Identify cap, garage door opener.
  • digge
    • Apr 2006
    • 296
    Hi
    Have this garage door opener in front of me and seems like the caps is busted. I have a problem identifying the manufacturer and cant find any datasheets for them. With my limited knowledge that means its hard to know what to replace them with.
    From what i can read on them the brand should be NKL and the series should be N, they are good for 85 degrees and there is a few different values on the board. The sleeve is grey with black stripe for negative side.
    The broken one seems to be on the output (might be input didn't look that closely on the datasheet) of a 7818CSP voltage regulator so my guess is that's why its not working. Also the voltage regulator seems to have been very hot.
    The one on the right in the picture is the one that's busted.
    So does anyone have a clue what cap might fit the purpose? The cap in question is 100uF 40V, but im probably gonna replace all for good measure.
  • Rob Northen
    • Jan 2010
    • 137
    • Denmark
    Re: Identify cap, garage door opener.
    Based on where the cap is used , I would go for something like Panasonic FC
    • Krankshaft
      • Jan 2007
      • 2328
      I take it this door opener was manufactured in the 80s? The caps have no stamped vents.
      Why do you say the cap is bad?
      You mention overheating of the voltage regulator. How is the input voltage to the regulator derived via a linear transformer or via a zener diode pre regulator stepping down line voltage to the 30-40 V input? Is the input voltage within spec and is the voltage below the input caps rating?
      Zeners can become leaky and the input voltage can drift over time.
      Board darkening from components like voltage regulators is normal especially with a device this old. The cheaper PCB materials tend to darken at the slightest exposure to heat.
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Brand is Meritek
        NKL is Series
        N is tolerance +/-30%
        Old series - no data sheet.
        But with that high a tolerance they are obviously just a GP cap.
        Mann-Made Global Warming.
        - Dr Seuss
        • digge
          • Apr 2006
          • 296
          The reason i think its broken is i measured ESR in circuit and that gave me 199 ESR, that sounded way to much even for a GP cap. Desoldered it now and it measures 1,6uF and 174 ESR, also i can see all the electrolyte have leaked out by one of the legs. Thats probably the gunk i saw on the board.
          Also now when im home i can take better pics then my cellphone so here goes, a full pic of the board.
          I was probing around a bit and on the input (of the regulator between middle and input pin) i measured about 38V AC, should be a DC voltage on the input of the regulator right? That would mean go hunting for some busted diodes as well?
          The whole thing is getting its feed from a 24V transformer btw.
          Still cant figure out why they put an 18V regulator in there, the relays are 24V, the actual motor is 12V so, maybe they are "overvolting" the motor since its running for such shorts periods?
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            When the motor is running the voltage will drop plus there is a high current when it first starts so, yeah, it might be overvolted on purpose.
            Also might be some voltage drops between the regulator and the motor.
            Yup, that's too much ESR.
            - Dr Seuss
            • Krankshaft
              • Jan 2007
              • 2328
              As long as you're sure that it is a regulator and not a Triac yes.
              The motor runs on DC that's weird. The openers in the US just use a zener diode regulator, a switchmode power supply, or a linear transformer for the control circuitry only.
              The motor is a 120V AC Permanent Split Capacitor type (start cap and start winding are always connected) motor cycled by a relay on the control board.
              That big fat diode is the half wave rectifier responsible for feeding the DC motor.
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Seems to me an DC motor would be a more sensible choice.
                More starting torque, easily reversible, and not much coast-down.
                I dunno what they actually use 'cause I never broke one.
                - Dr Seuss
                • Krankshaft
                  • Jan 2007
                  • 2328
                  Oh I know why they use them.
                  The newer garage door openers boast a battery backup system. An AC motor is impractical for this purpose an inverter would add way too much cost.
                  Because god forbid you'd have to haul your butt out of your car and manually open the door .
                  Just did some research DC motors have been available as an option in the US for awhile.
                  Funny when I bought one to install in 03 there was no mention of a DC motor being an option when I was looking at Sears. It seems that they have been available since the 90s. When the price of semiconductors dropped and cheap efficient power supplies could be built to drive the DC motor.
                  • digge
                    • Apr 2006
                    • 296
                    The motor is actually something similar to a windshield wiper motor. Might even be one, who knows
                    I'm not 100% sure its a regulator, but at least thats what my google skills lead me to belive. Its an old Thomson(?) part and i cant find a descent datasheet for it. Thought it would be a sibling to the ol 7805 and cousins
                    To me it sounds like an AC motor for this kind of application doesnt make sense and over complicates it. The direction part is just 2 microswitches depending on what end the motor is at basically. (This one have the motor moving on the chain, they even use the chain for ground and the rail for positive, kinda crazy even if its low voltage :P )
                    Maybe i should go ahead and replace all the caps for good measure, as said earlier they don't even have vents like modern ones have.
