P920 Workstation bios
  • mesdova
    • Oct 2015
    • 24
    • algeria
    need bios 32Mg and 4Mg P920 Workstation (ThinkStation) NILE NL1019 REV 1.0
    - Type 30BC
  • hoaca388
    Badcaps
    • Jan 2022
    • 11794
    Re: P920 Workstation bios
    Alway attach your original corrupt bios file and serial number when you request bios fix.
    • mesdova
      • Oct 2015
      • 24
      • algeria
      Sn s4ha7434
      • mesdova
        • Oct 2015
        • 24
        • algeria
        Originally posted by mesdova
        Sn s4ha7434
        BIOS original corrupt
        • hoaca388
          Badcaps
          • Jan 2022
          • 11794
          Try
          • mesdova
            • Oct 2015
            • 24
            • algeria
            it doesn't work i think the problem is EC bios
            thank you hoaca388
            • hoaca388
              Badcaps
              • Jan 2022
              • 11794
              thank you hoaca388
              Don't rush, with this bios file I'm a bit lacking in confidence that I'm doing it right, wait and see if someone else redo it for you.
              • cozily
                DELL Precision 3660 Tower Workstation BIOS
                by cozily
                I bought a DELL Precision 3660 Tower Workstation from a second-hand seller. After bringing it home, I found out it was actually a testing unit. The BIOS cannot be upgraded (only the ME and PD2 sections are upgradable), and there are test messages displayed during boot, which really affects the user experience.
                Upon inspecting the motherboard, I noticed that the BIOS is composed of two chips: one 8-pin 16MB chip and one 16-pin 32MB chip.
                I acquired two new chips from another source containing the official BIOS version, but after installing them, I found that none of the...
                07-09-2025, 08:43 PM
              • macabook
                by macabook
                🧩 Initial Issue
                07-24-2025, 02:17 PM
              • Vesko356
                by Vesko356
                08-11-2023, 03:27 AM
              • AHmad_Salal
                Need BIOS Dump/ROM for Lenovo Thinkstation p500
                by AHmad_Salal
                Hello all,
                I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                11-28-2023, 05:28 AM
              • EpicLPer
                HP Z2 SFF G9 Workstation (5F0D1EA) - BIOS corruption fix
                by EpicLPer
                Heya,
                I'm currently trying to fix a “HP Z2 Small Form Factor G9 Workstation (5F0D1EA)” after HP issued a warning that some models may become entirely unbootable if left on specific old versions. The exact issue happened to the one I got right now: https://support.hp.com/us-en/documen...235-8577455-16
                I've already desoldered and dumped the broken BIOS, over on the "level1techs" forums someone already took a look at it and sadly couldn't fix it either 😥 Still grateful of them taking a look however!
                I guess the current BIOS/dump truly seems to be...
                05-08-2025, 03:41 PM
