Bios Dell Optiplex 3050 Micro
  • kingskie
    • Oct 2014
    • 249
    • indonesia
    I need Bios for Dell Optiplex 3050 Micro.
    does anyone have?
    thanks
  • hoaca388
    Badcaps
    • Jan 2022
    • 11798
    Re: Bios Dell Optiplex 3050 Micro
    Post your original corrupt bios dump and sevice tag number of device.
    • kingskie
      • Oct 2014
      • 249
      • indonesia
      this dell optiplex 3050 micro can turn on but shows error:
      Boot Guard verified failed
      system will shutdown
      press any key
      in the attachment is the bios i backup from this machine and also attach the service tags and mainboard number
      thanks man.
      • hoaca388
        Badcaps
        • Jan 2022
        • 11798
        Dell OptiPlex 3050
        Service Tag: 99XP9M2
        • kingskie
          • Oct 2014
          • 249
          • indonesia
          Dell OptiPlex 3050
          my backup bios file only 8.195KB but yours is 16.384KB
          do you think my bios is corrupt?
          • hoaca388
            Badcaps
            • Jan 2022
            • 11798
            You have failed the backup and the bios chip shows it as 16MB of data.
            • kingskie
              • Oct 2014
              • 249
              • indonesia
              Update, 07CE works for me... thanks a lot @hoaca388
              • viperef
                • Nov 2022
                • spain
                thx a lot
                • Olive73
                  • Dec 2022
                  • 5
                  • FRANCE
                  Hello
                  I need help !
                  I have a Dell 3050 Micro that won't start... It displays 2 led flashes (orange) then 5 led flashes (white)
                  It's probably a corrupted BIOS problem.
                  Can you help me find the right file to reprogram my Bios chip?
                  The EZP2019 programmer does not come to anything and does not recognize Winbond 25Q128CSIG chip - It tells me that it is an Eeprom93!
                  When I set manually on the Winbond 25Q128 and I start the process, the writing starts then an error appears after checking the writing. The Bios chip does not keep any data and remains empty!
                  I have the impression that this programmer is not very reliable! Do you have a reliable programmer to advise me?
                  Serial Number: 2B551M2 / Express Service Code: 5027326058
                  Thank you in advance for your contribution !
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11798
                    Originally posted by Olive73
                    Hello
                    I need help !
                    You can try the 2 files in #4 but must read your bios chip first to make a backup of the original bios you can try with CH341A programmer, this is the cheapest one, pay attention to the voltage of this type (the black board has a default voltage of 5vol) in addition you can use the Rasberry Pi with the Flashrom tool.
                    • Olive73
                      • Dec 2022
                      • 5
                      • FRANCE
                      Hello;
                      Thanks for your quick response and advice...
                      I have already tried the 2 files in #4 - But nothing works - With EZP2019 + croco clip (even at low speed) it ends in failure (flash check error address 0h)
                      In reading, the original chip seems empty! So difficult to recover an .OLD file
                      I will wait for a possible other solution while waiting to receive a new programmer to try again!
                      • Olive73
                        • Dec 2022
                        • 5
                        • FRANCE
                        Correction !
                        Back to my original post!
                        The BIOS chip is not a WINBOND - It is actually a GigaDevice 25B128CSIG
                        After buying the CH341A programmer - I managed to rewrite the BIOS - My various attempts brought me different LED diagnostic codes, but the PC does not start...
                        I managed to recover the Bios 3050.old and I reinstalled it as at the beginning - I am now waiting for your help...
                        • hardware1
                          • Sep 2021
                          • 2936
                          • N/A
                          Correction !
                          Can you provide to us your original bios? and also write your Service Tag.
                          all donations are welcome,
                          • Olive73
                            • Dec 2022
                            • 5
                            • FRANCE
                            Unfortunately, I can't attach the file... I tried several times and it doesn't download! I'll try again... Ok! I think it's good this time!
                            Numéro de série : 2B551M2 / Code de service express : 5027326058
                            • hardware1
                              • Sep 2021
                              • 2936
                              • N/A
                              Here's your New bios file, try them one by one and see what will happen.
                              • Olive73
                                • Dec 2022
                                • 5
                                • FRANCE
                                A big THANK YOU to you for the 2 files that you sent to me...
                                I tested these 2 files; unfortunately, after installation, the PC displays a new error (2 orange leds + 3 orange leds then repetition)
                                Ditto for the 2nd file!
                                Thank you anyway for the time you spent and your quick response!
                                • radumamy
                                  • United Kingdom
                                  Good Afternoon All. Please accept my apologies as I am a newbie and don't quite fully understand BIOS programming. I have a Dell Micro 3050 (old BIOS attached), service tag 43LXXK2 with a 2-1 amber error code. Hopefully it can be rescued with this. I'm not sure how to edit this bios as Dell PFS Extractor produces 2 separate folders, each containing a 9MB bin file. Thank you for your support.
                                  • radumamy
                                    • United Kingdom
                                    Resolved, please ignore. Thanks.
                                    • adamgouadma
                                      • Jul 2017
                                      • 184
                                      • setif
                                      does anyone have?
                                      thanks​
                                      Service Tag: F7GFMN2
                                      • youcefinfo
                                        • May 2024
                                        • ALGERI
                                        sevice tag number:J9JNDN2
                                        does anyone have?
                                        thanks​
                                        • mrrubik
                                          Dell Optiplex 7010 micro bad BIOS flash?
                                          by mrrubik
                                          Hi folks,
                                          I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
                                          After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
                                          Steps I took:
                                          1. Read BIOS with CH341a, verified hash twice
                                          2. Patched
                                          12-23-2024, 04:11 PM
                                          DELL OptiPlex 3050 OptiPlex 3000 i5-7500 Specification for Upgrade or Repair
                                          This specification for the DELL OptiPlex 3050 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 3050 boardview and OptiPlex 3050 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          09-12-2024, 03:44 PM
                                          09-12-2024, 03:36 PM
