Hi
I have the same machine, Lenovo M70q 11E8.
Since the chip is locked, is buying a blank chip and install the original BIOS will work if replaced?
Thank you in advance
Lenovo 11E8 M70Q DIFFERENT FROM 11DT. REQUEST BIOS PLEASE
Hi, I just want to ask if replacing the two ICs could help resolve the chip-lock issue, and if it’s safe to use the firmware uploaded by Sr. hoaca388 after injecting the DMI data from the original ChromeOS dumps. I was unable to erase the chip due to an SR lock issue that cannot be set to unprotect. Even after setting WP pin 3 high and connecting WP pin 7 to pin 8 with 3.3V power from the CH341A programmer, the issue still remains.
I believe someone here might be able to help, since we have several computers donated from Amazon that are affected by this issue. These machines are intended for the children in our school, but unfortunately, they cannot use them because of the corporate ChromeOS lock.
Thank you for reading my post.
M70q Desktop (ThinkCentre) - Type 11E8Hi there,
I have 3 ThinkCentre M70Q, one with the amazon coreboot bios untouched and the other 2 have been previousely tinkered with. Could you please help me get them to work with a stock lenovo bios?
The boards are same: IQ4X0IL1
The serial numbers are as following:
-untouched one: PC2072L2
-PC2F0V1M
-PC2F0V0N
I've attached the dumps for the 16M and 8M chips.
Thanks in advance!
Hi there,
-PC2F0V1M
-PC2F0V0N
Thanks in advance!
Hello Good Day! I have a ThinkCentre MM70Q Gen 3 that has Amazon bios, can someone clear this?Help is much appreciated. Thank You
Name: Lenovo M70q Gen 3 mINI pc
Type: 11y6
S#: MZ00VVPQAttached FilesLeave a comment:
M70q (type 11E8) Desktop (ThinkCentre) - Type 11E8Hi there,
I have a Lenovo ThinkCenter M70Q 11E8 with amazon bios, changed both cips 16 and 8 with blank, but till now no working pc, I have attached the original iso from lenovo where you have the BIOS and UEFI there, 16 and 8, can you please guys help me to extract the .bin both , clear me , so I can try to write and hope it will work.
SN : PC2F0V1M
MB : IQ4X0IL1
I saw there are a lot of those amazon bios that no one make them work
Thank you
Hi there,
SN : PC2F0V1M
MB : IQ4X0IL1
Thank youAttached FilesLeave a comment:
how about i've downloaded bios on support section in exe format possible can be convert to bin file here i attach the file thanks and more power.Leave a comment:
i tried the attach file @ddtechrepairs the machines comes to rebooting only it does not power on stable turns off tthen off automaticLeave a comment:
hi has anyone have backup for lenovo M70q 11E8 bi:GH470 NM-C621 Rev1.0 SN: MJ0KGNBA for windows version.i have a machine which is in chrome version in support it has support for windows the bios availble is in exe format hope someone can help me for this one. thanksLeave a comment:
Lenovo ThinkCentre M70q - 11E8 - iq4xoil1
SN PC2F0V1M
winbond 25q128jvsq2130
winbond 25q64jvsiq2138
i try to write a clean bios but not make nothing, and at section unprotect nothing i put some photo
tell me write the bios and after i read is the same bios from amazon
thanks for help meLeave a comment:
Lenovo ThinkCentre M70q - 11E8 -- iq4xoil1
bios chip i read all 2 bios and not able to erase or write another bios, tell me is protecred and in neo programer i press unprotect and do not change nothing
winbond 25q128jvso2130
winbond 25q64jvsio2138
tomorow i put same bios backup if someone know how i make it and what biod is good to pui 8 and 16 thanks
please make me new bios
sn: pc2bpvgl
issue: chrome os
attached old 16mbLeave a comment:
by fefocaceresHi everyone,
I need some help unlocking the BIOS on a Lenovo ThinkCentre M70q Gen 2.
The admin password is set and I can’t access BIOS settings.
Here are the system details:- Model: Lenovo M70q Gen 2
- Product type: 11DT
- Serial number: MJ0GSLST
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
Channel: BIOS Requests ONLY!
08-12-2025, 03:01 PM -
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
by grimacelordHello there.
I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
History:
1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
I searched for this error online and discovered...-
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
I have opened the laptop and identified the main BIOS chip...2 Photos-
- Loading...
