the two that were dead. The GTI worked for almost two years but recently one of the two that I replaced failed. Since I had three spares, I replaced the dead one. Then a few weeks later it failed again. Weird. Well since I bought dubious China-sourced IGBTs from fleabay it could very well just be a mixture of fakes. I replaced it, but then a day later it failed again! I put in the last...
by amigo744Hello,
i am searching for 820-01310-A schematic ?
apple imac 27 2019 .
no backlight power.
regards-
by x_orange90_xI just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
I don't know how exactly to test the inverter itself. Is it... - Loading...
