Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
  • DynaxSC
    • Apr 2021
    • 475
    • Poland
    I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
    It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
    I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios dump from a real physical board and the values of MAC/UUID/Serial. The one from MSI site is useless, as it does not contain any MAC/UUID/Serial.
    The MAC/Serial/UUID is possible to look for in the BIOS (Setting/System Status/ DMI Information), or alternatively MAC can be found on a sticker on the SATA connectors (6 x 2 digit, eg: D8 BD C1 06 DD 28) , and Serial is to be found on the ATX power connector.
    The dump can be made with a CH-341 programmer, but you need to have a connector for MSI board (the connector is JTPM1) or an special clamp for WSON 8x6 packages - something like this:
    I attach the boardview and schematics for this board, if one would need it.
    Alternatively it would require to desolder the BIOS form the board and to have a WSON8-DIP8 adapter for CH341 - something like this:
    Note that desoldering requires some good knowledge how to do it, so don't do it if you are not experienced - the WSON bios package has a big thermo pad underneath, so it can be desoldered only with a preheater and heat gun, soldering iron is useless !!! The BIOS chip on the board is a Winbond W25Q256JWEQ (package is a 8-pad WSON 8x6 mm), so you can't use the standard clamp for normal BIOS chips.
    Will appreciate your help.
  • DynaxSC
    by DynaxSC
    06-14-2024, 03:49 PM
  • mkdj
    by mkdj
    Dear all,
    10-19-2025, 04:41 AM
  • Habble7
    by Habble7
    Suspected Cause:
    Troubleshooting Attempts:
    05-22-2025, 07:28 AM
  • Citymin
    by Citymin
    S/N : 5RNK9FFT70...
    08-05-2025, 05:12 AM
  • greelidd
    K6604J Vivobook RTX 4070 BIOS Dump Request
    by greelidd
    Hi all! Tldr: need a bios dump (.bin format) for K6604J (rtx 4070 and i9-13980hx)
    Longer story: my vivobook stopped booting after i switched out the thermal paste. I think the BIOS got corrupted. Everything i tried didn’t work until finally i decided to buy a CH341A BIOS programmer and just send over the BIOS directly from another PC onto the BIOS chip. I connected fine and backed up the existing BIOS, but i can’t find a clean BIOS that’s a .bin format. And I tried using UEFI software to extract all the files from the ASUS BIOS .exe file and get to the .bin but it was a .302...
    09-01-2025, 06:14 PM