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      Sounds like a good idea.
                      - Dr Seuss
                      • Krankshaft
                        • Jan 2007
                        • 2328
                        Replace all the caps and see what happens. A high quality General Purpose series like Chemicon KMG for example will be fine.
                        An induction motor will easily rotate in either direction by just changing current flow (swapping the wires) to the start winding.
                        Disconnect the cap on any cap start motor and run it. It won't rotate but you can choose it's direction by spinning it either clockwise or counterclockwise and it will continue rotating in that direction.
                        AC motors don't require a high current power supply to run that's why they're popular. Nowadays with the proliferation of cheap power supplies that point is pretty moot. However AC induction motors are brushless which makes them more durable in the long run.
                        • digge
                          • Apr 2006
                          • 296
                          Finally got my parts yesterday. I opted to swap more then needed just to save me one shipping cost. The shipping is more expensive then all the parts
                          So i swapped the caps for KMG ones, swapped all the 4007 diodes for good measure. Tried the board, still dead. Measured input on the voltage regulator, 38V DC, output nothing. So i swapped the voltage regulator as well and success, now it works!
                          Thanks for your input Krankshaft, PCBONEZ and Rob Northen, appreciate it.
                          • japlytic
                            • Oct 2005
                            • 2086
                            I am curious about whether modern garage door openers use switching power supplies - if the caps go bad, you can't open it!
                              Lift Master garage door opener with WiFi capability application through your phone
                              by sam_sam_sam
                              I had a lot of trouble with the WiFi connection from my router inside of the house into a ( new ) metal garage I had to run a 150 ft cat6 patch cord so the WIFI connection would be strong enough for the WiFi connection on the garage door opener would work correctly ( my son has a work out area in the garage as well and he was having to put his phone near the door to be able to stream music ) ( so I was going to eventually put WiFi out there anyway )
                              This garage door opener WiFi is very touchy if you lose the power it does not remember the password for the router which is weird or...
                              01-21-2023, 08:31 PM
                              Linear Garage Door Opener Control board took a crap install a new control board back normal
                              by sam_sam_sam
                              I have been having issues with this garage door opener for a while first the range of the remote was a lot less and sometimes it would start to go down and stop for no reason that I could find and would every once in awhile to start with then it started going more frequently until last Saturday when I opened the garage door it refused to close so I cranked up force all the way maximum limit this did not work also the sensor on one side that has a green and red lights that are supposed to be on when the door is open and there are no obstacles in the way on the original board the only light that...
                              02-08-2025, 06:52 AM
                              Linear Garage Door Opener Control Board Repair weak capacitors
                              by sam_sam_sam
                              I was having issues with the controller not always responding to remote control signal having to hold button until garage door started to move
                              Now after replacing the two capacitors on the two 5 volt power supply rails
                              One is used for the up/down limit up/down force circuits
                              Second one is used for the radio receiver circuit
                              The main filtering capacitor ESR value was a little higher than a new one
                              https://www.northshorecommercialdoor...yABEgLxlvD_BwE
                              09-03-2022, 12:15 AM
                            • Cornboats
                              Garage door opener-safety cutout faulty
                              by Cornboats
                              I have vintage Slavedor garage door opener that has stopped closing the door. If I disable the up/down current control to the motor it works fine. I've attached the larger control board which is for everything and the smaller current control board.
                              Normally the current control is set slightly above the maximum current normally used. If the door exceeds this it should stop and reverse when closing or just stop when opening. Can someone please explain how the current control board works so that I can try and repair or replace the defective parts.
                              I see my self as an interested novice...
                              01-19-2023, 05:25 AM
                            • deep000
                              Burned Voltage Regulator in Monitor – How to Identify and Repair?
                              by deep000
                              My computer monitor ASUS VP249H stopped working, and smoke came out of it.
                              I opened it and found that a voltage regulator had burned out.
                              The problem is that I can't identify its reference.
                              I searched online for schematics or photos of similar boards that people are selling, but without success (no schematics, bad quality of the board or lack of the reference when it's a good quality 😅).
                              How can I find its reference, and do you think it's repairable?
                              Monitor: Asus VP249H
                              Board reference: 0171 - 2271 - 6083
                              09-08-2024, 01:13 PM
