Anyone have troubleshooting knowledge of refrigerators?
  • keeney123
    Lauren
    • Sep 2014
    • 2536
    Re: Anyone have troubleshooting knowledge of refrigerators?
    The attached is your exact Manufacturer and the Model used. I believe the model to be on page 23 upper right. This will eliminate all doubt as to how the compressor is connected. And the run Cap. is mandatory and the company gives the precise type of caps to use. If these caps are not used the unit may not start or the motor can burn out.
    • keeney123
      Lauren
      • Sep 2014
      • 2536
      Originally posted by caphair
      I'm guessing full 120v what's interesting is that voltage was dropping when I tested the relay without it being connected to the compressor. Shouldn't it have been active and not dropping if tested that way?
      Also how do you know for sure the compressor isn't a PSC type using a run capacitor rather than a resistive start, capacitor run type? That PDF was helpful. How'd you find it?
      I just looked for it.
      I would say never just agree with a person unless you understand what you are agreeing to. Even if you feel like a fool because this is the only way to fully understand how things work. One teacher told me to try and understand something for up to 8 hours. If you can'y understand it by then, then just except you can't understand it now.
      • caphair
        • Nov 2011
        • 1249
        #43
        Ok so it's a RSCR (resistive start capacitor run type) and looks like the capacitor is connected across in parallel. So that helps to know.
        Do you strictly search for PDF files when searching? Because I didn't come across any of the files you posted when I tried looking
        • keeney123
          Lauren
          • Sep 2014
          • 2536
          No, I do not strictly search for PDF files. I am kind of use to researching things. I have a good IQ in abstract thought and spacial things. Not that IQ means much, but it is a indicator of what one is good at. My mind bounces around a lot. People who have structured thought will think I am crazy a lot of the times. So when I search for things I am constantly asking myself what do I need to know and how am I going to get there. With that going through my mind I just let my mind take its own course of action.
          • keeney123
            Lauren
            • Sep 2014
            • 2536
            So with this information have you determined if the reseting is the PTC or the Over-Voltage protection?
            • caphair
              • Nov 2011
              • 1249
              #46
              Update: New part fixed it. It's up and running. I'm not sure if it was the solid state relay or the overload that went bad but new relay and overload worked.
              I'm wondering if the overload's spring tension became weak causing it to trip more easily or if the solid state relay wasn't delivering full power
              • keeney123
                Lauren
                • Sep 2014
                • 2536
                The key to that was to know which was tripping. If it was the overload protection then I would believe that to be faulty. If it was the PTC that was tripping then it could of been the switch across the capacitor was not shorting the cap out completely at start up. Glad you got it working.
                • caphair
                  • Nov 2011
                  • 1249
                  #48
                  The PTC was solid state using a triac. Only thing that could "click" was the overload
                  • keeney123
                    Lauren
                    • Sep 2014
                    • 2536
                    From what I read there are two devices that could of been clicking. The overload protection usually trips like a breaker an has to be manually reset. It is possible they made this as a thermally set after it cools down. The PTC is different I believe that whole board was the PTC. I believe it is used to start and maintain the motor. This is done by shifting the phase of the voltage between the run and start winding. So initially when the motor is to start the phase shift will be different at start up than at run. The run capacitor is shorted out by a bi-metal thermally timed switch. As the motor gets to run position the PTC needs the run capacitor to lessen the phase shift because the motor has a certain inertia. The PTC may also lessen the voltage at the same time. This bi-metal thermally timed switch. Opens at a certain time. It is kept open if the motor is conducting current most likely by the triac turning on and conducts through one part of the bi-metal connection keeping it open. If the motor does not run this bi-metal switch will close because it cools down and tries to start the motor again.
                    • keeney123
                      Lauren
                      • Sep 2014
                      • 2536
                      They could also be keeping the bi-metal switch open by the charging and discharging on the capacitor causing enough heat at the junction points to keep it open or the bi-metal switch is designed when current runs through it, it stays open magnetically. I am not really sure of the how. I am just giving probable ways this can be done. The OverVoltage is physically separate circuit and connection and is placed between the hot line coming in and the one terminal on the motor nothing else is connected to. It does not necessarily have to be on the motor. I would suspect it to be somewhere in the area.
                      • CuriousJohn
                        Burco boiler power problem
                        by CuriousJohn
                        Burco BCPLSAFWM5L 5 Litre Wall Mounted Automatic Water Boiler With Filtration UK 240v
                        Does anybody have any experience with these Burco units at all there is no record of them on the forum lol and a proper service manual would be nice. I invite you all to pesuade me not to botch repair it with a 5v relay, read on.
                        This unit was rescued from a skip 3 years ago, the only fault it had then was no backight display (plus it wanted a new probe set and top seal) but the screen was never an issue you can still see the screen as is and I just use it to get 5 Litres of very hot...
                        12-22-2024, 10:25 AM
                      • jm1234
                        9V relay temperature 40C
                        by jm1234
                        Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                        I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                        05-09-2024, 03:03 AM
                      • edugimeno
                        Biomass Boiler not driving cleaner motor relay. ENERTRES BIOMASA BI-650
                        by edugimeno
                        Hi everyone!
                        I have this board that suddenly stopped supplying power to an output that drives an interchanger cleaner motor.
                        I checked while the board was in place with all wires attached and there's no AC voltage on the corresponding plug X5
                        This X5 is driven by fuse F8 (tested OK) which comes from the second orange relay
                        To make sure there are no charcoaled contacts inside the relay, I got a 24VDC power supply and got it ready to manually power up the coil side of these relays.
                        I respected the polarity, positive to cathode of protecting diode
                        So provided all...
                        04-18-2024, 01:15 PM
                      • CoinCoin88
                        Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                        by CoinCoin88
                        I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                        Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                        09-15-2025, 03:36 AM
                      • blues_spirit
                        practical courses for troubleshooting pc motherboards
                        by blues_spirit
                        Hello from France,
                        mon2 kindly advised me to post a thread to ask the question(s) I'm concerned about. I'm new to the forum and I'm looking for practical courses for troubleshooting pc motherboards especially laptops in Europe, if possible in France. I have been a computer network system administrator and a corrector of administration modules for automated programs under Unix. But I really miss the practical "ops" side of troubleshooting. So I would like to start from the beginning: 1.8V, 3.3V, 5V and 19V tests for example, etc...
                        Do you think this is feasible for me? I...
                        12-18-2022, 12:56 PM
