Hakko desoldering gun help
  • RepairNewbie47
    • Jun 2018
    • 18
    • United Kingdom
    Hi all new here great forum !
    Ok so my issue is slightly different to the norm probably .
    I have a Hakko 900c soldering station with a iron and a desoldering gun , the gun is completely destroyed which is a shame , however someone gave me a gun from a duratool ZD-915 and ZD-917 machine which is very similar looking , not as durable I dont think as the old Hakko but my question is , would it work and how should I go about wiring it ? I no longer have the Hakko one for a reference which I`m kicking myself about so thats a pain . The Cheapo one has 6 pins and the hakko has 5 so I`m thinking thats a non starter there but I thought I would ask the experts in here how to go about trying to make it work . I would LOVE to have it running again , when it was working (about 10 years ago) it was fantastic. They are both 24v I believe (the iron and the new gun are , I havent checked the v`s yet)
    TIA
  • RepairNewbie47
    • Jun 2018
    • 18
    • United Kingdom
    Re: Hakko desoldering gun help
    Having had a look inside the Hakko now , it seems that it uses only 4 of the pins out of the 5 in the socket , so I can only assume that this is 2 for the element and 2 for the switch (send and return to the pump) , and the temp is controlled but the co-efficiency of the heater itself (as some of them were back then). This is good it means I dont need to worry about the 2 wires on the heating element for the temp sensing I can just go ahead wire the element , and the switch and hopefully we should have a working gun . The gun isnt here yet should arrive tomorrow but I know it has a 4 wire element so thats where I`m at with it . If anyone has any info to throw in here I would greatly appreciate it before I blow something up . My hakko is an amazing Iron I really REALLY dont want to break it ..lol .
      • Jul 2011
      • 6039
      The ZD-915 Desoldering gun may not have the same type of temp sensor as a Hakko
      The heating element is the heavier set of wire the thinner set of wires are the temperature sensor on the ZD-915 gun
      • RepairNewbie47
        • Jun 2018
        • 18
        • United Kingdom
        cheers thanks for that , i dont think the hakko had a temp sensor at the element , i think it used the difference in resistance at the coil its self to determine the temp (coefficient temperature resistance) so i think i can just ignore the temp sensing wires and use the heating element . Should know tomorrow , thanks for your help.
        • redwire
          • 3907
          I know the Hakko 470, 471, 472 temperature controllers use the heater's resistance as a measure of temperature. It monitors heater current for feedback of temperature.
          Be careful, if your temperature controller thinks the heating element is cold (lower resistance/higher current) than expected, it can go into thermal runaway and overheat, even with the temperature dialed way down.
            • 31015
            the Zong-Di handpiece uses a thermocouple,
            i will post the pinouts later - i worked them out to make my own base from a fucked weller!
              • 31015
              1 - black (thermocouple)
              2 - blue (thermocouple)
              3 - red (heater)
              4 - red (heater)
              5 - white (switch)
              6 - white (switch)
              shell - earth(yellow)
              • RepairNewbie47
                • Jun 2018
                • 18
                • United Kingdom
                3 - red (heater)
                4 - red (heater)
                5 - white (switch)
                6 - white (switch)
                awesome , many thanks mate , this is going to help no end .
                • RepairNewbie47
                  • Jun 2018
                  • 18
                  • United Kingdom
                  thanks for that i`ll bear that in mind when i fire it up for the first time , cheers.
                    • Jul 2011
                    • 6039
                    How well dose your conversion weller base with a ZD-915 gun work
                      • 31015
                      not done yet.
                      soon, just waiting for delivery of a couple of used iron bases from a friend.
                      a ZD with lcd disp and a solomon with led readout.
                      hoping to use the controller from one because they use a thermocouple.
                      the original weller base used a thermister and was just a pot and led - i'm not using that!
                      my build list so far:
                      zong-di handpiece,
                      weller case, transformer & pump
                      extra air filter - https://www.banggood.com/5X-Universa...-p-913243.html
                      and "new" control board as mentioned.
                      once it works, i may build this for it!!!
                      https://manolena.wordpress.com/2015/...tion-with-avr/
                        • Jul 2011
                        • 6039
                        Keep us posted with your progress with this project
                        • trantony34
                          • Apr 2018
                          • trantony34
                          ủng hộ mọi người ơi @@
                          • RepairNewbie47
                            • Jun 2018
                            • 18
                            • United Kingdom
                            OK so , here`s what we have , (see images)
                            There are 3 active wires + earth at the plug do I ASSUME that there is heater + heater - and a pump - which connects to the - side of the heater when you pull the trigger . Does that sound plausable to you guys ?
                            The wires are - black - +v/H on the board
                            - Red - -v on the board (believed to be pump -)
                            - White - H On the board
                            Dave
                              • 31015
                              so 4 wires,
                              and you need at a minimum,
                              0v
                              element +
                              sensor +
                              switch return
                              do you have the broken original handpiece?
                                • 31015
                                btw, there are 2 other ways of sensing temp.
                                one is to put a thermocouple inline with the element - but i dont think that crude controller could handle that.
                                the other is as you said - to calculate the change of element impedence.
                                but that is also a bit complex.
                                i *hope* you have an old handpiece.
                                • RepairNewbie47
                                  • Jun 2018
                                  • 18
                                  • United Kingdom
                                  No i dont have an old gun , That went a long time ago . I`ve had this unit getting on 25 years . So i wired the new gun to H and H on the board it heats up ok , problem is it doesnt stop heating up . to the point it glows , at which point a "oh shit" popped out and I shut it down . So its no sensing the temp for sure .
                                  • RepairNewbie47
                                    • Jun 2018
                                    • 18
                                    • United Kingdom
                                    BTW one of those wires is Grounded to the case .
                                      • 31015
                                      solved.
                                      wiring diagram is in here:
                                      to be blunt, i would be looking to replace the controller.
                                      also, try not to use both irons together.
                                      the original desoldering head was 60w and the zong-di is about 80w
                                      i dont know how much extra the transformer can output.
                                        • 31015
                                        one other thing,
                                        the zong-di has thin switch wires - put a solid-state relay in the base for pump switching.
