Need help with this wellness machine board
  • ciki
    • Aug 2014
    • 132
    • Ireland
    This is control board of some kind of wellness machine ,when charger connected (18v) no power but when i bypass mosfet works ,is it mosfet fail or 2 capacitors ,can i use any of this from laptop motherboard like replacement or i have to order new one ,and can anyone identify 2 capacitors
  • kasfamily
    • Aug 2014
    • 774
    • Russia
    these are diodes
    • Soulzink
      Samsug washing machine. Power supply DC41-00189a board issue
      by Soulzink
      I am trying to fix a samsung washinmachine power supply main board.
      I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
      Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
      The power supply board reference is the following: DC41-00189a
      I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
      04-19-2025, 06:26 AM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • prodigy83
      MacBook Pro M1 Pro Logic Board 820-02100 Mosfet where to purchase?
      by prodigy83
      My reference only: TT10141.
      Problem: I need to purchase a mosfet chip from board 820-02100 M1 Pro, that is supposed to be Q5820 but according to Digikey, the schematic diagram I sent them, neither are relevant to the actual mosfet specification I sent them. I just basically need to find this mosfet to purchase, I cannot find it anywhere and am hoping someone could point me in the right direction without have to purchase this entire allusive board. Already checked with Digikey, Mouser, Aliexpress, eBay. Any suggestions?
      Mosfet specs are as follows:
      Chip markings:...
      03-12-2024, 01:38 PM
    • corrize
      IO power board, mosfet leak ?
      by corrize
      Hello, I have a basic power board (from DSLR camera), this board convert 12v in some other voltages (there is no charging chip). This board is disconnected to other, so it feed nothing, the outputs should be open lines.
      When I plug the battery (12v), I measure a weird behavior…
      I found a mosfet , with 12v at source and gate, and the voltage decrease very slowly at drain : 8v… 7v… 6v… I measured with meter source-drain : 45KOhms, so can I deduce surely the mosfet has a leak (and it is dead) pls ?
      The mosfet datasheet, but it's basic one.
      https://pdf1.alldatasheet.co...
      03-05-2023, 04:49 AM
