Dell optiplex 3000 micro bios
    Originally posted by redcapangler View Post
    Ok, I reflashed original bios again, confirmed the machine can still boot (success) cleared the settings - then reflashed the updated file you provided.
    The video came online (good, I wasn't waiting long enough for the reboots), i went into bios but the Absolute is still grayed out. Any thoughts?
    so it was about poor soldering... did you remove CMOS battery before soldering bios chipset? Try applying defaults and see if works.
      Hi - so i've verified soldering is not the issue (have successfully reflashed many times on this board now). I did remove the CMOS battery before soldering, no issues there. Chip is working.
      On a similar board (Optiplex 7010 micro) I required both the 16mb and 32mb chips to be updated in order for it work. hoaca388 helped with that one. I'm wondering if edits need to be made to the 16mb file as well?
        well, 1st time when you wrote the file I sent you, you said it wasn't work. 2nd time when you wrote it in bios chipset it worked ... so, where was the problem? 32Mb chipset contain Bios_Region so Computrace is in it, no need to modify 16Mb chipset usually but you seem to have also problems with ME firmware. So you need to do a clean ME to your full bios.
Name:	Screen Shot 2025-04-02 at 20.30.23.png
          I will try to do this myself and report back. First time performing an "ME" clean.
            I NEED UNLOCK PASSWORD
            OPTİPLEX 3000 MICRO
            ST:8XWK4V3
            REG MODEL D15U
            guys please help me to remove admin password on bios
            st: 4TJ0HY3
            st: 4TJ0HY3
            post full name and model, motherboard model, etc.
              DELL OPTIPLEX 3000 micro PC
                Hi volinakis , I was unsuccessful and got stuck. I was able to install ME Analyzer, get the same output in you screenshot at the bottom when loading my 16mb file. When I go to find the right firmware (attached in screenshot), I does not seem that my version is available out there to use as a base file for the cleaning process. Do you know of anyone that has gotten their ME Cleaned with version 16.1.31.xxxx? I'm only seeing all the guides go up to version 15.x.x.
                Any help is appreciated, I'm really stuck on this next part.
                Thank you,
                - Brian.
                  Originally posted by hoaca388 View Post
                  Re: Dell optiplex 3000 micro
                  1111111
                  Is it possible I could just load the bios from this older post to resolve my issue? Or would that not work?
                  Thank you,
                  - Brian
                    Thank you,
                    - Brian
                    I tried this and it did not work. I'm trying another bios from this thread for the 16mb to see if that one will work. Really stuck here.
                      Did not work, posting my original files to see if someone else can assist? I'm looking to have absolute disabled in both of these files / cleaned ME please.
                      Service tag is JXHJ5S3
                      I've been struggling for about a month in this thread trying to get this fixed, any help is truly appreciated.
                      - Brian
                        Hello, my BIOS is all "LOCKT" Can you please help me unlock the bios?
                        any idea to fix this ?
                        OptiPlex 3000 Micro
                        Service Tag: 1119MP3
                          - Brian
                          OptiPlex 3000 Micro
                          Service Tag: JXHJ5S3
                          Become a Badcaps supporter
                          Thanks to all supporters.
                            hoaca388 - these worked perfectly. Can you explain how you performed modifications to the 16MB file to clean the ME especially with version 16.1.32? Or can you point me toward any other resources on how you did this?
                            Thank you,
                            - Brian
                              OptiPlex 3000 Micro
                              HELLO CAN YOU HELP MINE THIS WAS MY ORIGINAL BIOS
                              SERVICE TAG:4TJ0HY3
                                SERVICE TAG:4TJ0HY3
                                You problem is ????
                                  You problem is ????
                                  bios password lock sorry i didnt mention
                                    Unlocked
                                      I have no password issues but no image, tried some bios files from here but no result, diffrence is that with 16mb file from here the fan get's to 100%
                                      no image system will take 10 watts and chipset is getting 45-50 degrees.
                                        SMDFlea commented
                                        Editing a comment
                                        Service tag ?
