I have been trying to sort a old Sinclair ZX 48k Spectrum that when i recently turned it on has acquired a display fault. It was working fine last year so gathered its probably the badcaps. Well I have replaced every single capacitor and even a couple of transistors that (TR4 & TR5) which were a common one to cause display faults but while the display is definitely less noisy than it was, still has the same fault. When turned on the system does seem to go through initialisation and then displays this corrupt blocky screen and I can see a couple of pixels flashing on & off and that I would say is the cursor flashing which shows it is working. None of the chips are getting really hot. Any ideas anyone? Here is a picture of the screen.
ZX Spectrum 48k DIsplay fault
Re: ZX Spectrum 48k DIsplay fault
The PCB is version 3. I was careful trying to take it to bits. Not always so lucky when with a Acorn electron the pins broke off the ULA socket when removing the chip.
I Kinda guessed it might be a Ram chip from reading forums. Its going to be finding which one. I looked to see if anyone else had a display like mine as a clue but nothing even close. Looking at a normal screen it looks like mine is displaying the Sinclair message at the bottom but its all distorted. The screen flashes through a few different colours while booting so I guess its working fine just the distortion on the screen is the problem. Do you know roughly which bank of Ram is likely to be faulty?Comment
can you actually read text?
i can post a rom that does diagnostics.Last edited by stj; 01-12-2017, 05:41 PM.Comment
Thanks thats interesting and a useful tool, Dont I need a flash rom board to load the rom image into like the one Retroleum do here http://www.retroleum.co.uk/smart-card-for-zx-spectrum/Comment
Something I've done with older gear is to take a good DRAM IC and swap out IC's one at a time until the dud is found. Maybe this can be done with the memory IC's. I know 4116's are really unreliable if this where VRAM is vs upper bank.
http://store.retroleum.co.uk/zx-spectrum-chips
Using SRAM as a replacement: http://zx.zigg.net/LRR/Comment
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
This specification for the Acer Nitro Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) boardview and Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060...09-06-2024, 10:20 PM
This specification for the Acer Nitro Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) boardview and Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060...09-06-2024, 10:20 PM
This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) schematic. Our users...09-06-2024, 09:30 PM
This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Silver) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Silver) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Silver) schematic. Our...09-06-2024, 09:30 PM
- Loading...
