PS4 No picture
  • Combustion
    • Mar 2023
    • Latvia
    PS4 No picture
    Hello. I have this PS4 CUH-1116A and it seems to be missing a component. Could anyone tell me what it is? Thanks in advance! xoxo
  • lotas
    • Jan 2016
    • 4921
    • Russia
    The protective diode marked “DJ” is the same as those located higher on the board.
    • maneatingmonkey
      Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
      by maneatingmonkey
      I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
      There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
      03-27-2024, 07:17 AM
    • JJAAMM
      by JJAAMM
      Problem
      07-06-2023, 06:01 AM
    • TR103
      by TR103
      - it keeps rebooting
      01-22-2025, 04:12 PM
    • jpreza
      Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
      by jpreza
      I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
      Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
      It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
      Looking at the card, it appears to be missing the following:
      1x 1.0uH inductor - orange square
      2x...
      11-01-2024, 10:54 PM
    • YellowJacket
      Samsung QE55Q60RAT - no picture
      by YellowJacket
      Hi friends,
      a friend of mine gave me this TV to fix, with common SAMSUNG TV issue - damaged panel. Turning on, sound is present, but no picture. So I went directly to standard process, connecting two pads together with a wire ( see in the picture ), and then removing flex cables. With right flex connected, there was half screen working, but still no picture ( disappearing colors and similar weird stuff ) + working sound. With left flex connected, TV is restarting + working sound. I supposed, left side is damaged, so I then blocked all 8 CLK pins ( going from 0R resistors on the second...
      07-30-2024, 01:31 PM
