E-MU xboard 25
  • kr315
    • Apr 2018
    • 6
    • Poland
    E-MU xboard 25
    E-MU xboard 25 is not starting. Checked diodes on power input, voltage regulators seem fine. Again, multilayer board stops my work without schematics.
    Does anyone have schematics for this or met the problem already?
  • yuii
    ThinkPad W530 - faulty CPU regulators?
    by yuii
    Hello
    I've got two W530 boards, one with K1000M and one with K2000M graphics card. The first one had an issue of turning off under heavy CPU load after about 30 minutes or in idle. GPU load wasn't causing it to shut down. Trying to turn it back on would only make the power LED to come up for about 2 seconds without fan spin or thinklight flash, and that's it. It also wasn't charging the battery after it died.
    Gently pressing the laptop in left upper corner would fix this problem for a couple of days.
    The latter is completely dead and has the same 2-second power blink, nevermind...
    11-01-2023, 02:59 AM
  • seweryn
    Dell 2007FPb with 4 buck step-down regulators
    by seweryn
    I have monitor Dell 2007FPb. It was working good. Some day it was shut off and stay dead.
    I checked some voltages on the boards. I read this thread:
    https://www.badcaps.net/forum/showthread.php?p=335335
    and very usefull budm posts ( thanks buddy, it was great work ... ).
    My damage was typical: 3A fuse burned and ZD701 diode was shorten.
    So my board is in few points different than other described in citing thread. On my board are 4 buck converter regulators. Apart regulators 3.3V (Q6), 5V (Q14), 12V (Q9), is ther fourth, build on MOSFET Q2. Two TL1451 has together...
    04-08-2022, 11:43 AM
  • ravi_1617
    Lenovo B540 ,Starting Problem
    by ravi_1617
    Hello !
    Model Lenovo B540
    Board Details 09244-1
    LA14 DIS MB
    48.4DMO4.01.1
    This Board has starting problem , when CMOS batter is removed ,it starts (turn ON) by itself fine, than if is short power switch once board turns OFF Fine.
    when connected CMOS dont start.
    3.3 volts present at power switch (it slight less 3.267-87) .there was slight liquid spill at around U53 (SL62872HR),when I clean that area . I mean when its little hot board warm , board starts few time ON and OFF by power switch
    One more thing i want to mention ( by mistake i started at...
    10-14-2025, 02:08 AM
  • PeteH
    Dell Precision 5520 / LA-E331P r2.0 starting into CPU-failure
    by PeteH
    I have here a broken Dell Precision 5520 / LA-E331P r2.0 to play with
    I found the schematics for r1.0, but not for r2.0.
    The situation
    - the laptop turns on, but the screen stays black -> the dell diag-LED shows the blink pattern for "CPU failure"
    - the voltages close to the CPU stay at low
    - I don't see any hotspots on the PCB (thermal imaging camera)
    - some spots/areas on the PCB indicate some kind of liquid "damage"
    Before I start digging though 70+ pages of schematics, maybe somebody...
    10-12-2025, 07:54 AM
  • tranquility
    Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
    by tranquility
    i want to repair an Onkyo TX-NR809 receiver.
    symptoms:
    on power on, display appears and i hear one click. enue functions is given.
    - no hdmi output
    - audio output not tested, but i think it is not there
    - usb sticks are not recognized
    if i read out the chips with display+standby button + tone+
    both dts show only ????
    chip is D830K013BZKB4
    things i have done:
    - reflow of the dts chip without taking off and reballing
    - changed the aluminium caps without the big one with 25v because i dont...
    08-25-2025, 01:04 AM
