SMD cap concern
  • wrx884
    • Apr 2015
    • 67
    SMD cap concern
    I have a super Nintendo that I have opened up to inspect its caps and to see if there's any common trace damage cause by these.
    Upon opening this console, C59 and C60 are the common caps to leak and damage traces underneath. Not sure if the photos show well enough but the C59 caps top is actually inverted as if something or somone has pushed on the top of it quiet hard (no signs of this tho). Is this another way of finding faulty caps? I haven't seen this as such before so thought id ask.
    C59 is a bipolar smd cap 10uF 25V
    C60 is just the normal smd cap 10Uf 50V
    Edit just realised this maybe in the wrong section can mods move to the appropriate section please cheers
  • japlytic
    • Oct 2005
    • 2086
    Re: SMD cap concern
    These SMD units are a bit hard to measure, so I simply recommend replaacing them all (there are not all that many on the board).
    I've also read that a number of the early SMD aluminium electrolytic capacitors can be problematic; the Sega Game Gear is known to have bad SMD aluminium electrolytic capacitors in the audio section.
    • wrx884
      • Apr 2015
      • 67
      Re: SMD cap concern
      I will probably do that anyways but still would like to know if the visual inspection is showing a bad cap or not? since its not showing any leaking what so ever. I can easily remove it since no legs are broken yet and use the ESR meter on it.
      your right these caps from around this era is prone to leaking on a number of consoles which is why I check them
        • 31304
        Re: SMD cap concern
        as someone who has rebuilt over a dozen, i'll correct you on that, the audio section is about the only part that doesnt leak!
        you have to replace every damned electrolytic in them!
        the fact that it contains an invertor and a CFL tube doesnt help!
        • wrx884
          • Apr 2015
          • 67
          Re: SMD cap concern
          well ive removed C59 and C60 and tested them with the ESR meter, don't know if results will differ being one is a bi polar cap or not?
          C59 11.79uF, 2.9ohms, 1.4% Vloss
          C60 10.49 uF, 1.9Ohms, 0.8% Vloss
          Mayb a bit off topic stj but I must disagree slightly ive seen a lot of the Audio PCBs on the game gears need recapping just not as much as the main board but the same issues pop up on them.
          • bulkchart32
            i think i accidently ordered non-polarized 10uf caps for my original xbox. will this cause a problem?
            by bulkchart32
            i ordered a lot of caps from digikey to repair my xboxs. one thing i ordered was 50NXA10MEFC5X11-ND caps and i think they are not polarized. will this cause any kind of a problem? i really don't want to order new caps just because of this.
            06-16-2025, 03:09 AM
          • eryjus
            by eryjus
            05-10-2023, 11:21 AM
          • Paxman_Swede
            by Paxman_Swede
            Hello!
            01-14-2025, 09:51 AM
          • mitsu2k
            Is it common for these caps to go bad?
            by mitsu2k
            Just wondering how common it is for these types of caps to go bad. I have a couple that are measuring approximately correct (997nF) however a couple of them show signs that they have been pretty warm at some point. I'm replacing them anyway but just wanted to know how common it is for these to maybe act up when hot....
            01-11-2023, 10:39 AM
          • captain150
            by captain150
            03-16-2025, 07:34 PM
