Ok, I have this device, a skulpt chisel. It's acting funky, and the battery never goes higher than 70% charged anymore. I popped the case open, and instead of NiMH batteries I was expecting (older version had them), I found Li-ion batteries. Two 10440 AAA form factor 3.7v 320mah batteries. I can find 10440 batteries, but finding ones with solder tabs is a challenge. I'm really not into ebay li-ion batteries. I'm not soldering the tabs on myself, it's not worth the risk.
So, I have found a flat pack that will fit. I can cut the plug, solder the wires on, tape the pack down, and it's all good.
https://www.adafruit.com/product/258
My question is, will the electronic protection circuits on this pack interfere with the charging circuits on the board? The standard li-ion AAA batteries don't seem to have any obvious protection circuits on them.
Thanks!
Battery Datasheet:
https://cdn.badcaps-static.com/pdfs/...14bb7e5e7b.pdf
Battery Protection IC
https://cdn.badcaps-static.com/pdfs/...4dd1bdc4ae.pdf
And there is an 8814 mosfet which i assume cuts off the battery if something bad happens.
Thanks!
Battery Datasheet:
