list of PS5 Internal Fuses
This is a sticky topic.
+ More Options
Posts
  • MarkRocket
    • Jan 2020
    • 17
    • United Kingdom
    This is not a definitive list, and I do not claim if it is 100% accurate so please do your own research, based on the information from littlefuse, RS, Farnell and a few other places, using information about the markings on the fuses
    Please feel free to distribute, amend, correct, etc
  • BwE
    • Dec 2024
    • 12
    Or use the schematics?
    • MarkRocket
      • Jan 2020
      • 17
      • United Kingdom
      Yes, or course use schematics, but I personally don't have them and didn't realise they were available.
      • adamski1952
        • Oct 2021
        • 93
        • england
        If schematics are available please share.
        • Saiyaman45
          • Mar 2024
          • 8
          I have not schematics, but check this, may can help you...
          • MarkRocket
            • Jan 2020
            • 17
            • United Kingdom
            Thank you very much Saiyaman45​, what program is used to open the PCB files, I have RIMU for Windows, but it errors saying it can't open the file
            • ourlissene
              • Jan 2021
              • 3
              • France
              Thank you very much
                Surface Mount Fuses Fundamentals Datasheet
                TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                10-07-2024, 06:07 AM
              • Sik_6ty_Sixx
                HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
                by Sik_6ty_Sixx
                So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
                02-18-2025, 05:06 AM
                How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                by sam_sam_sam
                About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
                12-14-2023, 07:45 PM
              • acedogblast
                Power supply for main amp blows fuses after replacing filter caps.
                by acedogblast
                Hello I have a Marantz sr5012 that I have been repairing. After I have replaced the 2 main filter caps the 2 fuses for the power amplifier blows. The original capacitors are ELNA LAO 10,000uF 71V and the replacements are Nichicon LKS 10,000uF 80V.
                I assume a short circuit connection has occurred so I set my multimeter to measure ohms across the 2 fuse connections and both read 55 Kilo-ohms so I assume that is ok.
                I am certain that I do not have any bridges on my soldering and after probing around I do find a temporary 0 ohm reading when probing across the positive and negative...
                02-27-2023, 05:11 PM
              • Mark D
                Samsung UN65JU67ODFXZA Version TD01 Schematic and Parts List
                by Mark D
                The TV is a Samsung UN65JU67ODFXZA Version TD01. I replaced the power source board and the TV is now working, but I decided to try and troubleshoot the old board to fix at the component level. Trying to get a schematic and a parts list has proven to be an issue. Trying on my own, I can't tell you how many times my Norton security has flagged sites as "malicious". I ordered a service manual from ServiceManuals.net, paid $16.99 and got 66 pages of everything BUT schematics and component parts list! Can anyone steer me in the right direction? Some of the surface mounted component parts...
                10-29-2024, 03:15 PM
